(1) 2 3 »
GX head??
From Brisbane
i am getting a (cheapish) GX head hopefully and was just wondering how much differecne in power i will gain, running a 32/36 and extractors, will i notice and difference????
Posted on: 2003/3/24 13:57
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: GX head??
Sure you'll notice a difference ... the Weber 32/36 alone makes a difference.
Add a camshaft change, and you'll have something similar to the factory GX engine ... for the HP difference see the Tech Section article Datsun A12GX Engine.
Posted on: 2003/3/24 15:43
Re: GX head??
From Brisbane
does anyone know if it is possible to put a GX on a A14 block?? has anyone done it? what will happen to teh compression?
CHeers
Posted on: 2003/3/25 8:27
Re: GX head??
From Warwick, QLD
yeah I've got a GX head on my A14 and A15, you'll het a compression increase by a bit, always good for more horsies!!!!
Cheers
Damo
Posted on: 2003/3/25 8:39
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: GX head??
From Melbourne, Australia
so as long as he runs premium (optimax/synergy) itll be good for him then?
Posted on: 2003/3/25 8:45
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: GX head??
From Brisbane
what carbies are you running on the A14 gx?? what kinda GO are you GEtting ?
what i couldnt run LRP then?
Re: GX head??
Not too shy to talk
iv got a , a14 block with a15 crank and a a12gx head, redline manifold and twin 40's 11 to1 comp plenty of head work.starts to make ponies bout 3 revs past 8 easy lota fun
Posted on: 2003/3/25 11:04
Re: GX head??
plenty of head work
That's the key.
The only advantage the A12GX head has over the A14 oval port is the combustion chamber design. Yes, it has dual valve springs (which is why you can rev it to "8 grand"), but it is easy enough to fit that to other cyl. heads. The A14 head ported will outflow the A12GX head.
So it mainly depends on if you want high compression or not. There is a lot of discussion on this topic if you use the search box you can find it.
Posted on: 2003/3/25 17:57
Re: GX head??
From auckland, new Zealand
so how much does head work cost like porting it out and double valve springs?
Posted on: 2003/3/25 23:28
Re: GX head??
From Wellington New Zealand
Have a chat to Tony Marsh. He should be able to do big valves, a good port without welding and springs for a couple of grand, and he's in auckland. Hes done a lotta nice A series heads.
Posted on: 2003/3/25 23:51
(1) 2 3 »
