Cowl Top Grille
Revision as of 03:41, 24 October 2010; view current revision
Category: Body
The Cowl Top Grille is the vents just below the windshield. Their purpose is to prevent debris from entering the air intakes for the passenget compartment air flow. There are three styles: Coupe, Sedan Standard and Sedan Deluxe. They all have the same screw pattern so can be swapped for a custom look.
[hide]
Styles
13264.jpg Coupe style
9384.jpg STD style
14593.jpg Sedan Deluxe vs Coupe
16902.jpg 1000 vs 1200
NOTE: The metal grile plate under the Coupe "scoop" vents are different to the standard metal vent covers -- they are flat, not raised 5mm like the Standard grille.
Colors
Coupe grilles at least were produced in body-matching colors. Sedan grilles appear to have been offered in gray or black. And Std style were painted black or body color.
Aftermarket
Bluemax is creating custom cowl top grilles in the coupe style.
Sedan DX
  • 66802-H1001 GRILLE-COWL TOP RH $63.33
  • 66802-H2314 GRILLE-COWL TOP RH ORANGE #006 Sedan DX
  • 66802-H2313 GRILLE-COWL TOP RH TURKOIS #005 $58.83
  • 66802-H2312 GRILLE-COWL TOP RH GREEN #004
  • 66803-H1001 GRILLE-COWL TOP RH $60.70
  • 66803-H2314 GRILLE-COWL TOP LH ORANGE #006
  • 66803-H2313 GRILLE-COWL TOP LH TURKOIS #005 $58.83
  • 66803-H2312 GRILLE-COWL TOP LH GREEN #004
Coupe
  • 08530-41212 SCREW-TAPPING M4 FOR GRILLE FITTING 6
  • 08530-41612 SCREW-TAPPING M4 FOR GRILLE FITTING 6
66802-H1806	GRILLE-COWL TOP RH WHITE #821
66802-H1807	GRILLE-COWL TOP RH YELLOW #665
66802-H2307	GRILLE-COWL TOP RH YELLOW #665
66802-H1809	GRILLE-COWL TOP RH BLUE #645
66802-H2309	GRILLE-COWL TOP RH BLUE #645
66802-H1810	GRILLE COWL TOP RH GREEN #940
66802-H2311	GRILLE-COWL TOP,RH,GREEN #003
66802-H2305	GRILLE-COWL TOP RH RED #932
66802-H2314	GRILLE-COWL TOP,RH,ORANGE #006
66802-H2310	GRILLE COWL TOP RH GREEN #940
66802-H2301	GRILLE-COWL TOP RH YELLOW #926
66802-H2306	GRILLE-COWL TOP RH WHITE #821
66802-H1805	GRILLE-COWL TOP RH RED #932
66802-H1801	GRILLE-COWL TOP RH YELLOW #926
66802-H1800	GRILLE-COWL TOP RH WHITE #924
66802-H1802	GRILLE-COWL TOP RH GRAY #928
66802-H2302	GRILLE-COWL TOP RH GRAY #928
66802-H1803	GRILLE-COWL TOP RH GREEN #930
66802-H2303	GRILLE-COWL TOP RH GREEN #930
66802-H1804	GRILLE-COWL TOP RH GOLD #931
66802-H2304	GRILLE-COWL TOP RH GOLD #931
66802-H2300	GRILLE-COWL TOP RH WHITE #924
66803-H1809	GRILLE-COWL TOP LH BLUE #645
66803-H1806	GRILLE-COWL TOP LH WHITE #821
66803-H2306	GRILLE-COWL TOP LH WHITE #821
66803-H1807	GRILLE-COWL TOP LH YELLOW #665
66803-H2307	GRILLE-COWL TOP LH YELLOW #665
66803-H2309	GRILLE-COWL TOP LH BLUE #645
66803-H1810	GRILLE-COWL TOP LH GREEN #940
66803-H2311	GRILLE-COWL TOP,LH,GREEN #003
66803-H2314	GRILLE-COWL TOP,LH,ORANGE #006
66803-H2305	GRILLE-COWL TOP LH RED #932
66803-H2300	GRILLE-COWL TOP LH WHITE #924
66803-H1801	GRILLE-COWL TOP LH YELLOW #926
66803-H1805	GRILLE-COWL TOP LH RED #932
66803-H2301	GRILLE-COWL TOP LH YELLOW #926
66803-H1800	GRILLE-COWL TOP LH WHITE #924
66803-H1802	GRILLE-COWL TOP LH GRAY #928
66803-H2302	GRILLE-COWL TOP LH GREEN #928
66803-H1803	GRILLE-COWL TOP LH GREEN #930
66803-H2303	GRILLE-COWL TOP LH GREEN #930
66803-H1804	GRILLE-COWL TOP LH GOLD #931
66803-H2304	GRILLE-COWL TOP LH GOLD #931
Pickup
  • 66802-H1002 COWL TOP GRILLE, RH
  • 66803-H1002 COWL TOP GRILLE, LH
  • 08530-41212 SCREW-(fixing cowl top grille) (12)
