Camshaft Comparison
Revision as of 04:16, 14 February 2012; view current revision
Category: Valvetrain
There are basically five factory camshaft grinds, from A10 to performance grinds.
240/240 duration (A10 Datsun 1000)
248/248 duration (standard small bore)
248/256 duration (standard large bore)
256/256 duration (performance engines)
244/248 duration (Late USA emission)
There are basically five factory camshaft grinds:
  • small bore grind
  • large bore grind
  • GX grind
  • Performance grind for A12T, A14T, EFI
  • Hi-torque emission grind (1981-1982 USA)
However, these can be fitted to any engine. The emission grind cam was used in A12A, A14 and A15 engine -- all with same cam part number.
Cam: A10 (B10) A12 (1973 USA) A12GX
Part: 13001-18000 13001-H1000 13001-H2300
HP: 62hp@6000rpm 69hp@6000rpm 83hp@6800rpm
Torque: 61.5 lb-ft 10.0kg-m@4,400rpm 9.7kg-m@3,600rpm
Exhaust open duration: 240° 248° 256°
Intake open duration: 240° 248° 256°
Intake opens at: 12° 14° BTDC 20° BTDC
Intake closes at: 48° 54° ABDC 56° ABDC
Exhaust opens at: 50° 56° BBDC 58° BBDC
Exhaust closes at: 10° 12° ATDC 18° ATDC
Lift:  ? 8mm 8.4mm
Duration
"Advertised Duration" means you should only compare these numbers with grinds from the same manufacturer. Other vendors may measure it differently.
Early vs. Late
For 1974, the A-series engine was re-designed. Because the distributor moved from beside cylinder #1 to beside cylinder #3, a new gear was added to the cam. The oil pump eccentric was moved from #3 to #2 at the same time.
Top: July 1974-up camshaft
Bottom: 1967-1973 June camshaft
Competition Camshaft
Beware, some cams have no eccentric cam for the fuel pump. You will have to use an electric fuel pump with these cams.
Top: Tomei 80A competition cam
Bottom: Early cam
Specs
A10: 240/240 12/48/10/50
1974-up
  • 13001-H9800 CAMSHAFT [Typical use: 1981-1982 USA]
    244/248 duration
    • USA B310 A14,A15 B310 0880-
    • USA B310 A12A 0880- B310
  • 13001-H5700 CAMSHAFT [Typical use: Performance engine]
    248/256 duration .331 lift
    • JPN B210 A12T, A14T
    • JPN B310 A14E, A15E
  • 13001-H5000 CAMSHAFT [Typical use: A12S]
    248/248 duration
    • JPN B120 A12S
    • JPN B210 A12S
    • JPN B310 A12S, A13S
    • USA B310 A12A 0879-0780
    • CAN B310 A12A
  • 13001-H6200 ASSY-CAMSHAFT [Typical use: A14/A15]
    248/256 duration
    • JPN B210 A14S
    • USA B210 A13, A14
    • USA B210 F10 A14
    • USA B310 A14,A15 -0780
    • JPN B310 A14S, A15S
ADVERTISED DURATION
* 13001-H5000/
* 13001-H6200
* 13001-H5700 .331 lift
* 13001-H9800
1967-1973
  • 13001-H7000 ASSY-CAMSHAFT USA B110 A12 0772- 0 13001-H2300
  • 13001-H2300 CAMSHAFT B110 JPN A12 GX
  • 13001-H1000 CAMSHAFT B110 USA JPN A12
  • 13001-18001 CAMSHAFT B10 JPN A10 0470- replaces 13001-18000 & 13001-H0100
  • 13001-18000 CAMSHAFT JPN B10 A10
  • 13001-H0100 CAMSHAFT JPN B10 A10
ADVERTISED DURATION
* 13001-H18001
248/248 duration
* 13001-H1000 A12
256/256 duration .331 lift
* 13001-H2300 A12 GX
Chart
Part Number@Ex. DurIn. DurIn. OpenIn. CloseEx. CloseEx. OpenLift (in)Reference
13001-18000 ?
13001-H1000?248248145412560.335photo
13001-H2300?256256205618580.353A12GX
13001-H5000?24824814541256 photo
13001-H5700?256248145420560.331here
13001-H6200?256248145420560.324photo
13001-H9800?24824414501256 1981
99996-H1031?300     0.487Nismo
99996-H1032?310     0.487Nismo
13001-H57100.10280 386235650.37topic
13001-H57110.10      0.37Nismo
?0.10320     0.413Nismo
?0.10328     0.413Nismo
