In 1977 Nissan released the B310 and three months introduced new trims GX-E and SGX-E. These featured fuel injected (EGI) engines, the legendary A14E motor. It improved upon the B310 GX which came with a single carburetor A14S motor. Nissan "introduction" Service Bulletin Number 350 highlights the features of the new model, in this case the biggest change from the GX to the GX-E is the Fuel Injection system. The Service Bulletin No. 350 is 60 pages.
PART 1 (Specifications, Engine) | PART 2 (Chassis, Body)
Chassis
Propeller Shaft
page 50 page 53 PDF![]() |
Body
page 51 page 54 PDF![]() |
Accent Stripe
The accent stripe interwoven with character of NISSAN EGI, fitted as standard.
Rear Emblem
2.2 '1400 GX E' or '1400 SGX E' emblem
Body Electrical
[page 52 original, page 55 PDF]
ボディ電装
Body electrical
Summary
1. 概要
ハーネス関係、タコメータ、リレー、ウォッシャータンク、エアコンの高圧ホース及びバキューム ホースの取り付け状態以外は、GX、SGXのキャブレター仕様車と同じです。
1. Summary
Harness relationship, tachometer, relay, washer tank, except mounting state of high pressure hose and vacuum hose of air conditioning, GX, this is the same as carburetor specification car of SGX.
Wiring and Relays
[page 53 original, page 56 PDF]
配線及びリレー
Wiring and relays
[Page 52 original, page 55 PDF]
2-1 配線
2-1 Wiring
Main Harness
Connects to relays of EGI and EGI harness connector
Body harness
Connects to fuel pump
Battery cable
Battery cable of EGI specification vehicle connects to fusible links [接続するコネクタを設けました。]
Fusible Link
Fusible link of EGI specification vehicle is 0.5(green), 2 used [2本設けました。]
Relay
[Page 53 original, page 56 PDF]
full | japanese
Right Hood Ledge
フード レッジ 右
ホールド リレー
hold relay
full | japanese
radiator core support
ラジエータ コア サポート
排気温度警告灯 チェック リレー
Exhaust Temperature warning light Check Relay
Tachometer
[page 54 original, page 57 PDF]
3. [Tachometer Yellow Zone 6400-6800, compared to 6000-6250 for A14S]
EGI仕様車 (参考)キャブレター仕様車 イエロー ゾーン 6400~6800 6000~6250 レッド ゾーン 6800~8000 6250~8000
EGI Carbureted Yellow Zone 6400-6800 6000-6250 Red Zone 6800-8000 6250-8000
Washer Tank
4. Washer Tank 2.2 litre, tank, fusible link & relay bracket, rear wiper & rear washer
Air Conditioner (Cooler Option)
[Page 55 original, page 58 PDF]
5. ???
Air conditioner (dealer option), hoses
High Pressure Hose
高圧
Vacuum Hose
エアコン用FICDアクチュエーカーがスロットル チャンバー下部にあるため、バキューム ホームの配管は、右図のようにしました。
FICD actuator for aircon is at the bottom of the throttle chamber, plumbing vacuum home as shown in the diagram on the right.
Final Page
Page 56 page 60 PDF
複製を禁ず
印刷発行 昭 和 53 年 2 月
実費210円
発 行 所 日 産 自 動 車 株 式 会 社
担 当 サ ー ビ ス 部
東京都中央区銀座6ー17ー1
T-802090
Replication prohibited Print issued in February 1978 Actual cost 210 yen Publishing office Nissan Motor Co., Ltd. Service Representative Part Ginza, Chuo-ku, Tokyo 6-17-1 T-802090
