Also see:
Part Numbers Index Main article for usage, photos, cross-reference Driveshaft
1974 PROPELLER SHAFT (Long Body) 1 37000-G1400 SHAFT ASS'Y-propeller (up to '73-8) 37000-G1410 SHAFT ASS'Y-propeller (from '73-9) 2 01111-00051 BOLT 4 3 08911-20810 NUT 4 4 08915-13810 WASHER-lock 5 37510-G1401 BRACKET-center bearing, lower 6 08154-02010 BOLT 2 7 08915-14010 WASHER-lock 2 8 37522-P0101 INSULATOR-center bearing 9 37525-P0101 CUSHION-center bearing 10 74345-G1401 BRACKET ASS'Y-center bearing, upper
1 37000-H5100 COMP-SHAFT PROPELLER WITH JOINT SHELL AUTOMATIC 0373- 2 37000-H5100 1 37000-H1001 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1000 1 37000-H1010 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1001 1 37000-H1011 COMP-SHAFT PROPELLER WITH JOINT MANUAL 0972- 0 37000-H1010 1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1011 1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT SHELL MANUAL 0373- 2 37000-H1011 1 37000-H1101 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 1 37000-H1110 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 0671- 2 37000-H1101 1 37000-H1000 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37111-20300 ASSY-YOKE SLEEVE AUTOMATIC 2 37111-18001 ASSY-YOKE SLEEVE MANUAL 3 37117-18000 YOKE-FLANGE 4 37125-18025 ASSY-JOURNAL WITH BEARING (2) 4 37125-H1025 KIT-JOURNAL WITH BEARING (2) 2 37125-18025 5 37130-18000 ASSY-RACE BEARING WITH OIL SEAL (8) 5 37125-H1025 ASSY-RACE BEARING WITH OIL SEAL (8) AUTOMATIC 2 37130-18000 6 37147-18000 RING-SNAP BEARING RACE T=1.48 (8) 6 37148-18000 RING-SNAP BEARING RACE T=1.50 (8) 6 37149-18000 RING-SNAP BEARING RACE T=1.52 (8) 6 37146-18000 RING-SNAP BEARING RACE T=1.46 (8) 7 08120-82210 BOLT-HEX M8X1.25 (4) 7 01111-00061 BOLT-FIX PROPELLER SHAFT (4) AUTOMATIC 2 08120-82210 7 01111-00151 BOLT-FIX PROPELLER SHAFT (4) 3N71B 0371- 2 01111-00061 8 08911-20810 NUT-HEX M8X1.25 (4) 9 08915-13810 WASHER-LOCK M8 (4)
