B210 Clock
Revision as of 19:21, 19 February 2024; view current revision
Categories: Datsun B210 | Body Electrical System
<-- back to B210 Gauges
Clocks come in a large 3-needle type and small 2-needle type. There are two shapes: square and round. The design is also stylish.
29674.jpgbrochure
27380-H5001
square meter
Compact 2-needle type
instrument panel
27380-H5100
square meter
large 3 needle type
instrument panel or console
27380-H5700
small 2 needle type
round meter
instrument panel
27380-H5700
large 3 needle type
round meter
Large Clock
Large Square Clock
Standard equipment for GL. Optional for all Coupe, Sedan and Van (except GX, which includes a tachometer).
3HAND type hour hand minute hand seconds hand
Large square clock was in the center gauge cluster, next to the speedometer, as in this photo:
21038.jpgAlbum 21038
174_65cfafb7e3ab8.pngPost 498290
  • Citizen
  • JECO
  • Kanto Seiki
If no meter is next to the speedometer, a blank plate is installed
174_65d11527c1df0.jpgPost 498290
If the is equipped with tachometer ala GX models, a #Small Square clock is fitted off to the side:
11137.jpgAlbum 11137
27380-H5110 Citizen
The Citizen clock only has one bottom screw
27380-H5110 CLOCK ASS'Y-A (シテズン型 CITIZEN) SEDAN-GL (from 1973-10)
174_65d123d376100.jpgPost 498293 174_65d123fd7ad38.jpgPost 498293
27380-H5100 JECO
27380-H5100 CLOCK ASS'Y-A (ジエコー型 JECO) SEDAN-GL
174_65d12421d8391.jpgPost 498293 174_65d1243d0ce73.jpgPost 498293 174_65d1244f37274.jpgPost 498293
Kanto Seiki
  • 27380-H5115*CLOCK ASS'Y-A (関東精器型 KANTO SEIKI) PB210-GL/GLL 4-speed,PB210-GL/GLL Automatic (from 1975-10)
  •  ?? 27380-H5116 CLOCK ASSY B211 SEDAN.A12.GL
174_65d1246459a45.jpgPost 498293 174_65d12478a2fa9.jpgPost 498293
Large Round Clock
Round (maru) type dash was fitted to B210 and PB210:
  • all JDM Coupes
  • Sedan GX
Large clock was in the GL and DX coupes next to the speedometer.
174_65cdcebeadc9c.jpgPost 498283
Clock blank was used in the small hole.
174_65cdcee532f2b.jpgPost 498283
The GX had a large tachometer, so used a small round clock off to the side
174_65cdcf0665e08.jpgPost 498283
27380-H5600
The original large round clock from 1973. Used by GL Coupe and DX Coupe.
H56 designed for KB210G (GL)
174_65cdd0b6e6073.jpgcatalog
174_65cdd0f403689.jpgPost 498284 174_65cdd10c7721c.jpgPost 498284 174_65cdd11a396d1.jpgPost 498284
27380-H5610
second-source manufacturer
174_65cdd59ec5fdf.jpgPost 498285 174_65cdd5c755ee8.jpgPost 498285 174_65cdd5ec00300.jpgPost 498285 174_65cdd67112e26.jpgPost 498285
Small Clock
Small Round
Small Square
11137.jpgAlbum 11137 174_6154f56671dac.jpgPost 495921
174_65cd9ce7413c4.jpgPost 498280
27380-H5001
square meter Compact 2-needle type 1973 up
174_65cd9cc82ee2a.jpgOPTION
27380-H5010
27380-H5010 CITIZEN 1977 JDM
174_65cdadffefcfb.jpgPost 498282 174_65cdae2212e50.jpgPost 498282 174_65cdae4233bba.jpgPost 498282 174_65cdae4fc69fc.jpgPost 498282 174_65cdae5a30592.jpgPost 498282
3-pin connector
174_65cdae354e0bc.jpgPost 498282
Blank Plate
Mask 'S' 25005-H5000 | Mask 'D'
174_6154f54e13d07.jpgPost 495921 174_6154f55c60613.jpgPost click for topic 174_615652c7ac425.jpgPost click for topic 174_65cda64fa2f92.jpgPost 498282 174_65cda6805ba84.jpgPost 498282
8508.jpgAlbum 8508 174_6156528c3b55c.jpgPost 495935
