Borg Warner Differential
Revision as of 06:50, 18 August 2009; view current revision
Australian-assembled B110s and B210s used a Borg Warner rear axle assembly. These use a 'Salisbury' type differential, where the gears are embedded into the axle housing. Other B110s used the Hitachi Differential, with a removable "pumpkin" gear center-section. Also some South Africa 1200s were fitted with a BW differential.
  • B110: Borg Warner Model 60
  • B210: Borg Warner Model 68
Model 60
Australian-assembled B110s used a Borg Warner Model 60 rear axle, starting with chassis numbers:
  • Manual serial number 54507
  • Automatic serial number 40937
This started in Late 1971.
Apparently this is the same diff that was in AMI-built Corolla KE10, but those have a 4 x 110 wheel bolt pattern.
  • 38300-H1000BW Carrier & Diff Assembly
  • 38310-G0400BW Carrier
  • 38315-G0400BW Bolt-carrier bearing
Model 68
Australian 120Y 4-dr Sedans from July 1976 were locally assembled and used a Borg Warner rear axle assembly. (BW model 68). All were 3.889 ratio. The 120Y Coupe, Wagon, and Panel Van, being fully imported into Australia, continued to use the Hitachi [Jap] rear-end in 3.9 ratio while the Van might have had a different [lower] ratio.
641.JPG BW - removable back cover
1660.jpg Japan - welded back cover
The BW rear ends are pretty strong - meant to be stronger than H165.
This can be detected as there is a rear cover (the diff [center] doesn't unbolt from the front of the axle housing - like a GM differential only smaller). There will be a metal tag on one of the bolts that holds the cover on. It tells you which type of Borg Warner, and also the ratio (makes life easy at the wreckers).
They say Borg Warner on the bottom.
  • it will be a BW if it has a removable cover at the back of the diff
  • and either a H150 or H145 if it doesnt
The BW68 is the same width as a 1200 H145 diff, but have a different input flange, so you will also need the matching 120Y-BW tailshaft.
This is the same type of differential in the early Corollas.
641.JPG 640.JPG640 1202.jpg1202
Borg-Warner diff
11404.jpg 11405.jpg 11422.jpg 11423.jpg 11424.jpg 11425.jpg 11426.jpg 11442.jpg 11470.jpg 11472.jpg 17285.jpg 18656.jpg 18657.jpg 18658.jpg
Borg Warner 78
Australian-built Pintara R31 came with a Borg Warner 78 diff (198 mm ring gear). It is strong, about as strong as the H190 in the Datsun pickups.
