Datsun 1200 originally fitted with automatic transmission has a much larger tunnel. It makes it easier to swap in 5-speeds or larger engines.
manual transmission
- 67300-H1000 ASS'Y-PANEL, dash, lower [manual transmission]
- 74300-H1010 ASS'Y-FLOOR, front [manual transmission]
- 67300-H1021 ASS'Y-PANEL, dash, lower [automatic transmission]
- 74306-H1020 ASS'Y-PANEL, A/T floor cover, front [automatic transmission]
- 74300-H1021 ASS'Y-FLOOR, front [automatic transmission]
Manual floor cover (normally not a separate piece) vs auto floor cover
Comparo
Auto Tunnel retrofit - can be welded into manual transmission floor & firewall:
Manual Tunnel is very small to fit the small stock transmissions and increase space inside the passenger compartment:
Photo showing where to cut the tunnel to fit a standard "short" L-series or CA-series transmission.
S13 gearbox clearance in manual tunnel
Reverse Lamp
To fit a 60-Series Transmission 5-speed, move the mounts 115mm back:
See Also
Also see: Transmission tunnel Photo Index
