Jack
Revision as of 02:08, 13 August 2015; view current revision
Categories: Wheel And Tire | Maintenance And Daily Care
Datsun 1200s were equipped with an easy-to-use scissor-type jack. It shipped in the boot, as shown in the Owners' manual.
Also see: Changing tire
Sedan & Truck jacks differ only by the diagram (sticker) on the jack.
Sedan
Truck
USA 1972 Owners manual (see page 27 for details):
There are four jack-up points at the floor panel
You can jack-up the 1200 at these points:
Using OEM jack (see Owners Manual above):
  • under rocker panel front
  • under rocker panel rear
Be sure to use a Nissan or Toyota jack with a "slot" to fit over the rocker panel seam. Jack here, at the point of the the half-round indents:
Using other jacks:
  • Under lower A-arm (Transverse link), near tire
  • Middle of engine crossmember (lift entire front end)
  • center of Differential (lift entire rear of car)
  • Outboard ends of rear axle housing
CAUTION: Before sliding underneath the car, be sure to place jackstands under the suspension. In a pinch a tree stump or beefy timber can work. Make certain it is secure, and lower the weight of the car on the jackstands.
Standard Equipment
  • Scissor Jack
  • S-shaped Jack Handle
  • Wheel Wrench in black 'Nissan' bag
  • Tire retaining clamp
1976 Aussie Pick-up
1976 tool kit
Jack Location
The Jack and its equipment is stored in special place.
Coupe
Sedan
The Jack and its equipment is stored in the Trunk (Boot).
Truck
The ute Jack is stored in front of passenger's seat.
B120 1974 Export owner's manual
The tools and jack components are stored in the storage compartment as shown. The tool bag is stowed under the assist seat.
Ute_floor_bracket
Mounts similar to this VB310 jack:
full
Tool_Kit_Part_Numbers#Sunny_Truck features tabs going other way?
Upgrades
Roller Jack Handle
Nissan jack handle with built-in rollers (no more pinched hands!). Source one from a more luxurious Datsun or Nissan. I got mine from a 1985 S12.
Wheel Stops
From B310 and many other Datsuns:
  • 99595-H7400 TIRE STOPPER
ジヤッキ、パンタグラフ タイパ゚ ハンドル、ジヤッキ クランク
Part Codes: 99610, 99611
  • 99550-H1000 SET-JACK B110 $74.14
  • 99553-H1400 HANDLE-JACK CRANK VB110P, B120 [right-angle]
    • looks similar to 99552-D0100 U11
  • 99551-G1400 JACK-PANTOGRAPH TYPE B120
  • 99595-18000 BAG-TOOL $3.89
Others
  • 99504-50Y00 bag-tool $4.14
  • 99501-01A00 tool kit-complete with jack $118.12
  • 99552-01G00 rod-jack D22 [straight] $17.25
  • 99553-01W00 Handle Jack 280ZX [crank] $9.33
  • 02996-01100 handle-jack 310/810 [with plastic roll surfaces] $19.33
  • 99595-H7400 tire stopper 810 [non-folding]
  • 99595-U1400 tire stopper 280ZX [folding type] $24.30 [99595-F2700]
  • 99545-8B400 Wrench-wheel Nut & jack handle Frontier $32.88
99596 oil filter wrench bag
99547 oil filter wrench
99548 oil filter wrench handle
99540 spark plug wrench
99512-25660 HAMMER
 99509-Z0000
Datsun 910
99545 wrench
02995-45200 WRENCH-WHEEL NUT
99610 jack
02996-10421 JACK-PANTOGRAPH TYPE sedan [groove type a la B110]
02996-01631 JACK-PANTOGRAPH TYPE wagon [finger type]
99595 wheel stop
99595-H7400 sedan [fixed type] (2)
99595-U1400 wagon [folding type] (1)
* 99595-F2700
99596 Tool bag
02995-95300 BAG-TOOL
99614 jack handle
02996-01100 HANDLE-JACK LEVER 910 sedan
99613 jack handle, 2-piece
02996-03200 ROD-JACK HANDLE wagon
99612 jack crank
02996-02100 HANDLE-JACK HANDle wagon
99501-89903 TOOL SET-STANDARD
Includes:
* 99545 wrench
* 99596 tool bag
U11
995 TOOL KIT
99501 TOOL SET-STANDARD
 99596 bag
 99535 phillips driver
 99545 lug wrench
 99525 pliers
 99507 spanner
 99507 spanner
02995-07100 spanner 8x10
 99507-01A00
02995-07300 spanner 12x14
 99512-01A00
02995-25100 PLIER
 99525-01A00
02995-30300 SCREWDRIVER/DRIVER-PLUS & MINUS [phillips + regular]
 99530-50Y00 $6.12 USD
 * S13, R50 USA
Alternative Datsuns Jacks
620 Pickup: rotary type for heavy loads
click
521 pickup handle
Long & Short handle (long one is for pickup)
1970-1976 S30 Tool Kit
1977-1978 S30 Tool Kit
280ZX Tool Kit
ジャッキ
