Tailgate Part Numbers
Revision as of 01:54, 1 May 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Tailgate
Rear Window
Fuel Door
Vents
Bumperettes
Truck
BODY SIDE FITTING
01 78130-G1000 COVER ASS'Y-gas filler
02 77760-89902 BUMPER-rubber, gas filler 2
03 76850-G1001 GRILLE-air outlet (R.H.)
   76851-G1001 GRILLE-air outlet (L.H.)
04 08530-71690 SCREW 4
07 76960-H1001 LOCK ASS'Y-gas filler
08 78962-18200 CLIP-seating cylinder lock
09 08310-51014 SCREW-with lock washer 2 <> 08360-51014
10 08915-43510 WASHER-plain 2
11 76916-00100 PLUG-rubber 2
BACK WINDOW
12 79712-G1000 GLASS-back window (up to '73-8)
*  79712-G1200 GLASS-back window (from '73-9)
13 79417-G1000 WEATHERSTRIP-back window 79710
   79417-G1001 WEATHERSTRIP-back window (up to '73-8)
*  79417-G1201 WEATHERSTRIP-back window (from '73-9)
* (79712-G1200) is compatible with the new parts in the set (79714-G1201)
14 79810-G1000 RAIL/PLATE-guard back window 3
15 08310-61226 SCREW-with washer (fixing guard plate) 6
REAR GATE FITTING
16 90134-G1000 HOOK ASS'Y-rear gate chain (R.H.)
   90135-G1000 HOOK ASS'Y-rear gate chain (L.H.)
17 90400-G1000 HINGE ASS'Y-rear gate 2
Fixing rear gate hinge
 18 08360-61612 SCREW 4
 19 08915-13610 WASHER-lock 4
 20 08915-53610 WASHER-plain 4
21 90500-G1024 LOCK ASS'Y-rear gate 2
Fixing rear gate lock
 22 08360-61612 SCREW 4
 23 08915-13610 WASHER-lock 4
 24 08915-43610 WASHER-plain 4
25 90802-G1000 BUMPER-rear gate 2
Fixing rear gate bumper
 26 08310-62012 SCREW 2
 27 08915-13610 WASHER-lock 2
31 90810-G1001 CHAIN SET-rear gate (op.)
 replaced 90810-G1025 CHAIN ASS'Y-rear gate 2 (op.)
32*93880-B5000 CHAIN ASS'Y-rear gate 2 (op.)
33 93425-B5000 BOLT-special 2
34 98015-G1000 HANGER-rear gate chain 2
35 85010-G1001 RUBBER ASS'Y-bumper rear (R.H.)
   85011-G1001 RUBBER ASS'Y-bumper rear (L.H.)
Fixing rear bumper rubber
 36 08310-64510 SCREW 2
 37 08915-13610 WASHER-clock 4
 38 08915-43610 WASHER-plain 4
 39 08110-61810 BOLT 2
REAR FLOOR FITTING
44 93599-14800 PLUG-floor hole 4 (op.)
HOLDFAST-GUARD
93100-G1060 FRAME ASSY-GUARD 7804-
93152-G1060 HOLDFAST-GUARD FRAME 8504- 3 [clip]
93154-G1060 HOLDFAST-GUARD FRAME 8504- 3 [insert]
93156-G1060 HOLDFAST-GUARD FRAME 8504- 3 [bracket]
 08110-61610
 08110-61225
93158-G1060 HOLDFAST-GUARD FRAME SIDE 8504- 2
 08110-82025 BOLT
