NES Part Numbers
(Redirected from NES)
Category: Catalog
Nissan Engineering Section (N.E.S.) specified six- to nine-digit Part Number formats for bolts and screws and other small hardware. During the 1970s these numbers were replaced by regular 10 digit Nissan Part Numbers.
Early Format
[from 520 parts catalog C-037 1965.8]
Nissan Standard Parts (N.E.S.) N.E.S. (Nissan Engineering Standard) parts consist of 6 digits, arrangement of which is, as a rule, in the following order:
Kind(1-~9-59) + Shape & Material(◯) + Nominal Dimensions(Ⓞ) + Length(Δ)
For N.E.S. Parts that have been processed surface finishing or cotter pin hole symbols showing these processings are added to the rear end.
Part Name                   Arrangement of Digits
Hexagon bolt              1 —   ◯   Ⓞ   Ⓞ   Δ   Δ
Carriage bolt             1 —   ◯   Ⓞ   Δ   Δ   Δ
Stud                      2 —   ◯   Ⓞ   Ⓞ   Δ   Δ
Machine screw             3 —   ◯   Ⓞ   Ⓞ   Δ   Δ
Tapping screw/Wood screw  5 —   ◯   Ⓞ   Ⓞ   Δ   Δ
Rivet                     6 —   ◯   Ⓞ   Ⓞ   Δ   Δ
Hexagon nut               9 —   1    1   ◯   Ⓞ  Ⓞ
Self-lock hexagon nut     9 —   1    2   ◯   Ⓞ  Ⓞ
Miscellaneous nut         9 —   1    3   ◯   Ⓞ  Ⓞ
Washer                    9 —   1    5   ◯   Ⓞ  Ⓞ
Tooth lock washer         9 —   1    6   ◯   Ⓞ  Ⓞ
Nut retainer              9 —   1    7   ◯   Ⓞ  Ⓞ
Pin & Key                 9 —   2    0   Ⓞ   Δ   Δ
Plug                      9 —   3    1   ◯   Ⓞ  Ⓞ
Grease Nipple             9 —   3    2   ◯   Ⓞ  Ⓞ
Electric parts            9 —   4    ☆   ◯   Ⓞ  Ⓞ
Rubber parts              9 —   5    ☆   ◯   Ⓞ  Ⓞ
NOTE: ☆ Kind, ◯ Shape & Material, Ⓞ Nominal dimension, Δ Length
2. Distinction by Alias Dimension (Mark Ⓞ)
 Distinction by alias dimensions of diameter and width, and apply 2 digits next to the rear of the digit showing Shape & Material.
[Table shows each code could mean #, inch, or mm value.
Later catalogs add these notes:
1. A. B. C. D. の 4 系列の適用については別に定める。
2. スタッのドの呼び寸法の大きさに対する??のつけ方は別に定める。
3. ?ビンにおいては? 1 杤の??を??する]
3. Distinction by Length Mark (Δ)
 Apply 2 digits next to the rear of those standing for Alias Dimensions. However this is not applied when the length is not necessary. [The digits are in mm, conversion is to inches]
4. Symbols of Surface Finishing, Cotter Pin Hole
 For the parts that have surface finishing or cotter pin hole, apply the following digits adding —mark to the rear of the above mentioned parts number.
                  Surface   Cotter pin hole
Not processed               10
Zinc-Cadmium        1       11
Chrome coated       2       21
Copper coated       3       31
Phosphoric Acid     4       41
Brass               5       51
Copper              6       61
Also See:
* Nissan Part Numbers
* NES Legend
NES hardware parts #in the 1960s used a six-digit format:
Type + Kind + dimensions (d) + length (L)
  t-kddLL or t-kkdLL or t-kkkLL
  e.g: 1-10612
  Surface-processed parts had suffix added
  e.g: 1-10612-51 or 83-30414-1
Around 1968, the digit '8' was added to the beginning:
 81-10612
Finally in the early 1970s they transformed into Nissan standard 10 digit numbers, by adding a 0 to the beginning requiring two finish processing digits at the end:
 08110-612pp
Example:
  • 81-10612 BOLT, fixing timing chain tensioner support [B10 model]
    • Part: 81: Hexagon bolt
    • Kind: 11= Low carbon steel
    • Dimension: 06=6mm diameter thread (M6)
    • Length: 12=12mm
Example:
  • 9-16114 WASHER-lock to fix timing chain tensioner [410 model]
    • New number would be 89-16114
    • Part-Kind: 9-16: Washer, Tooth-lock
    • Shape & material: 1=Spring-lock medium thickness
    • Dimension: 14=14mm
Example: B10 steering column cover screw
  • 83-30414-1
  • 33= Machine screw, Oval head
  • 04= 4mm diameter
  • 14= 14mm length
  • 1= Zinc cadmium coated
Example: B110 steering column cover machine screw
  • 08330-41410
    • 08=standardize hardware prefix
    • 33=Machine screw, Oval head
    • 04=4mm diameter (M4)
    • 14=14mm length
    • 0= filler to complete ten digits
Explanation
reference: Parts catalog C-201 revision 1970.8 page 10
〜〜〜〜〜 Nissan Standard Parts (N.E.S.) Explanation 〜〜〜〜〜
(Metric threads)
Metric screws N.E.S. (Nissan Engineering Standard) parts are composed of 7-digit numbers, and the order of arrangement of each number
1. In principle, it is specified as follows.
 Type (☆) + Shape/Material (○) + Nominal Dimensions (◎) + Length (△)
Although it is specified as above, N.E.S. parts that have been surface-treated or have pin holes, a symbol indicating this is added to the end.
ARRANGEMENT OF PART NUMBERS
   Part Name
81 Hexagon bolts              81 — (○)(◎)(◎)(△)(△)
   Hexagon head pointed bolts          "
   Hexagon flange head bolts           "
82 Stud                       82 — ○ ◎ ◎ △ △
83 Machine screw              83 — ○ ◎ ◎ △ △
84 Pointed machine screw      84 — ○ ◎ ◎ △ △
85 Tapping screw              85 — ◎ ◎ ◎ △ △
87 Inverted flared nuts       87 — 1 ○ ○ ◎ ◎
   Standard flared nuts       87 — 1 ○ ○ ◎ ◎
   Straight connectors        87 — 1 ○ ○ ◎ ◎
   Elbow connectors           87 — 1 ○ ○ ◎ ◎
   Hose clamps                87 — 2 ○ ○ ◎ ◎
   Clevis                     87 — 3 ○ ○ ◎ ◎
89 Hexagon nuts               89 — 1 1 ○ ◎ ◎
   Self-locking hexagon nuts  89 — 1 2 ○ ◎ ◎
   Square nuts                89 — 1 3 ○ ◎ ◎
   Wing nuts                           "
   Hexagon weld nuts          89 — 1 4 ○ ◎ ◎
   Tapping discs                       "
   Plate nuts                          "
89 Plain washers              89 — 1 5 ○ ◎ ◎
   Spring lock washers                 "
   Finish washers                      "
   Tooth lock washers         89 — 1 6 ○ ◎ ◎
89 Retained nuts              89 — 1 9 ○ ◎ ◎
89 Split cotter pins          89 — 2 1 ◎ △ △
89 Filler and drain plugs     89 — 3 1 ○ ◎ ◎
89 Grease nipples             89 — 3 2 ○ ◎ ◎
89 Spring nuts                89 — 6 ☆ ○ ◎ ◎
89 Push-on spring nuts        89 — 6 1 ○ ◎ ◎
(Note) ☆ Type ○ Shape/material ◎ Nominal dimensions △ Indicates the characteristic length.
低炭素綱 Low carbon steel
中炭素綱 Medium carbon steel
合金綱 Alloy steel
1. Classification by shape and material (symbol ○). This indicates the shape and material of the part, and a one-digit code is added after the type code.
Type of shape and material
PART NAME     MATERIAL, SHAPE CLASSIFICATION               CHARACTERISTIC NUMBER
Hexagon bolt  Low carbon steel Flat and round tip screw    1
 81-          Medium carbon steel Flat and round tip screw 2
              Alloy steel Flat round tip screw             3
              Low carbon steel Pointed tip screw           4
              Medium carbon steel Pointed tip screw        5
              Alloy steel Pointed tip screw                6
Stud          Low carbon steel, coarse thread              1
 82-          Medium carbon steel, course thread           2
              Low carbon steel, fine thread                5
              Medium carbon steel, fine thread             6
Machine screw Pan head                                     1
 83-          Flat head                                    2
              Oval head                                    3
              Truss head                                   4
              Binding head                                 5
              Hexagon head                                 6
Pointed tip   Pan head                                     1
machine screw Flat head                                    2
 84-          Oval head                                    3
              Truss head                                   4
              Binding head                                 5
              Hexagon head                                 6
Tapping screw Pan head                                     1
 85-          Flat head                                    2
              Oval head                                    3
              Truss head                                   4
Flared nut    Inverted nut                                 1
 87-11        Standard nut                                 2
Connectors    Straight connector                           1
 87-12        Elbow connector, brass                       2
              Elbow connector, copper                      3
Hose clamp    A-type clamp                                 11
 87-2         B-type clamp                                 11
Clevis        A-type clevis                                1
 87-31        B-type clevis                                2
              ai-type clevis                               3
Hexagon nut   Low carbon steel                             1
 89-11        Medium carbon steel                          2
              Low, Low carbon steel                        3
              With groove, Low carbon steel                7
              With groove, Medium carbon steel             8
              With groove, Low, Low carbon steel           9
              With groove, Low, Medium carbon steel        0
Hexagonal nut N-type, Low carbon steel                     3
 with stopper N-type, Medium carbon steel                  4
 89-12        N-type low, Low carbon steel                 5
              N-type low, Medium carbon steel              6
              S-type, Low carbon steel                     7
              S-type, Medium carbon steel                  8
Square, Wing  Square nut                                   1
 89-13        Wing nut                                     4
Weld nut      Hexagon                                      1
 89-14        Square                                       2
              Tapping disc A type                          3
              Tapping disc B type                          4
              Plate                                        5
Washer        Spring lock (normal)                         1
 89-15        Spring lock (?single)                        2
              Plain (standard type)                        3
              Plain (large type)                           4
              Finish                                       8
Tooth washer  Internal tooth (small outside diameter)      1
 89-16        Internal tooth (large outside diameter)      2
              External enlargement shape                   3
              Slotted                                      4
              Double tooth (for general use)               6
              Augmented tooth (for heavy loads)            7
Nut retainer Round holes on both feet                      1
 89-19       Round hole on one foot                        2
             Long holes on both feet                       3
             Long hole on one foot                         4
             Long holes on both feet                       5
Cotter pin 89-21
Threaded     Square head tapered screw                     1
 plug        Square hole tapered screw                     2
 89-31       Hexagonal head tapered screw                  3
             Hexagonal head parallel screw                 4
Grease       Straight                                      1
 nipple      67.5° angle                                   2
 89-32       90° angle                                     3
Spring nut   A-type No. 1                                  1
 89-6        A-type No. 2                                  2
             B-type                                        41
             C-type                                        51
             D-type No. 1                                  61
             D-type No. 2                                  62
             D-type No. 3                                  63
             D-type No. 4                                  64
Push-on      A1 type                                       1
 Spring nut  A2 type                                       2
 89-61       B type                                        3
             C type                                        4
2. Classification by nominal size (symbol ◎). Classification by nominal size, usually expressed by a two-digit number following the number that classifies the shape and material.
NOMINAL SIZE
Nominal  size mm  1  2  3 3.5 4  5  6  8  9  10 12 13 14 15 16 18 20 22 24
Characteristic A  01 02 03 07 04 05 06 08 09 10 12 13 14 15 16 18 20 22 24
               B  31 32 33 37 34 35 36 38 39 40 42 43 44 45 46 48 50 52 54
               C  61 62 63 67 64 65 66 68 69 70 72 73 74 75 76 78 80
               D  81 82 83 87 84 85 86 88 69 90 92 93 94 95 96 98 00
Notes
1. The application of the four series A, B, C, and D is specified separately.
2. The method of assigning the characteristic number to the nominal size of the stud is specified separately.
3. The first digit of the characteristic number is omitted for split pins.
3. Classification by length. The characteristic number for the nominal size is usually followed by a two-digit characteristic number, but if the length is not required, it is omitted.
LENGTH CHARACTERISTIC NUMBER
Length mm       4  6  7  8 10 12 13 14 15 16 18 19 20 22 24 25
Characteristic 04 06 07 08 10 12 13 14 15 16 18 19 20 22 24 25
  number
   26 28 30 32 34 35 36 38 40 41 42 44 45 48 50 51 52 54 55 57
   58 60 62 64 65 68 70 75 76 80 85 90 95
4. Surface treatment, cotter pin hole, and material indication. Parts with surface treatment or cotter pin hole are indicated by adding a "-" after the part number and using the following symbols.
SURFACE TREATMENTS, COTTER PIN HOLE AND MATERIAL
                                       Material:
Cotter pin   Surface                   ?  ??  Cu  Aluminum Stainless steel
 hole       treatment
Cotter pin   No surface treatment     -   5   6   7         9
             Zinc plating             1
             Chrome plating           2   5 8
             Copper plating           3
             Phosphate                4
             Black zinc               4 2
             ? finish                 8
             Painting after           8 8
              phosphoric acid treatment
Cotter pin   No surface treatment     0 1
 with holes  Zinc plating             1 1
             Chrome plating           2 1
             Copper plating           3 1  5 9
             Phosphating treatment    4 1
             Black zinc plating       4 3
             ? plating                8 1
             Painting after           8 9
              phosphating treatment
5. Indication of washer-assembled hexagonal bolts, washer-assembled machine screws, and surface treatment. Add "-" after the part number of the hexagonal bolt or machine screw, and add the number shown in the table below.
NUMBER OF WASHER-ASSEMBLED HEXAGONAL BOLTS, MACHINE SCREWS, AND SURFACE TREATMENT
------Shape Classification---------- Surface Treatment    ?Material
                                                          ?characteristic
Hexagonal bolt | Backing washer No.2 No surface treatment 61
 (without split|                     Zinc plating         62
  pin hole)    |                     Black zinc plating   91
 Machine screw |                     Chrome plating       63
               |                No.3 No surface treatment 64
               |                     Zinc plating         65
               |                     Black zinc plating   92
               |                     Chrome plating       66
               | Internally     No.1 No surface treatment 67
               |  toothed            Zinc plating         68
               |  spring washer      Black zinc plating   93
               |                     Chrome plating       69
               |                No.2 No surface treatment 71
               |                     Zinc plating         72
               |                     Black zinc plating   94
               |                     Chrome plating       73
               | Externally          No surface treatment 74
               |  toothed            Zinc plating         75
               |  spring washer      Black zinc plating   96
               |                     Chrome plating       76
               | Slotted washer      No surface treatment 77
               |                     Zinc plating         78
               |                     Chrome plating       79
21st Century Format
Preliminary, I have not seen this documented, but it appears Nissan has changed the last digit to F (for Finish?)
Zinc-Cadmium        1F
Chrome coated       2F
Copper coated       3F
Phosphoric Acid     4F
Brass               5F
Copper              6F
Example: 08120-6201F replacing 08120-62010 HEX BOLT Medium Carbon Steel M6x20mm
Metric
ISO metric screw thread
Nissan models use mostly British threads until January 1967, when in the middle of the month they adopted JIS metric standards across the board, starting with the R16, H20 and H30 engines. Thereafter the metric system was "adopted for all the screw threads of engine, chassis and body of Nissan's vehicle when:"
1. Model is change.
2. New unit is adopted.
3. New model is produced.
Although some parts still remained Standard threads (e.g. R16 cylinder head bolts).
For example, 1200 wheels are still 12" by 4" with a 4.5" PCD, as befitting their English ties building Austin vehicles.
Strength
Note: Japanese Industrial Standards (JIS) metric standards were used by Nissan starting in the 1960s.
The absence of marking/number on the bolt head indicates a lower grade bolt with low strength.
CLASSmarkNES TerminologyMPaNotes
JIS 4T"low carbon steel"392no mark means 4T
JIS 7T7"high carbon steel"686exceeds Class 9.8
JIS 9T9"alloy steel"883exceeds Class 10.9
US bolts are also strength-marked on the head (referred to as the grade).
Comparison with US Bolts
GRADEmarkdescriptionMPa
Grade 2no markLow-medium carbon steel393
Grade 53 linesMedium carbon steel586
Grade 86 linesMedium carbon alloy steel827
Kind
0
1- Bolts
example: 08120-61210 BOLT
0 standardization digit (starting ~1968)
8 Nissan Engineering Section prefix
1 Bolt
2 bolt type: Hexagon bolt, #Medium carbon steel
06 #Dimension Digits: =6mm (M6)
12 #Length Digits: 12mm
10 #Suffix digits: no special finishing
2- Studs
  • 21ddLL: Stud, Low carbon steel (for cast iron)
  • 22ddLL: Stud, Medium carbon steel (for cast iron)
  • 23ddLL: Stud, Low carbon steel (for light alloy)
  • 24ddLL: Stud, Medium carbon steel (for light alloy)
  • 25ddLL:
  • 26ddLL:
3- Machine Screws
Example: 08310-41620
           31        SCREW, Pan head
             0 4     diameter M4 thread
                16   length   16 mm
                  20 chrome coated
  • 31ddLL: Machine screw, Pan head
  • 32ddLL: Machine screw, Flat head
  • 33ddLL: Machine screw, Oval head
  • 34ddLL: Machine screw, Truss head
  • 35ddLL: Machine screw, Blind head
  • 36ddLL: Machine screw, Hexagon head
4- Pointed Machine Screw
  • 41ddLL: Pan head
  • 42ddLL: Flat head
  • 43ddLL: Oval head
  • 44ddLL: Truss head
  • 45ddLL: Blind head
  • 46ddLL: Hex head
5- Other Screws
  • 51ddLL: Tapping screw, Pan head
  • 52ddLL: Tapping screw, Flat head
  • 53ddLL: Tapping screw, Oval head
  • 54ddLL: Tapping screw, Truss head
  • 57dLL: Wood screw, Round head
  • 58dLL: Wood screw, Flat countersunk head
  • 59dLL: Wood screw, Oval head
    a) pan, b) button, c) round, d) truss, e) countersunk, f) oval
6- Rivets
  • 61ddLL: Rivet, Round head
  • 62ddLL: Rivet, Flat countersunk head
  • 63ddLL: Rivet, Flat head
  • 66ddLL: Rivet, Tubular flat head
  • 67ddLL: Rivet, Tubular flat countersunk head
  • 68ddLL: Rivet, Split oval head
711 Flared Nuts
  • 7111dd Flared nut, inpe-ted
  • 7112dd Flared nut, standard
712 Connectors
  • 7121dd Connector, straight
  • 7122dd Connector, elbow
  • 7123dd Connector, elbow
72 Hose Clamps
74 Hose
  • 740lll: Hose, fuel tank
  • 742lll: Hose
example: 08740-25021 L-250
731 Clevis
  • 7311dd: Clevis, A?
  • 7312dd: Clevis, B?
  • 7313dd: Clevis, ???
840 Clevis Pins
9-11 Hex Nuts
Note: dd=#Dimension Digits e.g. 04 = M4 thread. JIS B.1181?
  • 9111dd: Hexagon nut, low carbon steel #4T
  • 9112dd: Hexagon nut, medium carbon steel
  • 9113dd: Hexagon nut, Low, low carbon steel
  • 9115dd: Hexagon nut, High, low carbon steel
  • 9116dd: Hexagon nut, High, medium carbon steel
  • 9117dd: Hexagon nut, Recess, high, low carbon steel
  • 9118dd: Hexagon nut, Recess, high, medium carbon steel
  • 9119dd: Hexagon nut, Recess, low, low carbon steel
  • 9110dd: Hexagon nut, Recess, low, high carbon steel
9-12 Lock Nuts
Self-locking nut (stopper nut)
  • 9121dd: ???
  • 9122dd: ???
  • 9123dd: Self-locking hexagon nut, N, low carbon steel
  • 9124dd: Self-locking hexagon nut, N, medium carbon steel
  • 9125dd: Self-locking hexagon nut, low, low carbon steel
  • 9126dd: Self-locking hexagon nut, low, medium carbon steel
  • 9127dd: ???
  • 9128dd: ???
9-13 Square & Wing Nuts
  • 9131dd: Nut, Square
  • 9134dd: Nut, Wing (forged)
  • 9135dd: Nut, Wing (sheet)
9-14 Hex Weld Nuts, Tapping Discs, Plate Nuts
  • 9141dd: ?
  • 9142dd: ?
  • 9143dd: Tapping Disc, A?
  • 9144dd: Tapping Disc, B?
  • 9145dd: Nut, Plate
9-15 Washers
  • 9151dd: Washer, Spring lock medium
  • 9152dd: Washer, Spring lock thick
  • 9154dd: Washer, Plain standard
  • 9155dd: Washer, Plain large
  • 9158dd: Washer, Finish
example: 08915-53810 WASHER-plain large
91 Washer
5 washer type: plain large
38 #Dimension Digits: =8mm (M8)
9-16 Tooth-lock Washers
Tooth Lock washer (shakeproof)
  • 9161dd: Washer, toothed inside ratchet (outside dia. small)
  • 9162dd: Washer, toothed inside ratchet (outside dia. large)
  • 9163dd: Washer, toothed outside ratchet
  • 9164dd: Washer, toothed 80° countersunk
  • 9165dd: Washer, toothed 90° countersunk
  • 89-166dd: Washer, ???
  • 89-167dd: Washer, ???
  • 9168dd: Washer, toothed both side ratchet
9-17, 9-19 Nut Retainers
  • 9171dd/89-191dd: Nut retainer, Both shanks round hole
  • 9172dd/89-192dd: Nut retainer, One shank round hole
  • 9173dd/89-193dd: Nut retainer, Both shanks long hole
  • 9174dd/89-194dd: Nut retainer, One shank long hole
  • 9195dd: ????
9-2 Pin & Key
  • 921dLL: Cotter pin
    • 6 Semicircular key
    • 8 Parallel key
older Nissan numbering:
  • (00)921dLL: Cotter pin (example: 009211200-21810)
  • (00)926-dll00: Woodruff key (example: 00926-51600)
9-31 Thread Plugs
Note: dd=#Dimension Digits e.g. 12 (or 42, 62, 72) = M12 thread
  • 9311dd: Plug, threaded, square head taper thread
  • 9312dd: Plug, threaded, square hole taper thread
  • 9312dd: Plug, threaded, recessed taper thread
  • 9313dd: Plug, threaded, hex head taper thread
  • 9314dd: Plug, threaded, hex head parallel thread
9-32 Grease Nipples
  • 9321dd: Grease nipple, Straight
  • 9322dd: Grease nipple, 67.5°
  • 9323dd: Grease nipple, 90°
9-4 Electric Parts
  • 94*1dd: Electric parts
9-5 Rubber Parts
  • 95*1dd: Rubber Grommet
9-6 Spring Nuts
  • 9631dd: Spring nut, A1 type
  • 9632dd: Spring nut, A2 type
  • 9641dd: Spring nut, B type
  • 9651dd: Spring nut, C type
  • 9661dd: Spring nut, D1 type
  • 9662dd: Spring nut, D2 type
  • 9663dd: Spring nut, D3 type
  • 9664dd: Spring nut, D1 type
9-61 Push-on Spring Nuts
  • 9611dd: Spring nut, push-on, A1 type
  • 9612dd: Spring nut, push-on, A1 type
  • 9613dd: Spring nut, push-on, B type
  • 9614dd: Spring nut, push-on, C type
Dimension Digits
Distinction by alias dimension of diameter or width. Each number may be either a size, inch dimension or metric dimension.
DD = width or diameter
Dimension Digits Size Imperial Metric
01 (or 31, 51, 61) #1 1/16" 1mm
02 (or 32, 52, 62) #2 2mm
03 (or 33, 53, 63) #3 3/32" 3mm
04 (or 34, 54, 64) #4 7/64" 4mm
05 (or 35, 55, 65) #5 1/8" 5mm
06 (or 35, 55, 65) #6 n/64" 6mm
07 (or 36, 56, 66) 3.5mm
08 (or 38, 58, 68) #8 5/32" 8mm
09 (or 39, 59, 69) #9 9mm
10 (or 40, 60, 70) #10 3/16" 10mm
12 (or 42, 62, 72) #12 7/32" 12mm
13 (or 43, 63, 73) #13 13mm
14 (or 44, 64, 74) #14 1/4" 14mm
15 (or 45, 65, 75) #15 5/16" 15mm
16 (or 46, 66, 76) #16 3/8" 16mm
17 (or 47, 67, 77) #17 7/16"
18 (or 48, 68, 78) #18 1/2" 18mm
19 (or 49, 69, 79) #19 9/16"
20 (or 50, 70, 80) #20 5/8" 20mm
22 (or 52, 72) #22 3/4" 22mm
24 (or 54, 74) #24 7/8" 24mm
26 (or 56, 76) #26 1"
28 (or 58, 78) #28 1-5/8"
Length Digits
長さによる区分
LL digits = Length
Early form: n-nnnLL (likely to be imperial)
Transition form: nn-nnnLL
1970s form: nnnnn-nLLnn (likely to be metric)
Datsun fasteners started out using imperial dimensions (British thread standard). But more and more during the 1960s Datsun used some Metric fasteners, until starting in 1967 nearly all parts were changed to metric. Lastly, the flywheel bolts changed to metric in 1973. Only the oil sender threads continued to use BPT.
Metric LL digits
04 4mm
95 95mm
Imperial LL digits
07 1/4 inch
10 3/8
13 1/2
16 5/8
19 3/4
22 7/8
26 1 inch
28 1-1/8
32 1-1/4
35 1-3/8
38 1-1/2
41 1-5/8
44 1-3/4
48 1-7/8
51 2 inch
54 2-1/8
57 2-1/4
64 2-1/2
70 2-3/4
76 3 inch
NOTE: Bolt length does not include the head
174_5c9af300f08c4.pngPost 491017
Suffix
For parts that have surface finishing or cotter pin hole, symbols showing these proceedings are added at the end of the part number.
Two digits mean it has a cotter pin hole. Single digit: No cotter pin hole.
  • 1: Zinc cadmium coated
  • 2: Chrome coated
  • 3: Copper coated
  • 4: Phosphoric acid coated
  • 5: Brass
  • 6: Copper
With Cotter Pin Hole
  • 10: surface not processed
  • 11: Zinc cadmium coated
  • 21: Chrome coated
  • 31: Copper coated
  • 41: Phosphoric acid coated
  • 51: Brass
  • 61: Copper
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=NES_Part_Numbers"
This page has been accessed 80,948 times. This page was last modified 02:59, 25 July 2025. Content is available under Datsun 1200 Club.
