Block
Revision as of 11:10, 7 January 2012; view current revision
See:
 B110 RAW LIST
11010-H2300	ASSY-BLOCK,CYLINDER
11010-H1000	ASSY-BLOCK CYLINDER
12293-18001	BOLT FIXING BEARING CAP 1
11019-32200	PLUG-WELCH 44 CAM BEARING
00933-13500	PLUG-WELCH 35 CORE HOLE
01648-00084	PLUG-WELCH 35 CORE HOLE
00933-15000	PLUG-WELCH 50 CORE HOLE
11021-13200	PLUG-TAPER 12.7 OIL GALLERY
11024-K0100	PLUG-TAPER 12.7 OIL GALLERY
00933-20650	PLUG-TAPER 6 OIL GALLERY
01647-00011	PLUG-TAPER 6 OIL GALLERY
11046-73402	DOWEL-TIMING 5 FRONT COVER
11023-32200	DOWEL-TIMING 5 FRONT COVER
30412-21000	DOWEL-TIMING 9.5 CASE LOCATING
08213-82810	STUD-FIXING FUEL PUMP
08213-84810	STUD FIXING WATER PUMP
08213-84510	STUD FIXING WATER PUMP
08223-81610	STUD FIXING ENGINE MOUNTING BRACKET
12279-18000	SEAL-OIL CRANKSHAFT REAR
12279-18010	SEAL-OIL CRANKSHAFT REAR (NDK)
12279-H1000	SEAL-OIL CRANKSHAFT REAR (NOK)
21045-18000	PIPE-SUCTION WATER PUMP
08931-30410	PLUG-TAPER THRED WATER DRAIN
11037-H1000	NET-STEEL CRANK CASE
11038-H1000	PLATE-BAFFLE CRANK CASE
08310-61214	SCREW-MACHINE
10005-H1000	SLINGER-ENGINE FRONT
08110-8161B	BOLT-HEX M8
08110-81611	BOLT-HEX M8
