710
Revision as of 10:07, 18 January 2017; view current revision
Category: Nissan Vehicles
710 was the first generation of the Nissan Violet. Available in Sedan and Hardtop models, both of which had fastback styling. The difference was the door frames - sedans had frames around the door windows, while hardtops had no frames around the door glass. The Hardtop has up-sweeping rear side glass, while 2-door sedan had down-sweeping rear side glass.
[hide]
710 was the C-class (compact) model family for the Nissan sales organization (later named Nissan Blue). It differed from the Datsun 610 (Bluebird) notably by not using IRS in most of its models, making it handy for export markets to slot below the cost of the 610 with IRS.
710 "160J"
16575.jpgAlbum 16575 3339.jpgAlbum 3339
710 "Violet 1600"
4504.jpgAlbum 4504 11930.jpgAlbum 11930
SSS Hardtop
1973-1977 710 Market Names
Nissan Violet
Datsun 710/140J/160J/Sedan/Guayin
Yue Loong Violet
* nickname "bolillo"
SSS models came with IRS
710 early series: 1973-1976
711 late series:  1975- 1976
4-dr Sedan
2-dr Sedan
2-dr Hardtop (coupe)
4-dr Van (wagon)
For the last model year, the sedan changed from fastback style to notchback style.
Voilet and Bluebird
Violet was the C-class (compact) model family for the Nissan sales organization (later named Nissan Blue). It was a badge-engineered version of the Bluebird 610, with differed body and interior but same running gear & chassis/suspension. 710 did not use IRS in most of its models, making it handy for export markets to slot below the cost of the 610 with IRS. Bluebird moved upscale into the luxury sedan sedan market with availability of long-wheelbase six-cylinder 610 and 810 models, while Violet A10 continued as the lesser compact sedan.
Nissan Violet versus Datsun Bluebird
710, 610, B210 comparo
Applied Model Codes
Applied Model Codes
K01	710 Sedan '74
K03	710 Sedan '74
K04	710 Sedan '74
K05	710 Sedan '74
K09	710 Sedan '74
K10	710 Sedan '74
K11	710 Sedan '74
K12	710 Sedan '74
K13	710 Coupe '74
K16	710 Sedan '74
K17	710 Sedan '74
K20	710 Sedan '74
K21	710 Coupe '74
K25	710 Coupe '74
K29	710 Wagon '74
K30	710 Wagon '74
K31	710 Wagon '74
K32	710 Wagon '74
N69 L16E (SSS)
N70 LPG (L16P & L18P)
N71 L14
N72 Van
N74 Notchback
2-dr sedan (early series only)
J prefix?
710
4-door sedan
2-door sedan (door has window frame "post")
2-door Hardtop (door window has no frame)
710   STD 1400 L14 engine
710D  DX 1400  L14 engine
710H  GL 1400  L14 engine
P710  DX 1600  L16 engine
P710H GL 1600  L16 engine
P710K SSS - IRS, L16 twin carb engine
P710E SSS - IRS, L16 EFI engine
P710Y TAXI
P710P TAXI LPG L16P
R710P TAXI LPG L18P (late series)
K710 - hardtop coupe (1400 & 1600)
710 - 4-door sedan
710-R 2-door sedan
L14
L16
L16S - single carb
L16T - Twin carb
L16E - EFI (SSS model)
L16P LPG TAXI
L18P LPG TAXI 1.8 liter
SSS
SSS version of 710 differed from other trim levels:
IRS with R160 differential
Twin-carb or EFI
4-door Sedan or Hardtop (coupe). No 2-dr sedan SSS was offered
Sedan SSS: P710TE 4-speed
Sedan SSS: P710FE 5-speed
Coupe SSS: KP710TE 4-speed
Coupe SSS: KP710TE 5-speed
L16T: SU-type (early series only)
L16E: EFI
South Africa
160J - hardtop & sedan
160U - SSS(?) hardtop & sedan
ZA 710 "160U SSS" 4-door Sedan
IMG_0063.jpgPost click for topic IMG_0059.jpgPost click for topic 16574.jpgAlbum 16574 16573.jpgAlbum 16573 16572.jpgAlbum 16572 16571.jpgAlbum 16571
KHL710 Hardtop coupe
HL710R 2-dr sedan
HL710  4-dr sedan
WHL710 4-dr wagon
1974  L18 engine to 1974 August
1975- L20B engine from 1974 September (1975 model year)
suffix U export 710
1975-1976 model year
* CAL - suffix V California emissions
* CAN - suffix N Canada
* FED - USA emissions except CAL
