Tension Rod, also known as compression rod, strut rod, or caster/castor rod. Sometimes called a radius rod or reaction rod.
The tension rods keep the front wheels located fore/aft. It forms one leg of the virtual lower A-arm. The LCA forms the other leg of the "A".
1974 and later tensions rods have a different bolt spacing at the end, to match the updated bolt pattern on the 1974 and later LCAs.
The tension rod is the lower bar in this photo:
Red poly bushings for a stiffer ride
- 54470-H1000 ROD-TENSION FRONT SUSPENSION RH
- 54471-H1000 ROD-TENSION FRONT SUSPENSION LH
- 54470-H7200 Tension rod R.H 1974 to 7910
- 54470-H8500 Tension rod R.H 7911-
54472-18000 WASHER-SPECIAL TENSION ROD -7910 54472-H8500 WASHER-THRUST TENSION ROD 7911- 54630-H1001 COLLAR-BUSH TENSION ROD 08915-44210 WASHER-PLAIN M12 08912-34210 NUT-HEX SELF LOCK M12
Also see Ball Joints for the two bolts that fix the Tension Rod to the ball joint & LCA.
Bushes
- 54476-W5000* Tension rod bushing (2 per side) $2.73
- formerly 54476-H1001
- MCQUAY-NORRIS FA1320
- RAYBESTOS 5781039
- ACDELCO 45G25039 or 88913237 $4.70
JAPAN Early B210 54474-H5000 ROD ASS'Y-tension, front suspension (R.H.) 54475-H5000 ROD ASS'Y-tension, front suspension (L.H.) Late B210 Van 1075-, sedan/coupe 1275- 54474-H7400 ROD ASS'Y-tension, front suspension (R.H.) 54475-H7400 ROD ASS'Y-tension, front suspension (L.H.) 54472-18000 WASHER-special, tension rod (4) 54630-H1001 COLLAR-bush, tension rod (4) 54476-H1001 BUSH-tension rod (4) 08915-44210 WASHER-plain (2) 08912-34210 NUT (2)
NORTH AMERICA (HLB210, fits PB210 LCA) 54474-H5900 ASSY-ROD,TENSION RH 54475-H5900 ASSY-ROD,TENSION LH 54537-21003 WASHER-SPECIAL (4) 54479-21000 COLLAR-BUSH TENSION ROD (2) 54476-21000 BUSH-TENSION ROD (4) 08915-54210 WASHER-PLAIN (2) 08912-34210 NUT-SELF LOCK TYPE N M12 (2)
B310
54470-H8500 ROD-TENSION,FRONT SUSPENSION RH 54471-H8500 ROD-TENSION,FRONT SUSPENSION LH 54472-H8500 WASHER-SPECIAL TENSION ROD TO BRACKET (4) 54630-H1001 COLLAR-BUSH,TENSION ROD TO BRACKET (2) 54476-W5000 BUSH-TENSION ROD TO BRACKET (4) 08915-44210 WASHER-PLAIN (2) 08912-34210 NUT-HEX,SELF LOCK TYPE (2)
Body brackets, which are welded to the front side member (front rail)
74830, 74831 54532-H1001 BRACKET-SUSPENSION ROD, RH 54533-H1001 BRACKET-SUSPENSION ROD, LH
Custom Rods
For custom or adjustable rods, including Nissan Competition, see main article: Custom Caster Rods
