Glass
Revision as of 22:43, 12 June 2012; view current revision
Category: Body
Also see: Power Windows
Ventilation
1972 USA Owners manual (see page 7 for ventilation -- opening of the windows: door window, ventilator glass, and Quarter Window):
Driving Safety and Comfort
Windshield/Windscreen
See main article: Windshield
Door Glass
  • 2-dr Coupe Door glass differs from 2-dr Sedan glass
  • 2-dr and 4-dr glass differs
  • 4-dr van and 4-dr sedan are the same
Wing Window
The wing window is officially named the Door Ventilator.
  • 80244-H1001 GLASS-door ventilator (R.H.) 2 std
  • 80245-H1001 GLASS-door ventilator (L.H.) 2 std
  • 80244-H1101 GLASS-door ventilator (R.H.) 2 DX, 2 GL
  • 80245-H1101 GLASS-door ventilator (L.H.) 2 DX, 2 GL
  • 80244-H8000 GLASS-door ventilator (R.H.) Coupe
  • 80245-H8000 GLASS-door ventilator (L.H.) Coupe
  • 80250-H1001 CHANNEL ASS'Y-door ventilator (R.H.) 2 door [pivoting bottom-channel]
  • 80251-H1001 CHANNEL ASS'Y-door ventilator (L.H.) 2 door [pivoting bottom-channel]
  • 80250-H1800 CHANNEL ASS'Y-door ventilator (R.H.) Coupe [pivoting bottom-channel]
  • 80251-H1800 CHANNEL ASS'Y-door ventilator (L.H.) Coupe [pivoting bottom-channel]
  • 80270-H1001 FRAME ASS'Y-door ventilator (R.H.) 2 door
  • 80271-H1001 FRAME ASS'Y-door ventilator (L.H.) 2 door
Rubber Seals
2-door sedan, 4-door sedan, and Pickup
  • 80282-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, RH $13.69
  • 80283-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, LH $13.69
  • 80246-H1000 RUBBER-glazing, door ventilator (2) 2 door, Coupe
    [holds glass in the pivoting bottom-channel]
Coupe
  • 80282-H1800 WEATHERSTRIP-front door ventilator (R.H.)
  • 80283-H1800 WEATHERSTRIP-front door ventilator (L.H.)
Rear 4-door Sedan
  • 82242-H1000 WEATHERSTRIP-partition rear door (2)
Door Glass
Removal & Reinstall
  1. Take apart the door bits and pieces
    • Unscrew the door pull/armrest, door handle, and window winder
    • Carefully pop the door card (panel) off to access the inside of the door. Use a putty knife or other flat tool, slide it between the card and door until you locate the clip. Then twist to pop the clip out. There are two on one end and three on the other end.
  2. Roll the window up first. Then unbolt the window stop at the bottom of the door.
  3. Roll the window down so that the regulator comes out of the track on the window glass frame but be careful not to let the window drop too hard. Leave the glass at the bottom of the door temporarily.
  4. Take the quarter window frame out.
    • There are three screws at the top of the door concealed under the door rubber.
    • Also there is one larger screw towards the bottom of the door. It's recessed a bit.
    • Once loose pull the quarter window assembly out.
  5. Reach in the door and turn the door glass 90 degrees then pull of out from the top.
  6. To reinstall, do everything in reverse. However don't tighten the screws on the quarter window assembly until you get the new window to align with the slots on each side. That is the hardest part.
Rubber Seals
  • 80336-H1001 RUBBER-glass run "B" (2) 4 door, 2 door
  • 80335-H1001 RUBBER-glass run "A" (2) 4 door
  • 80335-H1202 RUBBER-glass run "A" (2) 2 door
  • 80336-H1800 RUBBER-glass run "B" (2) Coupe
  • 80335-H1800 RUBBER-glass run "A" (2) Coupe
  • 80335-H1202 RUBBER-GLASS RUN"A" SEDAN 2DR NLA
    • formerly 80335-H1200, 80335-H1201
  • 80336-H1801 RUBBER-GLASS RUN SEDAN 2DR NLA
    • formerly 80336-H1000, 80336-H1001, 80336-H1800
  • 80316-H1200 RUBBER-GLEZING SEDAN 2DR $5.61 USD
Truck
  • 80336-G1000 RUBBER-glass run "B" (2)
    • replaced 80336-H1001 RUBBER-glass run "B" (2)
  • 80336-H1001 RETAINER RUBBER-GLASS (2) -8910
  • 80336-G1901 RETAINER RUBBER-GLASS (2) 8910-
  • 80335-G1000 RUBBER-glass run "A" (2)
    • replaced 80335-H1001 RUBBER-glass run "A" (2)
  • 80335-H1001 GLASS RUN RUBBER-A (2) -8508
  • 80335-G1900 GLASS RUN RUBBER-A (2) 8508-8910
  • 80335-G1901 GLASS RUN RUBBER-A (2) 8910-
Door weatherstripping is same material (possible same shape/length) as 510.
  • 80830-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
  • 80831-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
  • 80830-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe $58.90 USD
  • 80831-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe $59.90 USD
  • 80836-H1000 WEATHERSTRIP ASS'Y-door inside (R.H.) 4 door
  • 80837-H1000 WEATHERSTRIP ASS'Y-door inside (L.H.) 4 door
  • 80836-H1200 WEATHERSTRIP ASS'Y-door inside (R.H.) 2-dr Sedan, Coupe, Coupe (L.H.) $7.53 USD
  • 80837-H1200 WEATHERSTRIP ASS'Y-door inside (L.H.) 2-dr Sedan $7.53 USD
2-door Sedan
  • 80830-H1202 ASSY-WEATERSTRIP FRONT DOOR RH (from '70-Jul.)
    • 80830-H1200 ASSY-WEATHERSTRIP FRONT DOORRH
  • 80831-H1200 ASSY-WEATHERSTRIP FRONT DOORLH (from '70-Jul.)
    • 80831-H1202 ASSY-WEATHERSTRIP FRONT DOORLH
  • 80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH
  • 80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH
  • 80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH $41.33 USD
    • replaced 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH
  • 80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH $46.18 USD
    • replaced 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH
80825-H1000 CLIP-MOULDING DOOR OUTER
80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE RH
80837-H1200 WEATHERSTRIP-FRONT DOOR INSIDE LH
ドア ウェザー ストリップ ドア インサイド モール ガラスウエザーストリップ
Window Winders
Black: 1970-1977
Brown shade 1: 1978
Brown shade 2: 1979-1989
Gray: Oct 1989-
  • 80675-H1000 WASHER-SEATING
  • 08330-51220 SCREW
  • 80760-H1000 HANDLE ASSY-DOOR WINDOW REGULATOR BLACK
  • 80760-G1060 HANDLE ASSY-DOOR WINDOW REGULATOR BROWN 7804-7907
  • 80760-G1660 HANDLE ASSY-DOOR WINDOW REGULATOR BROWN 7908-8910
  • 80760-95W00 HANDLE ASSY-DOOR WINDOW REGULATOR [GRAY] 8910-
Custom winders:
Compare to Datsun 1000:
ドア ウインドー レギュレーター ハンドル
Window Regulator
Top: 2-dr Coupe
Bottom: 2-dr Sedan
  • 80700-H1202 or 80700-H1201 REGULATOR ASS'Y-door window (2) Sedan-2D
    • replaced 80700-H1200 only works up to '70 Oct.
  • 80700-H1800 REGULATOR ASS'Y-door window (R.H.) Coupe
  • 80701-H1800 REGULATOR ASS'Y-door window (L.H.) Coupe
4-dr Sedan & Wagon
  • 80700-H1002 or 80700-H1001 or 80700-H1000 REGULATOR ASS'Y-door window (2)
  • 82700-H1001 or 82700-H1000 REGULATOR ASSY-rear door window, RH
  • 82701-H1001 or 82701-H1000 REGULATOR ASSY-rear door window, LH
Truck
  • 80700-H1002 REGULATOR ASSY-DOOR WINDOW, RH
  • 80701-H1002 REGULATOR ASSY-DOOR WINDOW, LH
2-dr door regulators have longer pivot arms (pivot point to roller) while the shorter 4-door front door regulators are likewise shorter.
Side Glass
Sedan
2-door sedan has popout side windows
  • 76828-H1200 COVER-SIDE WINDOW HINGE
  • 76822-H1301 GLASS-SIDE WINDOW RH TINTED & TEMPERD T=
  • 76823-H1301 GLASS-SIDE WINDOW LH TINTED & TEMPERD T=
  • 76870-H1200 ASSY-HANDLE SIDE WINDOW RH
  • 76870-H1200 ASSY-HANDLE SIDE WINDOW LH
  • 76872-18000 PIN-HANDLE SIDE WINDOW
  • 08430-41620 SCREW-MACHINE M4
Rubber
76802-H1202 WEATHERSTRIP-SIDE WINDOW RH
76803-H1202 WEATHERSTRIP-SIDE WINDOW LH
76922-H1200 WELT-SIDE WINDOW BLACK #698 (2) SEDAN 2 DOOR
B310 also fits with some trimming:
B310 83830-H8600 WEATHERSTRIP-SIDE WINDOW RH (BLACK 002G0 $84.53 USD
B310 83831-H8600 WEATHERSTRIP-SIDE WINDOW LH (BLACK 002G0 $84.53 USD
B310 weatherstripping can be used for B110 2-dr sedan rear side window weatherstripping. It's almost perfect, but about 1 inch too short for the B110. Surprisingly, the B110 glass is actually larger! The B110 has a window seal that's glued to the outside of the frame, and an inside cover for the door frame. The B310 uses a one-piece seal. Just trim a bit of it off when fitting to the B110.
Coupe
Rear Window
Sedan
  • 79710-H1001 WEATHERSTRIP-REAR WINDOW
  • 79710-H1000 WEATHERSTRIP-REAR WINDOW
  • 79713-H1101 GLASS-REAR WINDOW T=4.0 TEMPERED & T 0771-
  • 79713-H1103 GLASS-REAR WINDOW T=4.0 TEMPERED & T
  • 79713-H1001 GLASS-REAR WINDOW T=4.0 TEMPERED
  • 79713-H1003 GLASS-REAR WINDOW T T=4.0
  • 79713-H2900 GLASS-REAR WINDOW,T=4,0, HEAT,ANTI SU
  • 79713-H2901 GLASS-REAR WINDOW T=4.0 HEAT
  • 79810-H1100 SET-MOULDING REAR WINDOW
    • 79812-H1100 MOULDING-REAR WINDOW UPPER
    • 79813-H1100 MOULDING-REAR WINDOW LOWER
    • 79814-H1100 MOULDING-REAR WINDOW RH
    • 79815-H1100 MOULDING-REAR WINDOW LH
  • 79810-H1101 SET-MOULDING REAR WINDOW 0670-
    • 79811-H1101 MOULDING-REAR WINDOW UPPER RH
    • 79812-H1101 MOULDING-REAR WINDOW UPPER LH
    • 79814-H1101 MOULDING-REAR WINDOW RH
    • 79815-H1101 MOULDING-REAR WINDOW LH
    • 72814-13600 CLIP-MOULDING
Coupe
  • 79710-H1800 WEATHERSTRIP-REAR WINDOW
  • 79713-H1805 GLASS-REAR WINDOW TINTED T=4.0
  • 79713-H2201 GLASS-REAR WINDOW,TINTED HEAT RIGHT,T
  • 79810-H1800 SET-MOULDING REAR WINDOW
    • 79812-H1800 MOULDING-REAR WINDOW UPPER
    • 79813-H1800 MOULDING-REAR WINDOW LOWER
    • 79814-H1800 MOULDING-REAR WINDOW SIDE RH
    • 79815-H1800 MOULDING-REAR WINDOW SIDE LH
    • 79816-H1800 CLIP-MOULDING UPPER
    • 79817-H1800 CLIP-MOULDING LOWER
Parts Sources
Rubber Sources
See Rubber parts
Glass Sources
  • eBay
  • Wrecking Yards
  • Datsun1200.com Classifieds forum
  • USA:
    • Pilkington Classics 1-800-848-1351
    • PPG Vintage 1-877-855-8100
Discussion
ガラス
