Hitachi distributor for Z-series 8-plug distributors, has a one-piece type internal module (ignitor + pickup in one). The module looks the same as the D4R distributor, but PNs differ.
Vacuum Advance module looks similar but the screw is 90-degrees to D4R and [D4K]] advance modules.
* 8-plug caps * 90-degree advance mounting * 3-wire hookup
USA * 720 with Z20, Z22, Z24 (not Z24I) * M10 (CA20E) -0986 * S110 with Z22E, Z20E.CAL [FED is 4-plug, uses matchbox] * S12 with CA20E -0186 (newer has no advance module) * T11 with CA20S, CA20E.(EXC MITSUBISHI)
STATOR 22163-W0560 Z20,Z22,Z24 * USA ** 720 Pickup Z20, Z22, and Z24 engines ** M10 with CA20E ** S110 with Z20E, Z22E ** S12 with CA20E ** T11 with CA20E, CA20S
TRANSISTOR IGNITION UNIT [ignitor] 22020-61W00/22020-61W02/22020-61W03 * 720.Z20 22020-W0560/22020-W0561 * 720.Z22, M10.CA20E.MT, S12.CA20E, T11.CA20E.MT * S110.Z20E 0179-0681 22020-V5400/22020-V5401 * 720.Z24 22020-D0200 * S110.Z22E * 720.Z24
