Temperature Gauge
Revision as of 06:16, 28 April 2009; view current revision
Category: Wiring
Datsun 1200 comes with a full temperature gauge in the dash, controlled electrically by the Thermal Transmitter (sender) that is screwed into the cylinder head.
Also see: Water Temperature Gauge in Instruments and Controls
Thermal Transmitter
The temperature sender (sensor) is called the thermal transmitter. If varies resistance according to temperature.
Part Numbers:
  • 25080-89900 GAUGE-TEMP ENGINE UNIT
    • Beck/Arnley 2010247 Water Temperature Switch $17.49 at schucks.com
    • Standard Motor Products TS69 Engine Coolant Temperature Sender
  • 25251-30100 NUT
8122.jpg Transmitter is at very front of right side
15003.jpg Tranmitter at left side, pointing up> it has a threaded collar nut to hold it in.
3640.jpg Transmitter at right front corner of head (in the photo: left side of front of head)
Used by:
  • 1971 - 1973 1200
  • 1978 -1981 510 (A10 with L16 engine)
  • 1966 - 1970 1600
  • 1969 - 1972 521 Pickup (L16 Engine)
  • 1968 - 1970 2000
  • 1973 - 1976 610
  • 1977 - 1983 200SX (S10 & S110)
  • 1972 - 1979 620 Pickup
  • 1979 - 1982 210 (B310)
  • 1970 - 1973 240Z
  • 1974 - 1977 710
  • 1974 260Z
  • 1980 - 1986 720 Pickup
  • 1975 - 1978 280Z
  • 1977 - 1981 810
  • 1979 - 1983 280ZX
  • 1974 - 1978 B210
  • 1979 - 1982 310 (N10)
  • 1976 - 1978 F10
  • 1965 410
  • 1983 Pulsar
  • 1967 411
  • 1983 - 1984 Pulsar NX
  • 1968 - 1973 510
  • 1983 - 1985 Sentra
Troubleshooting
First, clean the connections of the wire to the thermal transmitter (engine temp sensor).
Yellow wire just about hose clamp
Remove the wire and clean the connector. Replace. Make sure the wire fits tight.
  • If both fuel and temperature gauges do not work at all, the fuse is likely burnt out. Inspect the fuse. If the fuse is good, the instrument panel voltage regulator may be bad
  • If both fuel gauge and temperature gauge read incorrectly (high or low) or fluctuate, the problem is likely the shared instrument panel voltage regulator. But first check the wiring connections. They may be loose or corroded.
  • If gauge reads MAX hot with ignition OFF, gauge is defective.
  • If gauge reads MAX hot with ignition ON, but cold with ignition OFF, transmitter is bad
  • Ground sensor wire at engine. If gauge fluctuates, gauge is bad
Accuracy Test
  • Buy a 116-ohm resistor at Radio Shack or other electronics store.
  1. At the engine, locate the thermal transmitter:
  2. Pull the wire off the transmitter and put a 116-ohm resistor from the wire to earth/ground
  3. Turn IGN switch to "ON". Gauge should read 50C/122F, or between C and H ranges (in middle range)
