1200 Parts Donor
A15 forklift Exhaust Manifold has been used to create a Turbo manifold
A15 Engine for Nissan forklift e.g. http://www.wholesaleforkliftparts.com/product_p/a15.htm
LR135 IR alternator (stock 1200 unit)
New A14 Engine from Nissan commercial business
Industrial Engine
A15 Prochem carpet cleaner Grove manlift Nissan H01 forklift Nissan H02 forklift
Nissan model A12 & A15 Industrial Engine Service Manual
A15 Industrial Engine with extended front housing & extended oil pan
Nissan Truckee T01
Available in Diesel or CG13 gasoline engine (HT01A08U "TG8")
1.3 tonne tractor tug
ENGINES T01 A12 from Jan 1985 T01 CG13
TG8 has a 500kg payload, and can tow up to 15 tons with two trailers
With various custom glass houses
H01/H02
Nissan H01 and H02 series forklifts.
H01 1.8 ton version
ENGINES H01 A15, A24, H20, SD22, SD25, SD5, Z24 H02 A15, A24, H20, SD22, SD25, SD5, Z24 AH01 A15 AEH02 SD25 APH02 H20 CRGH02 Z24 RGH02 Z24 CEH01 SD25 CEH02 SD25
In three types: Compact type, Pneumatic tire, and Cushion tire
Tonnage 1.0 ton 1.3 ton 1.5 ton 1.8 ton
Parts Catalog Nissan Forklift Model H01 Series USA & Canada April 1987 Issue Pub. No. C-F100U
Nissan Forklift Parts Catalog Model H01 Series Part Number: CF100-UBOOK & CF100-USBOO-K, Nissan Forklift Corporation, North America
Nissan Forklift Service Manual & Technical Bulletin Model H01 & H02 Series
Nissan Forklift Service Manual & Technical Bulletin Model A15, Z24 and SD25 Engines (Pub. No. SM6E-HEG0)
TCM
東洋運搬機 TOYO UMPANKI CO., LTD. OSAKA JAPAN
FG10
TCM FG10 A15 or D11 engine
full
FG14
TCM FG14 J15 TCM FG14N4 J15
FG15
TCM FG15N J15 TCM FG15N16 A15 TCM FG15N17 A15
FG15N16
full
FG15N17
full
FG18
Manifold
A-14004-03J00 TB42S 14004-05H00 A-14004-95008 A-14004-95502 Diesel A-14004-96019 UD PE6T A-14004-96066 Diesel: 14004-L1101 H20 A-14004-41K00 TD27? 14004-40K02 A-14004-97077 Diesel A-14004-Z5512 A-14004-Z5514 A-14004-Z5516 A-14004-Z5517
D11 Forklift
FinTuukka's FG103 Datsun forklift (D11-powered)
full
Others
Datsun Factory Service Manual for FG106/FG107 & FD106/FD107 forklifts
full
Models
FG107 H20/H30 PF02 AF50 Nomad K21
UF03 P40 UGF03 P40 WF03 TD42 WGF03 TD42 YF03 SD33T YFG03 SD33T SD25 SD25 J01 H15, H20, TD27 J02 BD30, H20, H25, TD27 L02 33L4C M20 SD25 MF05 SD33T P5 H20 PF02 H20, J15, PH01 H20 PH02 H20, SD22 QCF01 SD22 QCF02 SD22 BF03 TB2 C5 H20 CD40 SD25 CF01 H20,J15 CF02 H20,J15 CEF02 SD25 CD4000 SD25 CD5000 SD25 CFG003 D11 CFG005 H20 CFG103 D11 CFG105 H20 CH01 H20 CH02 H20 CHF03 H30 CHP02 H20 CPF01 H20 CPH01 H20 CQF01 SD22 CQF02 SD22 CD5500 SD25 D01 H20, H25, H27 D02 H20, H25, H27 DF02 H20 DF05 FD6 E40 electric ED005 SD33 EF02 SD22, SD25 EH01 SD25 EH02 SD25 F01 H20, J15, SD15, SD22, SD25 F02 H20, J15, SD15, SD22, SD25 F03 40, P40, SD22, SD33T, TB42, TD42 F05 FD6, P40, SD33T, TB42, TD42 FD005 SD33 FG001 D11 FG003 D11 FG004 H20 FG005 D11, H20 FG006 H30 FG007 H30 FG020 H20 FG035 D11 FG101 H20 FG102 D11, H20 FG103 D11 FG104 D11 FG105 D11 FG204 J15
Exhaust Manifold =
NI14004-L1801 14004-GS00A 14004-FU400 K15 14004-L1101
