H165 diff into a 120Y
From southern sydney "the shire"
will a H165 ute diff (complete back axle, from drum to drum) fit in a 120y without any mods? i know that they are supposed to be weaker than the H150 but its locked
Posted on: 2007/1/16 6:04
Re: H165 diff into a 120Y
The H165 diff, weaker than the H150???
Who told you such a load of old rubbish? If the H165 was weaker, then why would it be used under the heavier cars, like 1600 & 180B wagons along with some 200B sedans & wagons, as well as the series 1 & 2 Bluebirds.
The H165 rear end was used under the 1200 ute because this vehicle was the load carrier of the 1200 range, & was expected to place more load on this part than the passenger models ever would.
If the H150 was stronger, then it would be a simple matter to slip the 120Y rear end [H150] under the ute during production from 1974 onwards as this rear end was in production from then.
Here's the breakdown
H= Nissanspeak for differential
xxx [three digit number]= is the nominal diameter of the ring gear in mm.
Bigger is stronger, ... & heavier.
Posted on: 2007/1/16 8:16
Love your Datsun.
Treat it well.
i thought it said it may be weaker in the wiki. so would it fit?
Posted on: 2007/1/16 8:33
No.
Posted on: 2007/1/16 8:42
Love your Datsun.
Treat it well.
how different are they? can i use the 120y brakes/axles and the H165 diff?
Posted on: 2007/1/16 9:23
From Adelaide, Australia
There are two types of diff fitted to a 120y, a H150 and a Borg Warner diff.
Posted on: 2007/1/16 9:48
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From sydney
For $50 I can sell you a good H150 centre thats not locked, that would be easier to put in for you.
Posted on: 2007/1/16 10:21
Sidedraught I think he is saying he wants the 165 because it is locked.
But its still worthwhile to buy Sidedraught's 150 and have it welded up. That way there is still a normal 150 for when you get sick of the locked diff.
Posted on: 2007/1/16 10:53
From sydney
Ah ha the old wants a locked diff caper, yes buy mine weld it up, then in a week when you have decided you would rather walk up to the shops than drive that pig of a thing with its f@ckin locked diff, you can put your old one back in.
Posted on: 2007/1/16 10:59
sidedraught where abouts in sydney do you live?
Posted on: 2007/1/16 20:37
