Welch plugs (core plugs) are circular discs that fit into, and seal the casting holes in the Engine block and Cylinder head. You may hear them called "welsh plugs". They are often called "freeze plugs" because if the engine coolant freezes they'll be pushed out of the casting. However, their purpose is not to solve freezing problems but rather to seal the holes left by the casting process.
Cylinder Head
- 00933-14000 PLUG-WELCH (1) head, rear
Engine Block
- 11019-32200 PLUG-WELCH 44 CAM BEARING (1) block, rear
- 00933-15000 PLUG-WELCH 50 CORE HOLE (3) block, rear prev. 01648-00084
- 00933-13500 PLUG-WELCH 35 CORE HOLE (3) block, right side
