Cylinder Heads
Revision as of 03:41, 1 December 2011; view current revision
Heads may be grouped by engine size, however be aware that the exact same heads were used by various size engines. For example, all A15 engines used heads that were designed for A14 engines.
A10
A10 engines were used by the B10 "Datsun 1000" and the E10 Nissan Cherry.
The late A10 head was used by some A12 engines.
180 Type
11041-18002 ASS'Y-HEAD cylinder B10
11041-18001 ASS'Y-HEAD cylinder B10
11041-H0100 ASS'Y-HEAD cylinder B10
H10 Type
11041-H1001 ASS'Y-HEAD cylinder from '70-april B10
B10 Coupe Type
11041-25701 ASS'Y-HEAD cylinder B10 Coupe
11041-25700 ASS'Y-HEAD cylinder B10 Coupe
11041-H0300 ASS'Y-HEAD cylinder B10 Coupe
Nissan Cherry Type
11041-M0100 HEAD ASSY-cylinder A10 E10
11041-M0101 HEAD ASSY-cylinder A10 (from '72-1) E10
11041-M0102 HEAD ASS'Y-cylinder A10 (from '73-3) E10
A12
A12A
A12A engines came from B310 USA & N10 JDM.
A12A heads were also used on A14 & A15 engines.
728 Type B310 USA & CAN
11041-H7285 CYLINDER HEAD ASSY
11041-H7284 CYLINDER HEAD ASSY
11041-H7283 CYLINDER HEAD ASSY
11041-H7282 CYLINDER HEAD ASSY
991 Type B310 CAL
11041-H9913 CYLINDER HEAD ASSY A12 CAL 0880-
H85 Type N10 JDM
11041-H8500 HEAD ASSY-CYLINDER A12AS 11041-H8501 N10 JDM
11041-H8501 HEAD ASSY-CYLINDER A12AS 11041-H8503 N10 JDM
11041-H8503 HEAD ASSY-CYLINDER A12AS N10 JDM
A13 1974
H62 Type USA B210 1974
11041-H6200 ASSY-HEAD CYLINDER A13
11041-H6201 ASSY-HEAD CYLINDER A13
11041-H6202 ASSY-HEAD CYLINDER A13
A13 1980
For JDM B310 sedans & coupe, the A13S replaced the A12S November 1980. B310 Vans kept using the A12.
11041-H8503 HEAD ASSY-CYLINDER JDM B310 A13S 8011-
A14
A14 heads were also used by A15 models and (some) A12A models. Some A14 heads were used on the A12 from the Datsun 1200 Truck.
G32 Type
11041-G3202 HEAD ASSY-CYLINDER JDM B310,A10,N10 V.A14S 7910-8010
11041-G3203 HEAD ASSY-CYLINDER JDM B310 V.A14S 8011-
H720 Type
11041-H7200 ASSY-HEAD CYLINDER USA B210 -1175
11041-H7201 ASSY-HEAD CYLINDER USA B210 0776-0876
H726 Type
11041-H7261 ASSY-HEAD CYLINDER USA B210 0876-0777
H728 728 Type
11041-H7281 ASSY-HEAD CYLINDER B210 (FED)(GFU) 1276-0578
* also CAN B210 0877-0578
11041-H7282 ASSY-HEAD CYLINDER B210 (FED)(GFU), CAN 0678-
* also A14 B310 CAN, FED (KFU) -0778
11041-H7283 ASSY-HEAD CYLINDER B210 (FED)(GFU), CAN
* also B310 CAN, FED (KFU) 0878-1078
11041-H7284 CYLINDER HEAD ASSY B310 CAN 1178-0780
* also B310 FED (KFU) 1178-0779
11041-H7285 CYLINDER HEAD ASSY B310 CAN, FED (KFU) 0678-0678
H75 Type -- marked 'H72' on casting?
11041-H7500 HEAD ASSY-CYLINDER JDM B310 A14S V
11041-H7502 HEAD ASSY-CYLINDER JDM A10 A14S.S,K -7803
* also JDM F10 A14S
H77 Type
11041-H7760 ASSY-HEAD CYLINDER USA B210 0877-0578
11041-H7761 ASSY-HEAD CYLINDER USA B210 0678-
* also B310 FED (EXC KFU) -0778
11041-H7762 ASSY-HEAD CYLINDER USA B210
* also B310 FED (EXC KFU), N10 FED 0878-0779
11041-H7763 CYLINDER HEAD ASSY B310 FED (EXC KFU)
H786 (786) Type
11041-H7860 HEAD ASSY-CYLINDER JDM B310.V
11041-H7861 HEAD ASSY-CYLINDER JDM B310.V, A10.V N-7806
11041-H7863 HEAD ASSY-CYLINDER JDM B310.V, A10.V, N10.V 7807-7909
H87 - FED only
11041-H8700 CYLINDER HEAD ASSY FED 0880-
H89 Type
11041-H8900 HEAD ASSY-CYLINDER JDM B310 S,K.A14S 7811-7903
* also JDM A10 A14S.S,K 7804-7906
11041-H8901 HEAD ASSY-CYLINDER JDM B310 S,K.A14S 7811-7903
11041-H8902 HEAD ASSY-CYLINDER JDM A10.S,K, N10 7907-8003
11041-H8904 HEAD ASSY-CYLINDER JDM B310 S,K.A14S 7904-8010
* also JDM A10 A14S.S,K 8004-
H990 (990) Type - FED
11041-H9902 CYLINDER HEAD ASSY FED 0880-
11041-H9901 CYLINDER HEAD ASSY FED 0879-0780
H991 (991) Type - CAL B310 & N10
11041-H9913 CYLINDER HEAD ASSY CAL -0578
11041-H9911 CYLINDER HEAD ASSY CAL 0879-0780
H916 (916) Type - CAL B310 & N10
11041-H9164 CYLINDER HEAD ASSY CAL 0879-
11041-H9163 CYLINDER HEAD ASSY CAL 1178-0779
11041-H9162 CYLINDER HEAD ASSY CAL 0878-1078
11041-H9161 CYLINDER HEAD ASSY CAL -0778
H92 Type - for EGI
11041-H9200 HEAD ASSY-CYLINDER B310,N10 JDM A14E N-7810
11041-H9201 HEAD ASSY-CYLINDER B310 JDM A14E 7811-7903
11041-H9202 HEAD ASSY-CYLINDER B310,N10 JDM A14E 7904-7907
11041-H9204 HEAD ASSY-CYLINDER B310,N10 JDM A14E 7908-8010
M24 [dual-spring, otherwise standard A14 type]
11041-M2460 HEAD ASSY-CYLINDER A14T JDM B210 & F10
M49 Type
11041-M4900 B-210 1975-1976 USA B210 & USA F10 1976
A15
All A15 engines used cylinder heads that were designed for A14 engines. In other words, there is no specific "A15" head.
