DCH Carburetor Part Numbers
Revision as of 11:03, 22 August 2016; view current revision
Categories: Engine Mechanical | Catalog
<-- back to Part Numbers Index
Also see:
Main article for usage, photos, cross-reference
Carburetor
From June 1971 with Auto Choke
1 16010-H3901 ASSY-CARBURETOR (DCH306-1A) MANUAL 2 16010-H3900
1 16010-H3902 ASSY-CARBURETOR (DCH306-1B) MANUAL -672 2 16010-H3901
1 16010-H7000 ASSY-CARBURETOR (DCH306-4) MANUAL 0772- 0 16010-H3902
1 16010-H3920 ASSY-CARBURETOR (DCH306-3) AUTO
1 16010-H3921 ASSY-CARBURETOR (DCH306-3A) AUTO 2 16010-H3920
1 16010-H3922 ASSY-CARBURETOR (DCH306-3B) AUTO -672 2 16010-H3921
1 16010-H7100 ASSY-CARBURETOR (DCH306-5) AUTO 0772- 0 16010-H3900
1 16010-H3900 ASSY-CARBURETOR (DCH306-1) MANUAL
2 16011-H7011 ASSY-CHAMBER,CHOKE MANUAL 0772- 0 16011-H3910
2 16011-H3920 ASSY-CHAMBER,CHOKE AUTO -672
2 16011-H3910 ASSY-CHAMBER,CHOKE MANUAL -672
2 16011-H7111 ASSY-CHAMBER,CHOKE AUTO 0772- 0 16011-H3920
3 16182-H3920 POT-DASH AUTO
4 16302-H3910 LEVER-PUMP
5 16258-H3920 HOLDER-DASH POT AUTO
6 16143-H3910 ROD-PUMP
7 16262-H3910 DIAPHRAGM-SERVO
8 16118-H3910 ASSY-CHAMBER,THROTTLE
8 16118-H3911 ASSY-CHAMBER,THROTTLE -672 2 16118-H3910
8 16118-H7011 ASSY-CHAMBER,THROTTLE 0772- 0 16118-H3911
9 16145-91460 SPRING-IDLE ADJUST SCREW
10 16145-50000 SPRING-THROTTLE ADJUST SCREW
11 16129-25710 SCREW-THROTTLE ADJUST
11 16129-25715 SCREW-THROTTLE ADJUST -672 2 16129-25710
11 16114-H7010 SCREW-THROTTLE ADJUST 0772- 0 16129-25715
12 16144-M0110 SCREW-IDLE ADJUST -672
12 16144-H7010 SCREW-IDLE ADJUST 0772- 0 16144-M0110
13 16147-E6600 CAP-IDLE LIMITTEY 1070-0672
14 16082-H3910 PLATE-ADJUST -672
14 16082-H7010 PLATE-ADJUST 0772- 0 16082-H3910
15 16116-H3910 SLEEVE(B)
16 16128-H3910 LEVER-FIRST IDLE
17 16249-H3910 LEVER-OPENER
18 16389-H7010 COVER-THERMO 0772- 0 16389-H3910
18 16389-H3910 COVER-THERMO -672
19 16267-H3910 PIPE-VACUUM MANUAL
19 16267-H3920 PIPE-VACUUM AUTO
20 16161-H1911 HANGER-SPRING MANUAL -672
20 16161-H7010 HANGER-SPRING MANUAL 0772- 0 16161-H1911
21 16134-H1910 LEVER-THROTTLE MANUAL
21 16134-H3920 LEVER-THROTTLE AUTO
22 16116-H1910 SLEEVE(A)
23 16236-H1910 LEVER
24 16452-H1000 SPRING-PUMP LEVER
25 16453-H1000 WASHER
26 16025-H1000 TUBE-EMULSION(P)
27 16160-H1910 SPRING-THROTTLE RETURN
28 16171-25710 WEIGHT-INJECTOR -672
28 16171-H7010 WEIGHT-INJECTOR 0772- 0 16171-25710
29 16061-18010 FLOAT
30 16026-B0810 TUBE-EMULSION(S)
31 16151-H1000 PISTON-POWER 1070-
32 16148-H1000 SPRING-PISTON RETURN
33 16141-18010 ROD-CONNECTING
34 16305-19915 SHAFT-PUMP LEVER
35 16307-04000 COVER-PUMP
36 16272-36710 PLUG-DRAIN (2)
37 16066-18010 SHAFT-FLOAT
38 16101-H1000 VALVE-NEEDLE
39 16098-25710 FILTER
40 16029-18010 WASHER
41 16065-H1010 SCREW
42 16033-L0101 JET-MAIN #97 -672
42 16033-H7010 JET-MAIN #95 0772- 0 16033-L0101
43 16043-25715 JET-MAIN #140
44 16055-14811 JET-SLOW #43
45 16054-B0810 JET-SLOW #50
46 16050-18010 BLEED-SLOW AIR #80 (2)
47 16204-08000 BLEED-SLOW AIR #100
48 16051-H3910 BLEED-SLOW AIR #215
49 16059-H3910 VALVE-POWER #50 -671
49 16059-H3911 VALVE-POWER #45 0771-0672 2 16059-H3910
49 16059-14810 VALVE-POWER #60 0772- 2 16059-H3911
50 16196-H7010 ASSY-CUT,FUEL 0772-1072
50 16196-H7011 VALVE-ANTI DIESELING SOLENOID 1172- 0 16196-H7010
51 16455-H1000 KIT-GASKET -672
51 16455-H6200 KIT-GASKET 2 16455-H1001
51 16455-H6200 KIT-GASKET 2 16455-H1000
51 16455-H1001 KIT-GASKET 0772- 2 16455-H1000
52 16475-H3910 KIT-SCREW & WASHER(B) -1072
52 16475-H7010 KIT-SCREW & WASHER (B) 1172- 0 16475-H3910
53 16465-H3910 KIT-SCREW & WASHER(A)
54 16009-H1910 KIT-REPAIR A, CARBURETOR -672
54 16009-H7000 KIT-REPAIR A,CARBURETOR 0772- 2 16009-H1910
54 16009-H6200 KIT-REPAIR A CARBURETOR 2 16009-H7000
55 16009-H7010 KIT-REPAIR B,CARBURETOR 0772- 2 16009-H3910
55 16009-H3910 KIT-REPAIR B, CARBURETOR -672
1973 LB110 USA Parts Catalog
