Horn
Revision as of 22:38, 1 May 2015; view current revision
Datsun 1200 used dual horns. It also uses a three-connector relay, which is bolted to the right-side strut tower just below the ignition coil.
#3: horn relay
Horn wiring schematic: 14974.jpg
Relay Wire Colors
  • Green - to horns
  • Green/white - to 15A fuse in fuse box, Battery side
  • Black/green - to steering column connector (for horn button)
  • Case bolts to body (earth/ground)
Early Relay
Stamped on the relay case are:
* H - connector for Horns
* B - connector for Battery (through fuse box)
* S - connector for Switch (in steering wheel)
Late Relay 26321-G1600 7510-
  • 26310-H1000 ASS'Y-HORN, high ALL (exc. Coupe)
  • 26310-H1800 ASS'Y-HORN, high, sports Coupe, GX
  • 26330-H1000 ASS'Y-HORN, low DX (exc. Coupe)
  • 26330-H1800 ASS'Y-HORN, low, sports Coupe, GX
  • 26320-14800 RELAY-horn
    • 83-10510-14 SCREW (fixing horn relay)
