Moulding
Revision as of 06:21, 10 January 2012; view current revision
Category: Body & Trim
Body
Front
Bonnet moulding (grille surround)
Also see [[Sedan Grille]
Glass
See main article: Glass
Side Moulding
Beltine
Trim down the body crease are popular on coupes, but I think it was dealer installed.
Rocker Panel
Early-style Body sill moulding trim
Note moulding clips
76880-H3100 MOULDING-body sill 2 (exc. STD) (from '72-4)
76880-H1000 MOULDING-body sill 2 (exc. STD)
 (fixing sill moulding)
 76486-H1000 RETAINER-sill moulding 4 [bolt]
 76488-21600 CLIP-moulding 6 [spring metal]
 01221-00033 NUT 4
  (replaced)
  89-11106-1 NUT 4
  89-15136-1 WASHER-lock 4
  89-15436-1 WASHER-plain 4
76880-H1000 MOULDING-BODY SILL 2 -0372
 76486-H1000 RETAINER-SILL MOULDING 4
 08911-10610 NUT-HEX M6 4
 08915-13610 WASHER-SPRING LOCK 4
 08915-43610 WASHER-PLAIN 4
76880-H3100 COMP-BODY SILL MOULDING 2 0472-
 76486-N1600 BOLT-SILL MOULDING 4
 01221-00033 NUT-HEX M6 TO FIX SILL MOULDING W/W 4
76488-21600 CLIP-SILL MOULDING 6
Later-style Moulding
  • One retainer at each end
  • Three spring-clips in between (six per car)
Rear Moulding
Boot
モール モールデイング
