Datsun 1200 uses traditional 8mm stem diameter poppet valves.
Maintenance
See main article: Valve adjustment
Removal & Installation
- Remove the Cylinder Head
- Compress the valve springs and remove the keepers, then the springs
- Slide valve out of the head
- Coat valve mating surface with grinding compound. Slide new valve in and lap the valve. Clean the compound off.
- If needed, remove old seals and put new seals on
- Re-fit the valve springs
Stem Oil Seal
See Main Article: Valve Seals
* Intake valve head diameter: 35 mm * Exhaust valve head diameter: 29 mm * Stem diameter: 8 mm * Overall length: 103.80 mm * Seat angle: 45 degrees * Head style: standard * Stem end: NG
* 13201-H1000 VALVE-INTAKE [35mm] * 13202-18000 VALVE-EXHAUST [29mm] * 13201-H2300 VALVE-INTAKE A12GX [35mm] * 13202-H2300 VALVE-EXHAUST A12GX [29mm]
Valve Keepers
Valve Spring Retainer Keeper (Valve lock) * Stem diameter 0.252 * 7 degree angle * SEALED POWER Part # VK215 * BECK/ARNLEY Part # 0230045
Interchange * 1976-1979 Buick Opel/Isuzu 1.8 * 1976-1978 Chevrolet Luv/Isuzu 1.8 * 1981-1995 Isuzu, various models * 1988-1996 Honda/Isuzu 2.6 * Datsun A-series * Datsun L-series 4 and 6 * Datsun Z-series
13209-18000 RETAINER-VALVE SPRING (8) <> 13209-H2300 <> 13209-H2301 13209-H2302 RETAINER-VALVE SPRING (8) 0772- [without O-ring grooves] 13209-H2302 RETAINER-VALVE SPRING (8) B210
13210-73400 COLLET-VALVE 1 (16) A12 (MATERIAL C40) < 13210-U0100 13210-H1000 COLLET-VALVE 1 (16) A12 0272- <> 13210-U0100 13210-U0100 COLLET-VALVE (MATERIAL C1010) B210 > 13210-73400 $1.13 USD
Valve Guides
See Main Article: Valve Guides
Valve Springs
See Main Article: Valve springs
Valve Angles
SEATS
* Intake: 75° + 45° + 22.5° max. dia. @ 45°: 34.6mm contact width = 1.3mm * Exhaust: 75° + 45° max. dia. @ 45°: 28.6mm contact width = 1.8 mm
VALVES * Intake 30° + 45°30' backcut * Exhaust 20° + 45°30' backcut * Minimum valve head thickness 0.5 mm
Others
For other A-series valves (A14, etc) and for competition valves, see:
* Cylinder_Head_Identification#Valves * Big Valves
