Front
Bonnet moulding (grille surround)
Also see [[Sedan Grille]
Glass
See main article: Glass
Side Moulding
Beltine
Trim down the body crease are popular on coupes, but I think it was dealer installed.
Rocker Panel
Early-style Body sill moulding trim
Note moulding clips
Japan 76880-H3100 MOULDING-body sill 2 (exc. STD) (from '72-4) 76880-H1000 MOULDING-body sill 2 (exc. STD) (fixing sill moulding) 76486-H1000 RETAINER-sill moulding 4 [bolt] 76488-21600 CLIP-moulding 6 [spring metal] 01221-00033 NUT 4 (replaced) 89-11106-1 NUT 4 89-15136-1 WASHER-lock 4 89-15436-1 WASHER-plain 4
USA 76880-H1000 MOULDING-BODY SILL 2 -0372 76486-H1000 RETAINER-SILL MOULDING 4 08911-10610 NUT-HEX M6 4 08915-13610 WASHER-SPRING LOCK 4 08915-43610 WASHER-PLAIN 4 76880-H3100 COMP-BODY SILL MOULDING 2 0472- 76486-N1600 BOLT-SILL MOULDING 4 01221-00033 NUT-HEX M6 TO FIX SILL MOULDING W/W 4 76488-21600 CLIP-SILL MOULDING 6
- One retainer at each end
- Three spring-clips in between (six per car)
Rear Moulding
Boot
モール モールデイング
