Fuel tank
Revision as of 03:51, 14 November 2010; view current revision
Category: Fuel System
Datsun 1200 uses a 38 or 40 liter petrol tank.
Also see: Fuel Cap, Fuel Gauge, Wiring
Mounting
Sedan tank is inside boot, just behind rear seat:
Coupe tank is undernearth car, under the boot area:
wagon tank
Coupe Tank
Vent hose loop
Vent hose loop (end hangs free, vents to atmosphere)
US EVAPO
Expansion Tank
17350-H1801 ASSY-TANK RESERVOIR
17350-H1802 ASSY-TANK RESERVOIR
Diagram
1 17201-H1802	ASSY-TANK FUEL 38L
2 17342-18000	RING-"O"
3 17343-H1001	PLATE-LOCK
3 17343-14801	PLATE-LOCK
4 25060-H1800	GAUGE-FUEL TANK
5 17312-P0101	PACKING-DRAIN
5 17312-P0102	PACKING-DRAIN
5 17312-H1000	PACKING-DRAIN
5 17312-14800	PACKING-DRAIN
6 17310-H1000	PLUG-DRAIN
6 17310-P0100	PLUG-DRAIN
6 08931-44210	PLUG-DRAIN
7 17251-H1902	CAP-FILLER
7 17251-H1900	CAP-FILLER
7 17251-H1000	CAP-FILLER
7 17251-H1901	CAP-FILLER
8 17264-18000	PACKING
9 17220-H1802	HOSE-FILLER UPPER
9 17220-H1803	HOSE-FILLER UPPER
10 17222-H1000	NECK-FILLER
11 17221-H1000	PACKING FILLER NECK
12 08310-40812	SCREW-MACHIN
13 17229-H1802	HOSE-FILLER
14 17228-H1400	GROMMET
15 08723-15800	CLAMP-HOSE
16 17230-H1802	HOSE-FILLER INNER
16 17230-H1801	HOSE-FILLER 2ND(NOT ADOPTED)
17 08723-13600	CLAMP-HOSE
18 A7325-H1000	TUBE-VINYLE(10X14DX5M)
18 A7515-H1900	TUBE-RUBBER(10X16DX5M)
18 08742-20040	TUBE-RUBBER
19 16439-22100	CLAMP-HOSE
19 08723-11400	CLAMP-HOSE
20 17324-H1800	GROMMET
21 08110-82062	BOLT WITH LOCK WASHER
22 08915-53810	WASHER-PLAIN
23 17350-H1801	ASSY-TANK RESERVOIR
23 17350-H1802	ASSY-TANK RESERVOIR
24 63140-78500	NUT-JAM
25 08410-61610	SCREW
26 08915-13610	WASHER-LOCK
27 17335-H1801	TUBE-BREATHER RH
27 17335-H1802	CONNECTOR
28 17336-H1801	TUBE-BREATHER LH
29 17515-H1817	HOSE-FUEL FIX FUEL TANK TO EVAPO TANK(L
29 A7515-H1800	HOSE-FUEL(6X13.5X5M)
29 08742-20020	HOSE-FUEL(6X13.5X2200MM)
29 A7515-H1800	HOSE-FUEL(6X13.5X10M)
29 08742-20020	HOSE-FUEL (6X13.5X2.2M)
30 16439-22100	CLAMP-HOSE 1
30 08723-11400	CLAMP-HOSE 1
31 17351-H1800	CONNECTOR-3 WAY
31 17351-H1801	CONNECTOR-3WAY
32 17361-H1800	TUBE-EVAPORATION
32 17361-H1801	TUBE-EVAPORATION
33 24251-H1801	GROMMET
34 00951-10600	GROMMET
35 00951-11000	GROMMET
36 00951-11200	GROMMET
37 46115-C0400	GROMMET
38 17337-H1800	PROTECTOR-FUEL HOSE
39 24210-89964	CLIP
40 74890-H1800	PROTECTOR-FILLER HOSE
41 08110-62010	BOLT FIXING PROTECTOR
42 08915-23610	WASHER FIXING PROTECTOR
43 08915-43610	WASHER FIXING PROTECTOR
Capacity
  • Sedan: (40 liter, 10.5 US gal)
  • Coupe: (38 liter, 10 US gal)
  • Wagon: (38 liter, 10 US gal)
Fuel Sender
The fuel level 'sender' is the sensor in the tank.
  • Sedan sender
To remove the sender, only a screwdriver and hammer is needed. Carefully drive the retaining ring anti-clockwise until loose.
  • Coupe has a vent fitting on it (non-EVAPO
  • Coupe has no vent fitting (EVAPO models)
All use same O-ring and lock plate, including B10 and B120 through B2310:
  • 17342-18000 O-ring
  • 17343-14800 Lock plate (also 17343-14801)
B110 Sedan USA & JDM
  • 25060-H1000 GAUGE-FUEL TANK
  • 25060-H1900 1070-
B110 Coupe USA & JDM
  • 25060-H1800
B110 Van JDM
  • 25060-H1400
B120 JDM
  • 25060-G1000 7510-8111
  • 20560-G1010 8112-
B210 Sedan USA & JDM
  • 25060-H5000
B210 Coupe USA & JDM
  • 25060-H5500
  • 25060-H7210 0974-
B210 Van JDM
  • 25060-H6600
B310 USA Sedan, Coupe, Wagon USA, early JDM
  • 25060-H8500 GAUGE ASSY-FUEL TANK
There is a single Yellow wire on the sender. It goes forward to the dash Fuel Gauge. The sender is grounded through the tank body.
See: Wiring - Fuel Gauge
As measured by club members, by moving the float up and down from stop to stop:
NOTE: This does not necessarily match "Full" and "Empty" marks of the fuel gauge, due to normal manufacturing tolerances. Typically a 1200 reads well 'E' before it runs out of fuel, this is normal.
Reference: Forum: Fuel sending unit specs
Also see:
Return Line
Starting in 1975, North American B210s were fitted with a fuel return line. Here's what the Nissan publication "Introduction of Datsun B210 (1975 model)" says:
Fuel return system
For preventing abnormal fuel temperature rise, the fuel return system has been installed. In this system, fuel from the fuel tank is delivered to both the carburetor and fuel tank.
The fuel return line services to return a part of the fuel to the fuel tank to suit different engine operating requirements, preventing the possibility of fuel heated flowing through the fuel line inside the engine compartment, and elminating "percolation" inside the carburetor.
Venting
Datsun 1200 in most parts of the world vents the fuel tank to the atmosphere. A simple hose loop goes from the filler tube up above the tank and back down towards the ground.
In USA, the tank is not vented directly to the air. Instead, fumes are captured by the Evaporate Emission control (EVAPO) system. For details, see Fume Control.
  • Fume Control
B210 and newer B120 (Datsun 1200 pickup) adopted the EVAPO system.
Late B120 tank
Parts Sources
  • Nissan. Call Ericksen Nissan's toll-free number. If Ericksen says they can't get a part let us know (click "Edit" and add it to this article). Also, if they do get the part for you, let us know that too!
    • NOTE: Nissan USA is out of stock forever of the Sedan hose. But perhaps they can get the Coupe hose.
  • Wreckers, if you can find a 1200 in a wrecking yard
  • Friends with parts cars
  • Marine supply stores, for general fuel hose and filler hose. NAPA and other old-line auto parts store carry this generic fuel-rated hose also. Trimmed to length using the old filler hose as a guide. It is tough getting it to flex into shape, but can be done.
Filler Hose
Coupe
USA B110 coupe tank
Sedan
Note that the USA B110 sedan tank uses a 2-piece filler hose (there's a small hose inside the bigger one). This is for the EVAPO (emissions market) vehicles:
Two-piece curved filler hose for EVAPO system
This hose is NLA (No Longer Available) in US, Canada or Japan. However, the regular single hose can be fitted as follows:
Straight one-piece filler hose for non-EVAPO system
The hose looks like this:
Filler Hose Comparo
Filler Modifications
Discussions:
B210 Sedan Tank is similar to B110 Sedan tank
Compare to B110 SEDAN tank
Sedan Tank factory Baffling:
Coupe
