Jellybeans
Revision as of 06:13, 15 October 2016; view current revision
Category: Wheel And Tire
Whether you call them jellies or dish mags or slotted mags, tridents or kidney bean rims, they are the quintessental 1970s alloy wheel. Datsun 1200 uses 4-lug on 4-1/2" pitch circle (PCD), metric equivalent is 4.113mm PCD.
[hide]
Slotted Mag ID Guide
Jellybean Rim ID Guide
17197.jpgAlbum 17197 9950.jpgAlbum 9950
Cast IDs
Many rims have the brand, the size, or other information cast into the wheel, most often on the back side.
Center Caps
  • 3-screw
  • 4-screw
  • 5-screw
  • Captive (slips into the center hole from behind, before wheel is fitted)
  • Push-in (Pushes into the center hole)
Datsun B310 center caps fit many wheels
3488.jpgAlbum 3488
Slot Types
  • Rounded
  • Squared off
  • Trapezoidal
  • 4-slot (often called "dish mags")
  • 5-slot (most common)
  • 6-slot
4-slot
Rare 4-slot design
10148.jpgAlbum 10148
9231.jpgAlbum 9231 9232.jpgAlbum 9232 5735.jpgAlbum 5735
5-slot
Datsun 1200 SSS 12x4 Ward Wheels
5467.jpgAlbum 5467
5-slot 12x4
11887.jpgAlbum 11887
Cheviot Triden vs 1200 SSS comparo
52AD3323513BED51B06C1EAD5CEE27AA.jpgPost click for topic
1603.jpgAlbum click to view 2237.jpgAlbum click to view 3488.jpgAlbum click to view 5521.jpgAlbum click to view 5524.jpgAlbum click to view 15032.jpgAlbum click to view15548.jpgAlbum click to view 22399.jpgAlbum click to view 1620.jpgAlbum click to view
12x5 offset -2 (5.75" overall rim width) with steel washers
13447.jpgAlbum 13447 23767.jpgAlbum 23767 23768.jpgAlbum 23768
6-slot
6-window slot mags
  • Performance wheels#Spitfire
  • American Dragmaster (rounded sloping shoulder, or stepped shoulder)
  • International Dragmaster
  • Astro Supreme
  • Italia Carrera (squarish slots)
  • Universal Wheel
mini-7.jpgPost click for topic mini-11.jpgPost click for topic 24302.jpgAlbum 24302
Italia Carrera 114.3 PCD, 13x5.5, 2-5/8 backspace
8-slot
  • Cragar Mach 8
Trapezoidal slot
Triangular-like slots
18691.jpgAlbum 18691 9841.jpgAlbum 9841 6495.jpgAlbum 6495 10376.jpgAlbum 10376
13x7.5 - rounded shoulders
10375.jpgAlbum 10375
13x5.5 - squared shoulders
10374.jpgAlbum 10374
Valve Stem
* Valve stem in the slot
* Valve stem in the disc
* Valve stem in the barrel
Valve stem in the disc face
22449.jpgAlbum 22449
Shoulder
Rare is rounded flange shoulders
10375.jpgAlbum 10375 5735.jpgAlbum 5735
Common is squared flange shoulders
10374.jpgAlbum 10374 more1200Parts05_zpsf4e71d09.jpgPost click for topic
Hub Area
  • Flat
  • Recessed
  • Raised
Recessed hub
5735.jpgAlbum 5735
Raised hub (slightly raised in this case)
Brands
Peformance
See Main Article: Performance_wheels#Spitfire
6-slot Spitfires, listed by Performance up to 2007
2293.jpgAlbum 2293 23961.jpgAlbum 23961
Triden
Popularly called Trident-style, Triden was the name of a wheel made by CSA/Mullins.
See Main Article: Cheviot#Triden
  • Mullins Delta Triden
  • Mullins CSA "Delta"-brand Vectron
  • Mullins CSA "Cheviot"-brand Triden
Modified 5-slot jellies. Sometimes called "tridents", they come with silver or black centers:
1825.jpgAlbum 1825
  • Aunger
  • Wildcat
  • Ward
