(1) 2 3 4 »
NISSAN S13 BRAKES
From Lisbon
Hi!
Which is the diference:
Nissan Silvia CA18DET 180sx brake caliper with 250mm rotor
and
Nissan s13 200sx brake caliper with 255mm rotor?
Can i use the s13 200sx brake caliper on Nissan Silvia 250mm rotors?
200SX Brake caliper are biger than 180sx brake caliper?
Compare the brake caliper 200sx with brake caliper 180sx
they have the same distance between bolt support holes/slid pin bolts?
Thanks
Luis
Posted on: 2016/7/25 16:24
Edited by Luigi on 2016/7/25 17:06:47
Edited by Luigi on 2016/7/25 17:07:07
Edited by Luigi on 2016/7/25 17:23:18
Edited by Luigi on 2016/7/25 17:23:48
Re: NISSAN S13 BRAKES
Unknown
* In Japan, no 255 mm rotor was used with S13
* Same in North America
However, a 257 mm front rotor was used, as well as a 258 mm rear rotor. Caliper differs from the 250 or 280 caliper. Brake pads are also different shapes
You can use different calipers in some cases. Key factors to consider:
* Bolt pattern: will it bolt to your struts (or adapters)?
* Location: will it clear the rotor hub, or extend past the rotor edge? Can sometimes be adjusted by modifying the caliper adapter
* Size: Does it have adequate size pad size for the rotor? Is it too big for 13" rims?
* Thickness: what thickness rotor is it designed for?
Posted on: 2016/7/25 21:49
From Lisbon
Thanks
It was a doubt that i have.
I just bought new 250mm rotors, ca18 Japan Brake Caliper and brackets from a member.
I need buy new slip brake pins for brake calipers, but i cant find any with 9mm diāmeter, only i can find 10mmm diāmeter, what is 1mm upper.
If i cant find i will Buy 4 pins with 10mm and make 4 new bushing on brake caliper?
What do you think
If i need repair the brake caliper what are the correct references
Rubber parts, brake caliper piston
Many thanks on advance
Luis
Posted on: 2016/7/25 22:18
You will likely need to order repair parts from Japan or Australia, as the 250mm rotor/caliper were not used in Europe or USA
Posted on: 2016/7/25 23:07
It seems Nissan does not sell the pin separately
Here in my country, the local auto part shops either sell bare caliper, or full caliper including bracket and pins
Cost
* bare caliper: $52
* full caliper: $38
Of course these are for the larger S13 brakes, as they don't use 250mm brake here
Pins are $3 USD, but I don't know what size they are
jpg  BA0841430-1.jpg (177.54 KB)
174_579693c71417b.jpg 1500X1500 px
Posted on: 2016/7/25 23:33
From Lisbon
Hi!
Will fit s13 Silvia or ps13s 2.0 non turbo came from Japan rear brakes fits under Datsun 1200 13" minilite whells? I ve just bought front brake calipers with 250 mm rotors and apropriate bracket
Many thanks
Luis
Posted on: 2016/8/3 20:45
JAPAN Silvia
 S13 CA18DE, CA18DET
PS13 SR20DE, SR20DET
non-turbo SR20DE came with either 250mm disc brakes OR 280mm disc brakes. Apparently, all SR20 non-turbo Ks got the large size, also all 4-wheel-steering SR20 non-turbo cars
* 280mm disc brakes won't fit under 13" wheels
* 250mm disc brakes won't fit under 13" wheels (some) but will fit under other 13" wheels
Minilites, if sold by the Minilite company, varied over the years, so who knows unless you test-fit them? Silvia came with 14" or 15" wheels
Posted on: 2016/8/4 1:00
rear brakes? Japan S13/PS13 used the same rear brakes: 258mm rotors + calipers with integrated parking brake. Don't know if anyone has used them on a Datsun 1200 front
Posted on: 2016/8/4 1:08
From Lisbon
hI!
i want put Silvia QS SR20DE rear brakes on my Datsun 1200 not on front brakes but on rear
I have just read
Brakes:
CA18DE/CA18DET/SR20DE have 250mm diameter front rotors and slightly smaller calipers. SR20DET have 280mm front rotors and slightly larger calipers. This information is correct?
The car im pretending buy brakes is Nissan Silvia SR20DE according with i read they have 250mm rotors, im correct?
Do you know the dimensions of rear rotors from Nissan SR20DE? Those are the rear brakes that i want put on my Datsun 1200 back
Posted on: 2016/8/4 17:06
Edited by Luigi on 2016/8/4 20:38:34
For JDM S13, they are 258mm
For JDM S13, Nissan Silvia SR20DE with 4WS apparently has 280mm rotors. S13 Q's with 2-Wheel Steering should have 250mm rotors
Posted on: 2016/8/4 22:00
(1) 2 3 4 »
