Glass
(Redirected from Door Glass)
Category: Body
See also: Power Windows
Ventilation
1972 USA Owners manual (Page 07 ... 07):
opening of the windows: door window, ventilator glass, and Quarter Window
Windshield/Windscreen
Front Door Glass
  • 2-dr Coupe Door glass differs from 2-dr Sedan glass
    22790.jpgAlbum 22790
  • 2-dr and 4-dr glass differs
  • 4-dr van and 4-dr sedan and Truck are the same
    22791.jpgAlbum 22791
Wing Window
The wing window is officially named the Door Ventilator. It is often called the quarter glass or quarter light window. Because it is hinged and opens, it supplies strong ventilation to the car in motion. These were very common before air conditioning became commonplace.
3251.jpgAlbum 3251 8188.jpgAlbum 8188
* 80244-H1001 GLASS-door ventilator (R.H.) 2 std
* 80244-H1101 GLASS-door ventilator (R.H.) 2 DX, 2 GL [tinted]
* 80244-H8000 GLASS-door ventilator (R.H.) Coupe
* 80250-H1001 CHANNEL ASS'Y-door ventilator (R.H.) 2 door [pivoting bottom-channel]
* 80250-H1800 CHANNEL ASS'Y-door ventilator (R.H.) Coupe [pivoting bottom-channel]
* 80270-H1001 FRAME ASS'Y-door ventilator (R.H.) 2 door
Channel Assembly includes pivot and latch handle
24618.jpgAlbum 24618 6992.jpgAlbum 6992
Compare to Datsun 1000 latch handle
Rubber Seals
22283.jpgAlbum 22283 8189.jpgAlbum 8189
2-door sedan, 4-door sedan, and Pickup
* 80282-H1001 WEATHERSTRIP-FRONT DOOR VENTILATOR, RH $13.69
* 80246-H1000 RUBBER-glazing, door ventilator (2) 2 door-Sedan & Coupe
  [holds glass in the pivoting bottom-channel]
Coupe
* 80282-H1800 WEATHERSTRIP-front door ventilator (R.H.)
  Sedan doors are a bit taller than coupe doors
  ... about 1/4 to 1/2 inch difference
* Spectrum Rubber
  * 221.101 Quarter window seals - front (coupe) LH
  * 221.102 Quarter window seals - front (coupe) RH[/quote]
Rear 4-door Sedan
* 82242-H1000 WEATHERSTRIP-partition rear door (2 )
Wing Delete
The vent window can be removed and custom glass can be fitted for a smooth look. Alternatively, Lexan) polycarbonate sheet can be into a window. This is used in drag racing for its low weight is easy to cut. However, polycarbonate is scratch-prone and after a while it gets cloudy and needs to be replaced.
Coupe: datsun_lover preliminary
15276.jpgAlbum 15276
Sedan:
POST Datrotor: glass is curved and no you won't find another window to fit.its a big job so don't do it unless you know people and know what your doing.i had custom made rubbers and channels made to suit.and changed the window reg
I deleted the triangle front window had custom glass made and made new window brackets in the door.havnt seen a sedan like this and looks 100x better :)
DE41730C-15DA-42EA-891C-313BC9B9170A-4183-000003C5A5709C9C.jpg C50B2BE7-EDBA-4CFC-9B6C-98F1CFFD7255-3123-000003333B42FA7C.jpg 40BE1AB8-40E9-4A4C-B628-6632D67DB803-2556-0000024A262282C6.jpg 4E7C15C1-6F3A-4D0A-9567-807816283FE1-2556-0000024A4CC0A5ED.jpg
Front Door Glass
8188.jpgAlbum 8188
2-door GLASS-DOOR WINDOW
 COUPE shorter glass
  80311-H1800 COUPE TEMPERED TINTED T=4 RH
  80312-H1800 COUPE LH
 SEDAN taller glass
  80310-H1200 SEDAN TEMPERED T=4.0MM RH
  80310-H1300 SEDAN TINTED VERSION RH
  80311-H1200 SEDAN TEMPERED T=4.0MM LH
  80311-H1300 SEDAN TINTED VERSION LH
4-door GLASS-DOOR WINDOW
UTE, VAN, SEDAN
 80310-H1000 RH
 80310-H1100 RH Deluxe
 80311-H1000 LH
 80311-H1100 LH Deluxe
Removal & Reinstall
  1. Take apart the door bits and pieces
    • Unscrew the door pull/armrest, door handle, and window winder
    • Carefully pop the door card (panel) off to access the inside of the door. Use a putty knife or other flat tool, slide it between the card and door until you locate the clip. Then twist to pop the clip out. There are two on one end and three on the other end.
  2. Roll the window up first. Then unbolt the window stop at the bottom of the door.
  3. Roll the window down so that the regulator comes out of the track on the window glass frame but be careful not to let the window drop too hard. Leave the glass at the bottom of the door temporarily.
  4. Take the quarter window frame out.
    • There are three screws at the top of the door concealed under the door rubber.
    • Also there is one larger screw towards the bottom of the door. It's recessed a bit.
    • Once loose pull the quarter window assembly out.
  5. Reach in the door and turn the door glass 90 degrees then pull of out from the top.
  6. To reinstall, do everything in reverse. However don't tighten the screws on the quarter window assembly until you get the new window to align with the slots on each side. That is the hardest part.
Rubber Seals
Glass Run
22282.jpgAlbum 22282
Glass Run uses Bailey Channel type rubber.
80336-H1001 RUBBER-glass run "B" (2) 4 door, 2 door
80335-H1001 RUBBER-glass run "A" (2) 4 door
80335-H1202 RUBBER-glass run "A" (2) 2 door
80336-H1800 RUBBER-glass run "B" (2) Coupe
80335-H1800 RUBBER-glass run "A" (2) Coupe
Truck
80336-G1000 RUBBER-glass run "B" (2)
* replaced 80336-H1001 RUBBER-glass run "B" (2)
80336-H1001 RETAINER RUBBER-GLASS (2) -8910
80336-G1901 RETAINER RUBBER-GLASS (2) 8910-
80335-G1000 RUBBER-glass run "A" (2)
* replaced 80335-H1001 RUBBER-glass run "A" (2)
80335-H1001 GLASS RUN RUBBER-A (2) -8508
80335-G1900 GLASS RUN RUBBER-A (2) 8508-8910
80335-G1901 GLASS RUN RUBBER-A (2) 8910-
Door Weatherstrip
  • inside glass rubber is named the Inside Door Weatherstrip
  • outside rubber is named the Outer Door Moulding Assembly and is part of (stapled to) the stainless moulding trim piece
Rear Door Glass
Van & Sedan differ (H10/H11 vs H14/H15)
* Rear Door Glass (straight on top edge vs slightly curved)
* Rear Door Corner Glass (4-edged vs triangular)
13932.jpgAlbum 13932 2271.jpgAlbum 2271
Window Winders
Window Regulator
2-dr door regulators have longer pivot arms (pivot point to roller) while the shorter 4-door front door regulators are likewise shorter.
Long Doors
* 80700-H1800 REGULATOR ASS'Y-door window (R.H.) Coupe
* 80701-H1800 REGULATOR ASS'Y-door window (L.H.) Coupe
Top: 2-dr Coupe
1916.jpgAlbum 1916
Bottom: 2-dr Sedan
* 80700-H1202 REGULATOR ASS'Y-door window (2) Sedan-2D
Short doors: 4-dr, Wagon, Truck (front & rear)
18709.jpgAlbum 18709
4-dr Sedan & Wagon, Truck
* 80700-H1002 REGULATOR ASS'Y-door window (2)
* 80701-H1002 REGULATOR ASS'Y-door window LH Truck
* 82700-H1001 REGULATOR ASSY-rear door window, RH
* 82701-H1001 REGULATOR ASSY-rear door window, LH
Compare to B210, which needs a scissor-type regulator to keep the glass straight (B210 doesn't have quarter windows so the glass is sharply angled)
B210 80701-H5000
Side Glass
Rear Window
Removal and Installation
Truck
Back Window - two sizes (small one is for raised-roof B140)
B120 rear glass
31335.jpgAlbum 31335
79712-G1000 GLASS-back window -7308
* 79417-G1001 WEATHERSTRIP
79712-G1200 GLASS-REAR WINDOW 7309-
* 79714-G1201 WEATHERSTRIP
25607.jpgAlbum 25607
rear window guard bar リヤ ウインドウ ガイド レール
26048.jpgAlbum 26048 174_6927fc16cbc76.jpgPost 499137 174_6927fc1b94812.jpgPost 499137
Rear Glass Protection Bars
79810-G1000 RAIL-GUARD, REAR WINDOW 7510-
25526.jpgAlbum 25526
Aussie
14091.jpgAlbum 14091
リア ガラス 保護 バー
Sedan
25522.jpgAlbum 25522
  • 79710-H1001 WEATHERSTRIP-REAR WINDOW
  • 79710-H1000 WEATHERSTRIP-REAR WINDOW
  • 79713-H1101 GLASS-REAR WINDOW T=4.0 TEMPERED & T 0771-
  • 79713-H1103 GLASS-REAR WINDOW T=4.0 TEMPERED & T
  • 79713-H1001 GLASS-REAR WINDOW T=4.0 TEMPERED
  • 79713-H1003 GLASS-REAR WINDOW T T=4.0
  • 79713-H2900 GLASS-REAR WINDOW,T=4,0, HEAT,ANTI SU
  • 79713-H2901 GLASS-REAR WINDOW T=4.0 HEAT
  • 79810-H1100 SET-MOULDING REAR WINDOW
    • 79812-H1100 MOULDING-REAR WINDOW UPPER
    • 79813-H1100 MOULDING-REAR WINDOW LOWER
    • 79814-H1100 MOULDING-REAR WINDOW RH
    • 79815-H1100 MOULDING-REAR WINDOW LH
  • 79810-H1101 SET-MOULDING REAR WINDOW 0670-
    • 79811-H1101 MOULDING-REAR WINDOW UPPER RH
    • 79812-H1101 MOULDING-REAR WINDOW UPPER LH
    • 79814-H1101 MOULDING-REAR WINDOW RH
    • 79815-H1101 MOULDING-REAR WINDOW LH
    • 72814-13600 CLIP-MOULDING
Coupe
  • 79710-H1800 WEATHERSTRIP-REAR WINDOW
  • 79713-H1805 GLASS-REAR WINDOW TINTED T=4.0
  • 79713-H2201 GLASS-REAR WINDOW,TINTED HEAT RIGHT,T
  • 79810-H1800 SET-MOULDING REAR WINDOW
    • 79812-H1800 MOULDING-REAR WINDOW UPPER
    • 79813-H1800 MOULDING-REAR WINDOW LOWER
    • 79814-H1800 MOULDING-REAR WINDOW SIDE RH
    • 79815-H1800 MOULDING-REAR WINDOW SIDE LH
    • 79816-H1800 CLIP-MOULDING UPPER
    • 79817-H1800 CLIP-MOULDING LOWER
Heated Glass
Heated rear glass (electric rear defroster) was an option for Sedan & Coupe.
Parts Sources
Rubber Sources
See also: Rubber parts
Glass Sources
  • eBay
  • Wrecking Yards
  • Datsun1200.com Classifieds forum
  • USA:
    • Pilkington Classics 1-800-848-1351
    • PPG Vintage 1-877-855-8100
Discussion
Glass Markings
U.S.A. glass markings
American Standard mark
AS-1 is clear laminated, can be used anywhere
AS-2 is clear tempered, not for front window use
DOT number is a number that the Department of Transportation (National Highway Traffic Safety Administration) assigns to the manufacturer of the glass. This is required by FMVSS (Federal Motor Vehicle Safety Standards) No. 205 (glazing materials) section S6.2
e.g. DOT 303 is Asahi Tokyo
M number is the model, specific to the manufacturer
e.g. M 30 from Pilkington is different from M 30 from Asahi
S6.2 A prime glazing manufacturer certifies its glazing by adding to the marks required by section 7 of ANSI/SAE Z26.1-1996, in letters and numerals of the same size, the symbol “DOT” and a manufacturer's code mark that NHTSA assigns to the manufacturer. NHTSA will assign a code mark to a manufacturer after the manufacturer submits a written request to the Office of Vehicle Safety Compliance, National Highway Traffic Safety Administration, 400 Seventh Street, SW., Washington, DC 20590. The request must include the company name, address, and a statement from the manufacturer certifying its status as a prime glazing manufacturer as defined in S4.
'NISSAN TEMPALEX' on bakkie low-roof rear window
31336.jpgAlbum 31336
ガラス ウインドー
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Glass"
This page has been accessed 117,953 times. This page was last modified 08:22, 27 November 2025. Content is available under Datsun 1200 Club.
