Cowl Top Grille
Revision as of 03:57, 22 March 2009; view current revision
Category: Body
The Cowl top grille is the vents just below the windshield. There are three styles: Coupe, Sedan Standard and Sedan Deluxe. They all have the same screw pattern so can be swapped for a custom look.
13264.jpg Coupe style
2183.jpg Sedan DX style
9384.jpg STD style
14593.jpg Sedan Deluxe vs Coupe
16902.jpg 1000 vs 1200
NOTE: The metal grile plate under the Coupe "scoop" vents are different to the standard metal vent covers -- they are flat, not raised 5mm like the Standard grille.
[hide]
Colors
Coupe grilles at least were produced in body-matching colors. Sedan grilles appear to have been offered in gray or black. And Std style were painted black or body color.
Aftermarket
Bluemax is creating custom cowl top grilles in the coupe style.
Sedan DX
  • 66802-H1001 GRILLE-COWL TOP RH $63.33
  • 66802-H2314 GRILLE-COWL TOP RH ORANGE #006 Sedan DX
  • 66802-H2313 GRILLE-COWL TOP RH TURKOIS #005 $58.83
  • 66802-H2312 GRILLE-COWL TOP RH GREEN #004
  • 66803-H1001 GRILLE-COWL TOP RH $60.70
  • 66803-H2314 GRILLE-COWL TOP LH ORANGE #006
  • 66803-H2313 GRILLE-COWL TOP LH TURKOIS #005 $58.83
  • 66803-H2312 GRILLE-COWL TOP LH GREEN #004
