Also see:
Part Numbers Index Main article for usage, photos, cross-reference Throttle Cable Choke Cable Accelerator Pedal
1 18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC 1 18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL 2 18100-H1602 ASSY-ARM ACCELERATOR PEDAL MANUAL 2 18100-H1902 ASSY-ARM ACCELERATOR PEDAL AUTOMATIC 3 18017-H1600 PAD-ACCELERATOR PEDAL 4 18021-H1600 BRACKET-ACCELERATOR PEDAL 5 18215-H1600 SPRING-RETURN ACCELERATOR 5 18215-H1601 SPRING-RETURN ACCELERATOR 1070- 2 18215-H1600 6 18137-10600 RING-SNAP E TYPE 7 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX (3) 8 18056-H1600 BOLT-PEDAL STOPPER 9 08911-30610 NUT-HEX M6 FOR PEDAL STOPPER 10 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER 11 18036-18000 SPRING-CLAMP ACCELERATOR WIRE A8200-G1300 ASSY-WIRE ACCELERATOR 18200-H1600 12 18200-H1600 ASSY-WIRE ACCELERATOR 13 18410-H1601 COMP-WIRE CHOKE CONTROL 13 18410-H1602 COMP-WIRE CHOKE CONTROL 2 18410-H1601 14 18415-H1000 ASSY-KNOB CHOKE CONTROL 14 18415-H1001 ASSY-KNOB CHOKE CONTROL SEDAN & COUPE 0171- 2 18415-H1000 15 00951-10400 GROMMET
