The famous <E15ET> Nissan Turbo engine was the pinnacle of the Nissan E Engine design. It produced 115 hp (86 kW).
Also see E-series Engine Swap
Power
Turbo Power! Right from the factory. Some question whether a regular E15 has any real advantage over an A15, but there is no question that the E15ET (the turbo version) is a superior design. The cylinder head flows more than other E-series engines.
E15ETᵂ Stock * 115PS (85 kW; 113 hp) JAPAN * 106PS (78 kw; 105 bhp) AUS N12 Exa * Torque 116 lb-ft (157Nm) AUS * 7.8:1 Compression Ratio * 7.3 - 7.4 psi boost (7psi nominal) * T02-style turbo with internal wastegate
Modified
112.6 kw @ 5650 rpm
200 Nm @ 4322 rpm
The connecting rods are 3mm shorter than E15 rods, resulting in lower compression ratio of 7.3:1. This along with the low boost level results in suitable use with Regular octane fuel.
For 1986, the ET model also saw its 1.5-liter turbocharged engine updated for unleaded fuel, boost increased but power decreased.
Sources
- B11 Nissan Sunny GT/Sunny (JPN)
- 1982 B11 Nissan Sunny Turbo Leprix
- 1984-1986 N12 Nissan Pulsar ETᵂ (AUS) 5-door
- 1985-1986 N12 Nissan Pulsar ET (NZ)
- 1982-1986 N12 Nissan EXAᵂ (AUS) 2-door Coupe
- 1983-1986 N12 Nissan Pulsar NX Turboᴳ (USA)
Turbo
Nissan N12 Pulsar NX Turbo (USA) 0283-0784 Nissan Cherry Turbo (EUR) * 14411-17M00 TURBOCHARGER ** M26 AR .47 AiResearch M10/ Garrett TB020
AiResearch M10 turbocharger from Nissan Sunny B11 (JDM) * 14411-56A00
Distributor
