Main : Mechanical : Drive Train Forklift manifold
[<   Previous  730  731  732  733  734  735  736  Next   >]
Forklift manifold
Forklift manifoldPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2003/6/23 6:02    Tell a friendTell a friend
Hits6045  Comments9    0.00 (0 votes)0.00 (0 votes)
The infamous a-type exhaust
jaimecidpedro
Posted: 2003/6/23 23:22  Updated: 2003/6/23 23:22
 Re: Forklift manifold
Those manifolds look scary. What kind of performance can you get out of that. Sure it is a forklift, no high RPM, but, no excuse, "F" grade in design. That must have been Fred Flinstone's A -12( "minus12" engine) engine's manifold.
rally-a-coupe
Posted: 2003/6/24 3:02  Updated: 2003/6/24 3:02
there is no performance in them the carb througt is only 4 cm diameter they rev to about 3000 rpm (petrol motor) and thats about it
Posted: 2003/6/24 5:48  Updated: 2003/6/24 5:48
These forklift engines are designed to do something your engine cannot do. Run at full load all the time for years. To do so, they are specially built and tuned for low power, high torque output.
Posted: 2003/6/24 5:50  Updated: 2003/6/24 5:50
Did anyone else notice the manifold goes UP? It wouldn't fit in a car ...
2332owner
Posted: 2003/6/24 7:31  Updated: 2003/6/24 7:31
I think it would clear the hood 'cause it wouldn't be much taller than the valve cover. Less heat soak into the intake manifold as well. Once you mount a turbo on it you'd have to cut a hole in your firewall to fit it though!
benny
Posted: 2003/6/24 7:38  Updated: 2003/6/24 7:38
the manifold dumps to the front of the engine towards the radiator. It does fit easily on a 1200, clears the bonnet, with room to spare.
No need to cut the firewall.
Benny
rally-a-coupe
Posted: 2003/6/24 7:42  Updated: 2003/6/24 7:42
forklifts last for ages i will see if we have any of these manifolds left at work my old man owns a forklift company i think it would be a better idea to make up a custom manifold
This manifold is off an A15 forklift there was never an A12 forklift made
2332owner
Posted: 2003/6/24 10:26  Updated: 2003/6/24 10:26
So hood clearance would be a problem then huh? I thought the manifold went up over the intake then down.
2332owner
Posted: 2003/6/24 10:31  Updated: 2003/6/24 10:31
Guess I was looking at it all backward... looking at a pic of another one on this site looks like it would fit under the hood but this one looks longer for some reason.
Posted: 2005/7/2 6:51  Updated: 2005/7/2 6:51
Here's a photo showing how the exhaust pipe is located in a Nissan forklift:
Forklift A-type engine
Posted: 2005/7/2 6:55  Updated: 2005/7/2 6:55
Here's a different forklift manifold (this one sweeps down):
Phunkdokta
