Datsun 1200 used the tried and true leaf spring rear suspension, which was common among most cars - including american cars - in the early 1970s.
Leaf Spring Mounting
Rear axle mounting and Shocks
Spring Seat Assembly Sedan: 55262-H1001 Truck: 55262-G1000 (RH) & 55266-G1000 (LH) 12mm shock Nut wide u-bolt Van: 55262-H1402 (RH) & 55266-H1402 (LH) 12mm shock Nut narrow u-bolt Coupe: 55262-H1802 (RH) & 55266-H1802 (LH) 8mm shock Nut
U-bolts 55247-H1002 CLIP-rear spring Sedan, Coupe.USA 55240-H1800 Coupe.JPM.early 55247-H1401 CLIP-rear spring Van, Coupe.JDM.late 55247-G1000 CLIP-REAR SPRING Truck 4-leaf 55247-G1060 CLIP-REAR SPRING Truck 5-leaf 7804-
Fasteners for U-bolts (Sedan,Coupe,Van,Truck) 08911-64010 NUT-HEX M10 x 1.25 8 08915-14010 WASHER-spring lock 8
Bumpers
Coupe & Van rear suspension bumper (above the Leaf Spring) 55240-H1400 ASSY-BUMPER REAR AXLE 08911-64010 NUT-HEX M10X1.25 08915-14010 WASHER-SPRING LOCK
Sedan rear suspension bumper (on the Shocks) 55240-H1001 BOUND BUMPER A 56124-H1001 BOUND-BUMPER B
Bushings
5 - 55044-H1001 BUSHING-rear suspension, front, upper (8)
6 - 55045-H1000 BUSHING-rear suspension, front, lower (4) [leaf eye]
* NLA in North America
6 - Wagon & Truck (ute) use 55045-H1400
17 - 55046-H1000 BUSHING-rear suspension, upper (4)
18 - 55047-H1000 BUSHING-rear suspension, lower (4) [leaf eye]
Make your own
Or, make your own performance bushings per Nissan Competition book:
Aftermarket
Or, get stiff aftermarket bushings:
Polyurethane bushings out of Mexico: Parbo
