120Y wont start :(
This is my first post!
I have a 1974 Datto 120Y (A12)... and she wont start with the key...i have to push start... when i turn the key, it just clicks?? is that the starter motor?? help needed Urgently!!
(also, has anyone got the English version of the workshop manul in PDF format?)
Thanks
Steds
Posted on: 2003/11/20 3:56
Re: 120Y wont start :(
From Melbourne, Australia
yep thats the starter, welcome to the club, could be an electrical problem though
Posted on: 2003/11/20 4:48
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Perth W.A
chack your starter motor and your electrics if your starter is clicking and nothing is happening is may be worn out
Posted on: 2003/11/20 6:06
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From newcastle, NSW
solenoid on your starter moter is stuffed. an old bush mechanics trick is to get a hammer handle and tap the top of the starter(that is the soleinoid) somtimes the solenoid gets stuck, it might work. Another thing is check the electric conections, make sure that there is good contact and that they are resonably clean, also check the wires for any problems. ON BEHALF OF ALL DATSUN FANS; WELCOME!
Posted on: 2003/11/20 6:55
From Collingwood. Victoria. Aus.
Wecome to the club Steds
I hope you have fun there is lots to gain here.
How about giving us a rough idea of where you are from?
eg San Diego, Alice Springs, Lisbon, Panama,
etc.
It often helps to know for those helping you.
Posted on: 2003/11/20 8:56
Never ever grow up
Welcome to the site.
The symptoms you describe can be caused by nothing more complex than a bad electrical connection at the battery, so a good start is to ensure that
1. The Battery is fully charged & in good condition. You will feel bad if you overhaul the starter only to discover that the battery is crook.
2. The terminals are clean & the leads are tight.
If this is all OK, then move to the starter as a probable culprit.
Chris
Posted on: 2003/11/20 10:44
