Main : Members : PIGDOG adjustable front end stuff
[<   Previous  55  56  57  58  59  60  61  Next   >]
adjustable front end stuffPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2008/1/23 3:54    Tell a friendTell a friend
Hits4674  Comments16    0.00 (0 votes)0.00 (0 votes)
late ute control arms modded to be adjustable with modded corrona/torago castor rods
retrorally
Posted: 2008/1/23 22:45  Updated: 2008/1/23 22:45
 Re: adjustable front end stuff
"to get the desired camber you are allowed to redrill the LCA mounting point up to 40? -45mm?(id have to look it up) in the crossmember"
You would have to be a bit careful with this one, moving the hole out to get your camber will cause bumpsteer. Moving directly up and down will affect your roll centre (mechanical stiffness for want of a simple explanation).
I have not had a lot to do with adjustable strut tops but wonder how much camber you can acyually gain by using these over the standard strut tops.
Does ant one know?
R-fastmotorsport
Posted: 2008/1/23 23:42  Updated: 2008/1/23 23:42
My 2 bob,
Standard Stanza bottom arms, redrilled crossmember (only about 20mm from memory) and noltec adjustable tops got me about 4 - 4.5 deg neg camber. Castor about 4 - 5 deg with rethreaded stanza LCA.
Couldn't achieve the above before the coil over setup went in but now all is well with correct ride height. No "5 minute" job though !!
Cheers
WhiteSedan
Posted: 2008/1/23 12:19  Updated: 2008/1/23 12:19
Cheers for that, i didnt think I could. I'll only be doing supersprints and hillclimbs in the meantime anyway so all will be good for now.
WhiteSedan
Posted: 2008/1/23 8:13  Updated: 2008/1/23 8:13
Nice work, the castor rods look about the same diameter as my torana ones. Can i ask how the castor rods are modded to fit the datsun balljoint pattern? Are they adjustable from factory? My ke20 corolla stuff was like that with a small tack weld to stop them self adjusting.
PIGDOG
Posted: 2008/1/23 8:22  Updated: 2008/1/23 8:22
they were fairly adjustable from factory, but i found the right size tap(or die, which ever it is) so added more thread for the hell of it
had to cut the end off after the first bolt hole and weld it back on so that the second bolt hole lined up with the other one on the control arm
oh and the rod is about 18-19mm thick
sunny_L18
Posted: 2008/1/23 8:26  Updated: 2008/1/23 8:26
did the get the general idea on how to do it from the stuff i had for sale ??
bert
Posted: 2008/1/23 10:11  Updated: 2008/1/23 10:11
And it's even legal for I.P.R.A. cause you hav'nt moved the pick up points(and it's called a die)on the chassis.
sikyne
Posted: 2008/1/23 12:02  Updated: 2008/1/23 12:02
Looks very good.
Not IPRA legal tho, have to run elastometric bush in standard lower control arm(no rod ends) and caster rod has to be original item.
A job well done, it would be perfect for a club sprint car.
WhiteSedan
Posted: 2008/1/23 12:08  Updated: 2008/1/23 12:08
I haven't got this years cams book, I dont think I can but can I run my adjustable lower control arms in IPRA, they have nolathane bushings? They will be good for the next two years anyway before I have enough cash and experience to run IPRA.
sikyne
Posted: 2008/1/23 12:15  Updated: 2008/1/23 12:15
Unfortunatly not,
to get the desired camber you are allowed to redrill the LCA mounting point up to 40? -45mm?(id have to look it up) in the crossmember.
converted
Posted: 2008/1/24 2:56  Updated: 2008/1/24 2:56
no you cant run anything else other than stock lower arms, silly rule
bert
Posted: 2008/1/23 21:23  Updated: 2008/1/23 21:23
What was i thinking?I stand corrected on the rod ends,however you would get away with the caster rod,cause it is original is'nt it??? eh,well?
dongdong0507
Posted: 2008/1/23 4:14  Updated: 2008/1/23 4:14
look nice! i wanna find these stuff also, but quite hard to get in Malaysia. the castor rod is custom made one?
subwoffers
Posted: 2008/1/23 4:26  Updated: 2008/1/23 4:26
The red rubber bushings, what are they called?
Mine have gone all hard and dry.
1200rallycar
Posted: 2008/1/23 5:10  Updated: 2008/1/23 5:10
called: castor rod bushes
