Also see:
Part Numbers Index Main article for usage, photos, cross-reference Door Door Hinge Door Glass Weatherstripping
Sedan
REAR DOOR (4 DOOR SEDAN) 1 82102-H1000 ASS'Y-PANEL, rear door (R.H.) STD 82102-H1100 ASS'Y-PANEL, rear door (R.H.) DX,GL,GX 82103-H1000 ASS'Y-PANEL, rear door (L.H.) STD 82103-H1100 ASS'Y-PANEL, rear door (L.H.) DX,GL,GX 2 82210-H1001 ASS'Y-SASH, rear door (R.H.) 82211-H1001 ASS'Y-SASH, rear door (L.H.) 3 82220-H1000 ASS'Y-SASH, partition, rear door (R.H.) 82221-H1000 ASS'Y-SASH, partition, rear door (L.H.) 4 82336-H1000 RUBBER-glass run "D" (2) 82336-H1001 RUBBER-glass run "D" (from '70-Oct.) (2) > 82336-H1000 5 08320-40612 SCREW-fixing partition to sash (2) fixing partition to inner parcel 6 08915-53610 WASHER-plain (2) 7 08915-13610 WASHER-lock (2) 8 08410-61012 SCREW (2) 9 82254-H1000 GLASS-rear door corner (R.H.) STD 82254-H1100 GLASS-rear door corner (R.H.) DX,GL,GX 82255-H1000 GLASS-rear door corner (L.H.) STD 82255-H1100 GLASS-rear door corner (L.H.) DX,GL,GX 10 82242-H1000 WEATHERSTRIP-partition rear door (2)
REAR DOOR HINGE (4 DOOR SEDAN) 11 82400-H1001 HINGE ASS'Y-rear door, upper (R.H.) 82401-H1001 HINGE ASS'Y-rear door, upper (L.H.) 12 82402-H1000 HINGE ASS'Y-rear door, lower (2) H0400-73002 BUSHING-door hinge (8) fixing hinge 13 01221-00031 BOLT-with plain & lock washer (fixing hinge to pillar) (12) 14 08120-82062 BOLT-with lock washer (fixing hinge to door) (10) or, fixing hinge 13 77720-89913 BOLT-special (fixing pillar) (12) 77740-89912 WASHER-plain special (fixing pillar) (12) 14 08120-82062 BOLT-with lock washer (fixing door) (10) or, fixing hinge 13,14 011-21000 BOLT-with plain & lock washer (22)
REAR DOOR FITTING (4 DOOR SEDAN) 15 82830-H1000 WEATHERSTRIP ASS'Y-rear door (R.H.) 82831-H1000 WEATHERSTRIP ASS'Y-rear door (L.H.) 16 ※左右Setで左?性?り。 82820-H1000 MOULDING ASS'Y-rear door outside (R.H.) <※> 82820-H3100 82820-H3100 MOULDING ASS'Y-rear door outside (R.H.) (from '72-4) 82821-H1000 MOULDING ASS'Y-rear door outside (L.H.) <※> 82821-H3100 82821-H3100 MOULDING ASS'Y-rear door outside (L.H.) (from '72-4) 17 80825-H1000 CLIP-moulding, door outside (8) 18 82836-H1000 WEATHERSTRIP-rear door inside (R.H.) 82837-H1000 WEATHERSTRIP-rear door inside (L.H.) 19 80860-H1000 STOPPER ASS'Y-door glass (2) 20 08310-61214 SCREW 21 86865-21010 RUBBER-bumper, rear door (2) 22 82804-H1000 SCREEN-seal (2) 23 80840-21001 COVER-drain hole (4) 24 96502-H1001 ASH TRAY ASS'Y (1) STD (2) DX,GL,GX 25 08520-51212 SCREW (1) STD (2) DX,GL,GX
REAR DOOR TRIMMING (4 DOOR SEDAN) 26 82900-H1000 FINISHER ASS'Y-rear door (R.H.) STD 82900-H3100 FINISHER ASS'Y-rear door (R.H.) STD 1972 82901-H3100 FINISHER ASS'Y-rear door (L.H.) STD 82901-H3100 FINISHER ASS'Y-rear door (L.H.) STD 1972 27 82900-H1100 FINISHER ASS'Y-rear door (R.H.) (Black) DX,GL,GX 82900-H3200 FINISHER ASS'Y-rear door (R.H.) (Black) DX,GL,GX 1972 82900-H1101 FINISHER ASS'Y-rear door (R.H.) (Yellow) DX 82900-H3201 FINISHER ASS'Y-rear door (R.H.) (Yellow) DX 1972 82901-H1100 FINISHER ASS'Y-rear door (L.H.) (Black) DX,GL,GX 82901-H3200 FINISHER ASS'Y-rear door (L.H.) (Black) DX,GL,GX 1972 82901-H1101 FINISHER ASS'Y-rear door (L.H.) (Yellow) DX 82901-H3201 FINISHER ASS'Y-rear door (L.H.) (Yellow) DX 1972 28 80919-89900 CLIP-door finisher (12) 29 80929-32200 CAP-door finisher (12) 30 80960-H1000 HANDLE-pull (M5) (2) STD < 80960-H1001 80960-H1001 HANDLE-pull (M6) (2) STD fixing pull handle 31 08310-52042 SCREW (M5) (4) 08310-62042 SCREW (M6) (4) 32 08915-43542 WASHER-plain (M5) (4) 08915-43642 WASHER-plain (M6) (4) 33 80940-H1100 ARM REST COMP (2) DX,GL,GX fixing arm rest 34 08410-62012 SCREW (4) 35 08915-13610 WASHER-lock (4)
Van
REAR DOOR (VAN) 1 82102-H1400 ASS'Y-PANEL, rear door (R.H.) 82102-H1400 ASS'Y-PANEL, rear door (R.H.) 2 82210-H1401 ASS'Y-SASH, rear door (R.H.) 82211-H1401 ASS'Y-SASH, rear door (L.H.) 3 82220-H1400 ASS'Y-SASH, partition, rear door (R.H.) 82221-H1400 ASS'Y-SASH, partition, rear door (L.H.) 4 82336-H1400 RUBBER-glass run "D" (2) 5 08320-40612 SCREW-fixing partition to sash (2) fixing partition to inner panel 6 08915-53610 WASHER-plain (2) 7 08915-13610 WASHER-lock (2) 8 08410-61012 SCREW (2) 9 82254-H1400 GLASS-rear door corner (R.H.) VS,VP 82254-H1500 GLASS-rear door corner (R.H.) V-DX 82255-H1400 GLASS-rear door corner (L.H.) VS,VP 82255-H1500 GLASS-rear door corner (L.H.) V-DX 10 82242-H1400 WEATHERSTRIP-partition rear door 2 V-Dx.
REAR DOOR HINGE (4 DOOR VAN) same as 4-door sedan above
