The 1984 Nissan Competition Catalog listed conversion parts to fit an H165 rear axle assembly to the Datsun 1200.
Datsun 1200 utes came H165 rear axle assembly. However there are several differences from the Sedan & Coupe. However the B110 powered by L14 engine (PB110) also came with H165 which is a direct bolt-in for Sedans & Coupes. Datsun Competition made these PB110 parts available.
The 1200, B210 and 210 models came with either the H145A (to 8/74) or H150 (from 9/74) 3rd members. For competition it is suggested that the H165 3rd member be fitted. To adapt the H165 3rd member the entire axle housing must be changed. For a complete listing of H165 R&P set and LSD units, please refer to page 29.
Parts List
43010-H2551 1200 AXLE HOUSING (COUPE ONLY) * [H25 is PB110 part] 38162-G1000 AXLE ASSY FOR 43010-H2551 * [G10 is newer B120 part]
43010-G1051 B210 AXLE HOUSING (COUPE ONLY) 38162-G1000 AXLE ASSY FOR 43010-G1051
43010-W6250 B310 AXLE HOUSING * same as A10 wagon housing 38162-W8500 AXLE ASSY FOR 43010-W6250
The following parts are required to complete the conversion: * 43036-H5000 AXLE SHIM (0.75.MM) * 43036-H5001 AXLE SHIM (0.15MM) * 43036-H5002 AXLE SHIM (0.225MM) * 43036-H5003 AXLE SHIM (0.3MM) * 43070-01L00 AXLE BEARING SPACER (2) * 43215-H5000 AXLE BEARING (2) * 43252-H1010 OIL SEAL (2) * 43255-H1000 BEARING COLLAR (2) 1200/B210 only * 43236-H5000 GREASE CATCHER (1200/B210 only) (2) * 43239-H5000 PACKING 1200/B210 only (2)
