« 1 (2) 3 4 5 6 »
Re: a14egi vs 15egi
From Hawaii, USA
Depends on the cost. If you can weld aluminum, definitely worth it. If a local welding shop charges $500 to weld it for you, maybe not worth it
If you get it cheap, you could try JB-Weld ...
Posted on: 2016/10/15 4:57
Re: a14egi vs 15egi
Jb weld to stick to pieces together? Strong enough?
Posted on: 2016/10/15 10:35
Re: a14egi vs 15egi
From Hawaii, USA
Yes, very strong
Posted on: 2016/10/15 11:14
Re: a14egi vs 15egi
From Melbored
JB weld would be fine but good to use some bridging as well in the form of steel mesh
however best of all is hts2000 alloy braze at low heat, just need propane torch or oxy
but as long as you can get enough heat from propane setup thats all you need.
I saw a thread on a RB25 box for SR20VE in japanese using this Brazing and seems
to be better than TIG for the amount of input, time and finish couldnt see final joint
https://www.youtube.com/watch?v=RCrixbXz4rc
Posted on: 2016/10/15 12:08
https://www.youtube.com/watch?v=FEheU28ea3c
Give me control of a nations money supply and I care not who makes the laws - Mayer Amschel Rothschild
Politics not the oldest profession yet same result http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf
Re: a14egi vs 15egi
Start dreaming of injection / injection turbo ....
Matter of cost.
Posted on: 2016/10/15 13:44
Re: a14egi vs 15egi
Btw, do a14,a14e,a15 and a15e sharing same piston? I guess the crankshaft is different.
Posted on: 2016/10/15 13:47
Re: a14egi vs 15egi
* Same differences as regular A14 and A15 (pistons & crank). Flywheels are same
GOT IT
Posted on: 2016/10/15 17:48
Re: a14egi vs 15egi
better pictures
jpg  manifold.jpg (113.35 KB)
17554_580262ebe65a3.jpg 1040X780 px
jpg  manifold2.jpg (141.73 KB)
17554_5802634d7aa2b.jpg 1040X780 px
jpg  manifold3.jpg (186.21 KB)
17554_580264510db99.jpg 1040X780 px
Posted on: 2016/10/15 18:16
Re: a14egi vs 15egi
Hi dd, can I use the h89 manifold gasket and make a little cut to give away to injector?
Posted on: 2016/10/16 16:38
Re: a14egi vs 15egi
From Hawaii, USA
Yes
Posted on: 2016/10/17 0:07
« 1 (2) 3 4 5 6 »
