"Drag racing's toughest little car", this Datsun 1200 is powered by a 1974 L26 engine from a 260Z.
The 411 Horsepower L20B-powered 1200
Ron Folck's 1200 (ex-Chris Wayland)
I’m sure most of you know of Ron Folk’s 1200 sedan with the 6 cylinder turbo Z engine? That car is one I found in a wrecking yard for my brother, Chris Wayland. He and I dropped an L20B into it, modified it for turbocharging, and jammed it with 31 lbs. of boost with a double pumper Holley 750 carb, and a tubbed the rear stuffed with a Ford 9 inch. This was back in the early 80’s, when the whole import drag racing scene wasn’t even around. We really blew the muscle car crowd’s minds with a four banger Datsun that kicked butt! The car’s best ET was somewhere around 11 seconds, if I recall correctly. reference: John Wayland, an introduction
More details:
Let's see: 400 hp in a 1640 lb car v 600 in a 2800 lb car ... the Datsun had a power-to-weight advantage.
Hello Datsohollics and 1200 fans,Years ago, my brother and I stuffed an L20B into a 1200 sedan....the beginnings of our 411 hp (dynoed) 31 lbs. of boost, 1/4 mile drag Datsun. Knowing we were going to use a Corvette crossflow radiator, and thus the engine would sit a little farther into the engine bay, and knowing we were also going to use a Z 5 speed tranny with its larger bell housing, we cut the firewall and built a new tranny tunnel. While we were at it, we also tubbed the rear and put in a huge Ford 9 inch rear end with 5:17 gears, too. I believe it is possible to put in an L series motor without cutting up the bodywork as we did, though, but at the time, this how we did it. This same 1200 is alive today but now belongs to Ron Faulk who is well known for this wheel-standing, now 6 cylinder turbo powered car.
See Ya.....John Wayland
reference: Re: L - series engine conversion
700 HP: Ron Folck Pours on the Power
The Oregonian by Jerry F. Boone
Folck is one drag racer who is programmed to race
The Sandy [Oregon] driver gets the most out of his Datsun 1200 by turning to his computer and high-tech for improving engine performance on the track
Many time national event winner and runner up import & NHRA. This car was the first turbocharged w/ automatic trans to stall on a 4ths pro tree in NHRA or import, This car is light years ahead of any import as it can run in national events in the nhra and stand up to any car in it' class. It has beaten Abell Abira in 1999 world finals in pheonix,beaten many many NHRA national event bracket cars. Extremely reliable and has never broke and is set up to run 9.90 in super gas can run 8s at 150. There are to many parts to list as we have worked on it for 12 years.
- 700hp inline 6 Nissan
- Factory backed turbonetics ceramic ball bearing 60-1 turbo
- Handmade fuel injected intake plenum
- Hand made exhaust system
- Turbonetics wastegate
- Two speed Powerglide /w protree transbrake
- turbonetics intercooler
- Remote water pump
- NHRA certified chromoly full cage
- Wheely bars
- Simpson chute
- Goodyear slicks
- 9' ford funnycar lenco 35 spline differential
- Biondo Mega 400 w/ throttle stop
- HALtech EFI controller
- Laptop computer and all programs to run it
Where is it now?
Ron has since retired, and at last word 'Drag racing's toughest little car' was for sale at $25,000 USD.
