1979 aircon
From Datsun 1200 Club
Category: Heating And Ventilation Systems
Starting August 1979 -- factory aircon installation with new compressor type. It is a very nicely designed unit, however the interior cooler protrudes into the passenger legroom and precludes using a package tray.
From August 1979 a uniform kit was offered with DKKC (Diesel Kiki) radial-type compressor.
20087.jpgAlbum 20087 20088.jpgAlbum 20088
B110 1970-1976 All custom, various types
B120 1978-1979 Factory high-idler mount
B120 1979-     Factory low-idler pulley mount
21821.jpgAlbum 21821 20078.jpgAlbum 20078
This kit is beautiful and easy to install. Unfortunately the interior cooler unit is bulky and protrudes farther into the passenger legroom than other types.
Set Parts
You need all these parts:
174_5a1a572dbd2d8.jpgPost 486807 174_5a1b57dc519a0.jpgPost 486814
  • High-pressure flexible pipe (from compressor to condensor)
  • Low-pressure hose (from evaporator to compressor)
  • Tube-Liquid Tank to Evaporator
  • Receiver/dryer (Liquid Tank)
    • Bracket to mount Tank on core support
  • Relay (for compressor)
  • Wiring harness
  • Capacitor for electric fan
Vents may be opened or closed:
20082.jpgAlbum 20082
Twin Condensors and Liquid Tank with connecting pipes.
20086.jpgAlbum 20086
Condensor-to-Liquid Tank hose is routed along the top of core support.
15192.jpgAlbum 15192
Compressor is mounted low on left side of engine.
15194.jpgAlbum 15194
Cooler Unit lines: Evaporator Inlet & Outlet and drain hose
20083.jpgAlbum 20083
Compressor Bracket
Bracket is identified with 1) low-mount idler pulley 2) two large oval openings in bracket
11910-G1615 BRACKET 7908-8910 [593017 6100] w/low-mount tensioner
11910-95W00 BRACKET 8910-
11925-G1615 IDLER PULLEY
23102.jpgAlbum 23102 20084.jpgAlbum 20084 15194.jpgAlbum 15194 20081.jpgAlbum 20081
174_5c45a2674b862.jpgPost 490404
Low-mount Pulley (1979-up) for round type compressor
26588.jpgAlbum 26588 21783.jpgAlbum 21783
Bracket
20079.jpgAlbum 20079 174_5c45a258b87d1.jpgPost 490404 174_5c45a26bd1247.jpgPost 490404 174_5c45a273eae3b.jpgPost 490404 174_5c45a278de62b.jpgPost 490404
174_5c452c6591662.jpgPost 490401
174_5c452c6c82bd3.jpgPost 490401 174_5c452c733f62b.jpgPost 490401 174_5c452c7a6aa50.jpgPost 490401
Interior Unit
The inside unit is a one-box solution comprising evaporator core, vents, switches and fan, and fits underneath the passenger side of the dash.
aircon-1.jpg aircon-2.jpg aircon-3.jpg aircon-4.jpg aircon-5.jpg aircon-6.jpg aircon-7.jpg
Fast Idle Control
From 1978-1989, no special idle control device was used. From Oct 1989 they added FICD.
See Main Article: FICD#Sunny_Truck
COOLER KIT 27600
B7600-G1660 7804-7907
B7600-G1661 7908-8110
B7600-G1662 8110-
27706-65000 REFRIGERANT-COOLER
FICD - See FICD#Sunny_Truck 8910-
11920N BELT-COMPRESSOR
       11920-H1000 7804-7807 L=810
       11920-G1615 7808-     L=814
12303-M0110 CRANKSHAFT PULLEY 7804-7907 COOLER USE
12303-G1615 CRANKSHAFT PULLEY 7908-     COOLER USE
BRACKET
11910  BRACKET-COMPRESSOR
       11910-G1661 7804-7907 [YORK TYPE]
       11910-G1615 7908-8910 [SWASH TYPE, ANGLE OUTLET]
       11910-95W00 8910-     [SWASH TYPE, STRAIGHT OUTLET]
       08131-0351A BOLT M10 x 35mm 3
       08131-0551A BOLT M10 x 55mm
       08915-1401A WASHER 4
11910A 11916-H7200 BOLT 7908- 4
11910F SHIM 7804-
       11713-U0500 T=0.3
       11713-U0501 T-0.2
11925M PULLEY ASSY-IDLER, COMPRESSOR
       11925-A0100 7804-7807
       11925-G1615 7808-
COOLING UNIT
27610  27610-H7900 COOLING UNIT ASSY 7804- DKKC
27616  BRACKET-COOLING UNIT NO 2 DKKC
       27616-G1660 7804-8109
       27616-G1900 8110-
27618  BRACKET-COOLING UNIT NO 4 DKKC
       27618-G1660 7804-8109
       27618-G1900 8110-
27619  HOSE-DRAIN DKKC
       27611-G1660 7804-8109
       27611-G1900 8110-
27619E 27363-18200 GROMMET-DRAIN HOSE DKKC 7804-8503
27620  27612-T3020 EVAPORATOR ASSY-COOLER 7804-
27624  27613-B8520 VALVE-EXPANSION DKKC 7804-
27626  TUBE-EVAPORATOR INLET DKKC
       27785-G1660 7804-8109
       27785-G1900 8110-
27626E GROMMET-EVAPORATOR TUBE
       01651-00015 7804- INLET TUBE インレツト チューブ ヨウ
       27363-18200 7804- 2 OUTLET TUBE アウトレツト チューブ ヨウ DKKC
27628  TUBE-EVAPORATOR OUTLET DKKC
       27787-G1660 7804-8109
       27787-G1900 8110-
174_5a1bbcee5ed64.jpgPost 486818
COMPRESSOR & HOSES
27630  COMPRESSOR-COOLER DKKC
       27630-G1660 7804-7907 [YORK TYPE]
       27630-W7001 7908-8109 [SWASH TYPE, ANGLED OUTLET]
       27630-W7002 8110-8910 <> 27630-W7001
       92610-G1900 9810-     [NON-ANGLED OUTLET]
27681  HOSE-FLEXIBLE, HIGH [to condensor]
       27776-G1660 7804-7904 DKKC
       27776-G1661 7908-8910 DKKC
       92490-95W00 8910-
27781M HOSE-FLEXIBLE, HIGH [2ND PIECE]
       92447-95W00 9810-
27682  HOSE-FLEXIBLE, LOW DKKC
       27775-G1660 7804-7907
       27775-G1661 7908-
27688  01651-00025 GROMMET-DASH DKKC 7804-8910
174_5a1bbcfe5784b.jpgPost 486818
CONDENSORS, LIQUID TANK & PIPING
27640  27640-G1660 TANK ASSY-LIQUID DKKC 7804-
27640E BRACKET-LIQUID TANK
       27642-G1660 7804-8910 DKKC
       92135-95W00 8910-
       08360-81426 SCREW
27650  CONDENSOR ASSY
       27651-G1660 7804-8910 DKKC
       92110-95W00 8910-
27650M CONDENSOR ASSY-SUB
       27653-G1660 7804-8910
       92111-95W00 8910-
       08360-61626 SCREW
       08911-10637 NUT
27653F 27655-G1660 FAN-CONDENSOR 7804- DKKC
27678  TUBE-CONDENSOR TO LIQUID TANK, 1
       27780-G1660 7804-8109 DKKC
       27780-G1661 8110-8910
       92446-95W00 8910-
27681M TUBE-FLARE
       27660-G1660 7804-8910 DKKC
       92448-95W00 8910-
27683  TUBE-LIQUID TANK TO EVAPORATOR
       27783-G1660 7804-8910 DKKC
       92441-95W00 8910-
27683E 27691-G1660 CLAMP-TUBE 7804- DKKC
       08543-51012 SCREW
HARNESS
27062  25230-G1660 RELAY 7804- DKKC
       08543-51012 SCREW
27186F 01552-00191 CLIP 7804-8109
27187F 24220-89991 CLIP 7804-8109
27188F 01552-00191 CLIP
       7804-8910 4
       8910-     5
27629  HARNESS-AIR CONDITIONER
       27628-G1660 7804-8910 DKKC
       27580-95W00 8910-
27629E 01551-00091 CLIP-HARNESS FIX 3
27683E 27691-G1660 CLAMP-TUBE 7804- DKKC 4
       08543-51012 SCREW 4
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=1979_aircon"
This page has been accessed 8,464 times. This page was last modified 11:10, 2 December 2021. Content is available under Datsun 1200 Club.
