b310 Swing Arm Bracket Help
From Indiana, USA
So, as some of you may know, I just purchased and cleaned up a new
rear end(pictures coming soon) for my '79 210. While my friend and I
were working on it, we noticed one of the swing arm brackets was bent
slightly. In an effort to bend it back, my friend stuck a socket
wrench handle through the hole and put a jack handle over it to create
leverage. As you may have guessed, the bracket bent back into place
but now i'm left with a warped hole. Part of the hole now protrudes
into the inner part of the bracket and the swing arm will no longer
slide all the way in. We tried using a vice to flatten it out, but
that bent the handle. It's so frustrating to have this not work, this
is the last thing I need to fix to get it back on the road. Any
suggestions?
Posted on: 2007/2/13 16:49
Re: b310 Swing Arm Bracket Help
From Texas
Try a "C" clamp to flatten the raised area.
Another thought... two sockets back to back to sandwich the bent ear. Couple of large heavy duty washers on both sides, then a bolt and nut to tighten down. Large washer keeps the nut and bolt where you can reach them, sockets flatten the bent ear.
Posted on: 2007/2/13 19:41
From Burbank, CA
you may not want to keep bending this thing... post a pic - i think i have spares laying around.
you'll need to supply bushings...
Posted on: 2007/2/13 21:56
|||\ 81 KPB310 /|||
