<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Oil pump Oil Filter
10 15208-13211 ELEMENT-oil filter, cartridge 15208-13212 ELEMENT-oil filter, cartridge <> 15208-13211 15208-H1010 (from '72-2) <> 15208-13212 15208-H8911 FILTER ASSY-OIL 7911-8502 15208-H8903 FILTER ASSY-OIL 8502-
1 15010-H9701 ASSY-PUMP OIL WITH OUT OIL FILTER A12 0473- 2 15010-H6200 1 15010-H6200 ASSY-PUMP OIL WITH OUT OIL FILTER A12 0473- 2 15010-H1000 1 15010-H1000 ASSY-PUMP OIL WITH OUT OIL FILTER A12 -373 2 15020-H1025 ASSY-SHAFT DRIVE OIL PUMP A12 2 15020-H1005 ASSY-SHAFT DRIVE OIL PUMP A12 2 15020-H1025 3 15025-18003 GASKET-OIL PUMP A12 4 15132-H1000 ASSY-VALVE OIL REGULATOR A12 5 08310-53010 SET-BOLT BODY TO COVER A12 6 08915-13510 WASHER-SPRING A12 7 15066-18000 GASKET-OIL PUMP TO CYLINDER BLOCK A12 8 08915-13810 WASHER-LOCK (3) A12 9 15036-18000 BOLT-OIL PUMP (2) A12 10 08110-85510 BOLT A12 11 15050-H1000 ASSY-STRAINER OIL A12 12 15053-18000 GASKET-OIL STRAINER A12 13 08110-82010 BOLT (2) A12 14 08915-13810 WASHER-LOCK (2) A12 15208-55Y00 ASSY-OIL FILTER CARTRIDGE A12 0272- 15208-H1010 15 15208-H1010 ASSY-OIL FILTER CARTRIDGE A12 0272- 2 15208-13212 15 15208-13211 ASSY-OIL FILTER CARTRIDGE A12 15 15208-13212 ASSY-OIL FILTER CARTRIDGE A12 2 15208-13211
1973 LB110 USA Parts Catalog
