Brown PB210
Revision as of 23:30, 2 July 2019; view current revision
Categories: Documentation | Datsun B210
<-- back to B210 Japan Brochures
Title: DATSUN Sunny Excellent 1400 [brown 1400 in front of the sea and sailboat]
1975 Sunny Excellent 1400 sedan PB210
Format:8 pages Size:unknown Publication Number:unspecified 30cm x 25.5cm
Comments? Questions? More photos or info? Reply to main forum: POST Brochures wanted
01 Cover
1975 October - DATSUN Sunny Excellent 1400
話題のNAPSを搭載。50年排出ガス規制適合車。 Equipped with the topic NAPS. Vehicles that meet the 1975 emission regulations.
27388.jpgAlbum 27388 27389.jpgAlbum 27389
02-03 Coupe & Sedan
27391.jpgAlbum 27391
04-05 Features
Features & NAPS SYSTEM
27390.jpgAlbum 27390
Coupe GL-L dash
Coupe GL-L interior
EXH TEMP lamp
Voltmeter
ELR Seat Belts
AM-FM radio
Trunk Opener (GL-L)
Heated rear glass
Cigarette Lighter
100 Yen coin holder console
06-07 Trim Grades
27392.jpgAlbum 27392
SEDAN
GL-L GL
COUPE
GL-L GL
08 Back Cover
27393.jpgAlbum 27393
サニーエクセレント1400-NAPS車 主要諸元 Sunny Excellent 1400-NAPS car main specifications
27394.jpgAlbum 27394
DATSUN A-PB210 Sedan Coupe
grade GL-L GL GL-L GL
4-speed floor shift 1PB210GTH 1PB210GT 1KPB210GH 1KPB210G
NissanMatic floor type 1PB210GAH 1PB210GA 1KPB210AH 1KPB210GA
DIMENSIONS
total length mm 4045 4045
width mm 1545 1545
height mm 1370 1350
wheelbase mm 2340 2340
tread front/rear mm 1275/1265 1275/1265
ground clearance mm 165 165
Weight
curb weight kg 915(930) 915(930)
Occupants 5 5
Gross weight kg 1190(1205) 1190(1205)
Performance
top speed km/h 155(145) 155(145)
tan angle 0.49(0.47) 0.49(0.47)
turning circle m 4.7 4.7
fuel economy 19.0(17.5) 19.0(17.5)
Engine
engine family L14 type
type overhead cam (OHC) 4 cylinder
displacment cc 1428
compression ratio 9.0
horsepower PS/rpm 85/6000
torque kgm/rpm 11.8/3600
carburetor single
Mechanism
suspension front mcpherson strut
suspension rear leaf spring
shock absorber ?
transmission 4-speed full synchro
(6 position Nissan Matic)
ratio 1st 3.657(2.458)
ratio 2nd 2.177(1.458)
ratio 3rd 1.419(1.000)
ratio 4th 1.000(----)
ratio REV 3.638(2.182)
brakes front master-back with disc
brakes rear leading/trailing type
tires 6.15-13-4PR
fuel tank l regular gasoline 44 regular gasoline 43
( ) NissanMatic
Colors
BODY COLOR & SEAT TRIM
211 olive green (metallic)
212 blue
216 white
214 SEDAN brown (metallic)
213 COUPE wine purple (metallic)
27395.jpgAlbum 27395
Dimensions#PB210
27396.jpgAlbum 27396
Equipment list
27397.jpgAlbum 27397
