Images
Padding
no space character (right, left padding)
0 top,bottom padding (class=test_pad_zero)
Album
Album Width
(Album 12.jpg is 330 x 225)
Album|12 (default, up to 400px wide, image is 330px wide)
Album|12|width=400, still shows correct 330px wide
Album|12|jpg|400, shown at 400px which makes the photo stretched, use only if you want to force a size
Arbitrary Width
forced widths, will stretch if needed (if width= is used, invalid widths will be ignored)
Album|13|jpg|width=400 256 192 120
Album Width by name
Album|8580|width=XL, LG, MED, SM, TH, THUMB
Album Width by number
widths available: 100,THUMB(140),TH(160),SM(256),MED(400),LG(560),XL(640),MAX. blank for no-resize (imagepx class). INDEX for inheritance
Album|8580 (750 x 462) [default Album class "imagepx" (400px wide)]
Album|8580|width=400 256 160 140 100
Mixed Widths
mixing Class width with arbitrary width
Class width wins:
{{Album|8580|jpg|SM|width=MED}} {{Album|8580|jpg|MED|width=SM}}
placement of width irrelevant
{{Album|width=TH|8580|jpg|SM}} {{Album|8580|jpg|SM|width=TH}}
Order in CSS /* GLOBAL WIKI styles */ img { max-width:400px; /* IMG general classes */ .imageSMpx img { max-width: 256px; }
Album Width INDEX
AlbumSize
No Click
PhotoTh!
Photo!
AlbumPhoto PhotoAlbum ThumbPhoto
Photo Photo! Photo-
PhotoH
PhotoTranslate
PhotoUrl (NO wrappers)
H
Height stretches to uniform height
PhotoH 166 default
UploadH 352 (limited to 400px wide)
Pending
S13 Japan Silvia 8805-9310 [250 mm] 40206-35F01 SR20DE.2WS+CA18DE+CA18DET 8805-9310 <> 40206-35F02 [280 mm] 40206-55F01 2WS.KS+4WS 9308- <> 40206-55F03,40206-7J101,40206-73L01,40206-73L02 aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaap
inlo
imageMEDpx class
helo
QUOTE
should be two paragraphs
blockquote (narrow)Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam Laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortisQuote with BRs added
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam Laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortisblockquote (class="wide")
QUOTE IMG
Did you know?
The Coupe came out two years after the sedan started selling
Datsun 1000 Coupe article
TOC
original TOC with 400px applied
styled TOC (UL margin affects)
current TOC
LIST
LIST IMG
All right edges should line up
See also =
Une
image100px
dos
Old Tech Section Graphic Old Tech Section Graphic
hello world
tres
next line
Force
op
Quin
next line
1 1
1
1
1 next line
1 1
1
float right is after this linelast line
Seis
Column
GMREADME.TXT Copyright (c) 1998-2000 Microsoft Corporation. All Rights Reserved.
The GM.DLS file contains the Roland SoundCanvas Sound Set which is protected under the following copyright: Roland GS Sound Set/Microsoft (P) 1996 Roland Corporation U.S. The Roland SoundCanvas Sound Set is licensed under Microsoft's End User License Agreement for use with Microsoft operating system products only. All other uses require a separate written license from Roland.
