Also see: Part Numbers Index Main articles for usage, photos, cross-reference: Wiring Wiring Harness Battery
1 24012-H7000 HARNESS-ENGINE ROOM MANUAL 0772- 0 24012-H2102 1 24012-H7005 HARNESS-ENGINE ROOM AUTOMATIC 0772- 0 24012-H2112 1 24012-H2112 HARNESS-ENGINE ROOM AUTOMATIC 0172- 0 24012-H2111 1 24012-H2111 HARNESS-ENGINE ROOM AUTOMATIC 0671- 0 24012-H2118 1 24012-H7001 HARNESS-ENGINE ROOM MANUAL 0372- 0 24012-H7000 1 24012-H2102 HARNESS-ENGINE ROOM MANUAL 0172- 0 24012-H2101 1 24012-H2101 HARNESS-ENGINE ROOM MANUAL 0671- 0 24012-H2108 1 24012-H2108 HARNESS-ENGINE ROOM MANUAL 0471-0571 10 24012-H1900 1 24012-H1900 HARNESS-ENGINE ROOM MANUAL 1 24012-H2118 HARNESS-ENGINE ROOM AUTOMATIC 2 24013-H1905 HARNESS-INSTRUMENT MANUAL 2 24013-H2118 HARNESS-INSTRUMENT 0471- 2 24013-H2112 HARNESS-INSTRUMENT AUTOMATIC 0771- 0 24013-H2118 2 24013-H7000 HARNESS-INSTRUMENT AUTOMATIC 0772- 0 24013-H2112 3 24014-H1011 HARNESS-BODY SEDAN 3 24014-H1811 HARNESS-BODY COUPE 4 24015-H1900 HARNESS-TAIL SEDAN 4 24015-H7000 HARNESS-TAIL SEDAN 1272- 0 24015-H1900 4 24015-H1910 HARNESS-TAIL COUPE 5 24272-H1000 PROTECTOR-WIRING SEDAN 6 24039-H1900 ASSY-CABLE HAND BRAKE SWITCH 7 24150-H1020 ASSY-CABLE INDICATOR LAMP AUTOMATIC -671 1 8 24250-89927 GROMMET SEDAN 9 24029-H1400 CABLE-TANK UNIT COUPE 10 24220-89937 CLIP FIXING TO BODY SIDE INNER COUPE 11 24220-89953 CLIP FIXING TO REAR COMB LAMP COUPE 12 25442-H1100 LINK-FUSIBLE,TYPE C 12 25442-H2500 LINK-FUSIBLE,TYPE C 0471- 0 25442-H1100 13 24110-H1600 CABLE-BATTERY(+) 13 24110-H1605 CABLE-BATTERY (+) 0 24110-H1600 13 24110-H1900 CABLE-BATTERY(+) COUPE 2 24110-H1605 14 24080-H1900 CABLE-BATTERY(-) 15 24160-H1100 CABLE-ROOM LAMP DX 16 24100-H1600 CABLE-FOG LAMP 17 24163-H1900 CABLE-HEAT GLASS D OP 1270- 18 24220-89931 CLIP-CABLE OP 1270- 19 24161-H2200 CABLE-HEAT GLASS A OP.COUPE 1270- 19 24161-H1900 CABLE-HEAT GLASS,A OP.SEDAN 20 24162-H2200 CABLE-HEAT GLASS B OP 1270- 21 24163-H2200 CABLE-HEAT GLASS C OP.COUPE 22 24163-H2000 CABLE-HEAT GLASS OP.SEDAN 23 24338-H4600 CABLE-SEAT BELT WARNING MANUAL 0772- 2 24110-H1600 23 24338-H7005 CABLE-SEAT BELT WARNING AUTOMATIC 0772- 23 24338-H4600 CABLE-SEAT BELT WARNING 0172-
