<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Camshaft Valves Rocker Shaft Timing Chain Push Rods
1 13001-H7000 ASSY-CAMSHAFT A12 0772- 0 13001-H2300 1 13001-H1000 CAMSHAFT A12 2 11023-78200 PLUG-TAPER A12 3 13032-18000 DOWEL-CAMSHAFT GEAR A12 4 13010-18001 PLATE-CAMSHAFT A12 08110-6161A BOLT-FIXING CAMSHAFT PLATE (2) A12 01111-00022 5 01111-00022 BOLT-FIXING CAMSHAFT PLATE (2) A12 08915-1361A WASHER-LOCK FIXING CAMSHAFT PLATE (2) A12 08915-13610 6 08915-13610 WASHER-LOCK FIXING CAMSHAFT PLATE (2) A12 13024-H8500 SPROCKET-CAMSHAFT A12 13024-18001 7 13024-18001 SPROCKET-CAMSHAFT A12 8 13082-18000 BOLT-CAMSHAFT SPROCKET A12 9 13030-18000 WASHER-CAMSHAFT A12 08915-2401A WASHER-LOCK A12 08915-14010 10 08915-14010 WASHER-LOCK A12 11 13028-18001 CHAIN-CAMSHAFT A12 12 13070-18001 ASSY-TENSIONER CHAIN A12 13 08120-63510 BOLT-FIXING CHAIN TENSIONER (2) A12 14 08915-13610 WASHER-LOCK FIXING CHAIN TENSIONER (2) A12 15 13201-H1000 VALVE-INTAKE (4) A12 16 13202-H1000 VALVE-EXHAUST (4) A12 17 13203-H1000 SPRING-VALVE OUTER (8) A12 18 13205-18000 SEAT-VALVE SPRING (8) A12 19 13209-H2302 RETAINER-VALVE SPRING (8) A12 0772- 0 13209-H2301 19 13209-18000 RETAINER-VALVE SPRING (8) A12 19 13209-H2300 RETAINER-VALVE SPRING (8) A12 2 13209-18000 19 13209-H2301 RETAINER-VALVE SPRING (8) A12 0670-0672 2 13209-H2300 20 13210-73400 COLLET-VALVE 1 (16) A12 20 13210-H1000 COLLET-VALVE 1 (16) A12 0272- 0 20 13210-U0100 COLLET-VALVE 1 (16) A12 1072- 2 13210-H1000 21 13207-18000 SEAL-OIL VALVE (INTAKE ONLY) (8) A12 -672 21 13207-H2301 SEAL-LIP VALVE OIL (INTAKE ONLY,KEEPER) (4) OP A12 2 13207-H2300 21 13207-H2310 SEAL-LIP,VALVE,OIL (INTAKE ONLY,NOK) (4) OP A12 22 13219-H1000 SHROUD-VALVE INNER (8) A12 0772- 2 13207-18000 22 13219-H1000 SHROUD-VALVE INNER,FOR TROPICAL REG (8) OP A12 23 13252-18000 ASSY-SHAFT & VALVE ROCKER A12 24 13254-58000 PLUG-EXPANSHION ROCKER SHAFT (2) A12 25 13256-18000 SPRING-INSIDE ROCKER SHAFT (4) A12 26 13222-18001 BRACKET-ROCKER SHAFT (5) A12 27 13224-18000 BOLT-ROCKER SHAFT (5) A12 28 08915-43810 WASHER-PLAIN (5) A12 29 13257-18003 ROCKER-VALVE NO.1 (4) A12 13257-18001 29 13257-18001 ROCKER-VALVE NO.1 (4) A12 30 13258-18003 ROCKER-VALVE NO.2 (4) A12 13258-18001 30 13258-18001 ROCKER-VALVE NO.2 (4) A12 31 13234-18000 SCREW-ADJUSTING ROCKER VALVE (8) A12 32 13288-18001 NUT-ADJUSTING ROCKER VALVE (8) A12 33 13231-H1000 LIFTER-VALVE (8) A12 33 13231-H1001 LIFTER-VALVE (8) A12 13231-H1000 34 13238-H1001 ROD-PUSH (8) A12 1070- 2 13238-H1000 34 13238-H1000 ROD-PUSH (8) A12
1973 LB110 USA Parts Catalog
