Also see:
Part Numbers Index Main article for usage, photos, cross-reference Carpet & Floor Mat Console
Mat, jute, kicking plate, interior sill trim, wheelhouse trim
Truck
Floor Trimming
Console Box =
Sedan
1 74902-H1605 MAT-FLOOR FRONT RH SEDAN 2 74902-H2031 CARPET-FLOOR FRONT RH OP SEDAN 3 74903-H1605 MAT-FLOOR FRONT LH SEDAN MANUAL 3 74903-H1725 MAT-FLOOR FRONT LH SEDAN AUTOMATIC 3 G4903-H1005 MAT-FLOOR FRONT LH SEDAN MANUAL 4 74903-H2031 CARPET-FLOOR FRONT LH OP SEDAN MANUAL 4 74903-H2025 CARPET-FLOOR FRONT LH OP SEDAN AUTOMATIC 5 74904-H2031 CARPET-FLOOR TUNNEL SEDAN MANUAL 6 74904-H2025 CARPET-FLOOR FRONT SEDAN AUTOMATIC 7 74907-H1105 MAT-FLOOR REAR SEDAN 8 74907-H2011 CARPET-FLOOR REAR OP SEDAN 9 61140-0502P HOOK 1 (12) SEDAN 10 08530-52512 SCREW-TAPPING 1 (12) SEDAN 11 74943-H1111 JUTE-TUNNEL FRONT SEDAN 4 SPEED 11 74943-H1121 JUTE-TUNNEL FRONT SEDAN AUTOMATIC 12 74941-H2011 JUTE-FRONT FLOOR (2) SEDAN 13 74921-H1100 COVER-FLOOR SIDE FRONT RH SEDAN 13 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211 SEDAN 0772- 13 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20 SEDAN 0173- 13 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 SEDAN 0173- 14 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20 SEDAN 0173- 14 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 SEDAN 0173- 14 74922-H1100 COVER-FLOOR SIDE FRONT LH SEDAN 14 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211 SEDAN 0772- 15 74925-H7000 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 SEDAN 0772- 15 74925-H7001 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 SEDAN 0173- 15 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 SEDAN 0173- 15 74925-H1300 COVER-FLOOR SIDE REAR RH SEDAN 16 74926-H1300 COVER-FLOOR SIDE REAR LH SEDAN 16 74926-H7000 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 SEDAN 0772- 16 74926-H7001 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 SEDAN 0173- 16 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 SEDAN 0173- 17 74914-H7000 COVER-REAR SEAT LOWER RH (BLUE,LB-211 SEDAN 0772- 17 74914-H7005 COVER-REAR SEAT LOWER LH (BLACK,LG-13 SEDAN 0173- 17 74914-H7003 COVER-REAR SEAT LOWER LH (BEIGE,LH-20 SEDAN 0173- 17 74914-H7001 COVER-REAR SEAT LOWER LH SEDAN 0772- 17 74914-H7002 COVER-REAR SEAT LOWER RH (BEIGE,LH-20 SEDAN 0173- 17 74914-H1101 COVER-REAR SEAT LOWER H SEDAN 17 74914-H7004 COVER-REAR SEAT LOWER RH (BLACK,LG-13 SEDAN 0173- 18 74915-H1000 COVER-REAR WHEEL HOUSE BLACK#1742 (2) SEDAN 18 74915-H1001 COVER-REAR WHEEL HOUSE YELLOW (2) SEDAN(DX) 1270- 18 74915-H7000 COVER-REAR WHEEL HOUSE (BLUE,LB-211 (2) SEDAN 0772- 18 74915-H7001 COVER-REAR WHEEL HOUSE (BEIGE,LH-20 (2) SEDAN 0772- 18 74915-H7002 COVER-REAR WHEEL HOUSE (BLACK,LG-13 (2) SEDAN 0173- 19 74917-18200 PAD-REAR WHEEL HOUSE (2) SEDAN 20 74951-H3600 PLATE-KICKING FRONT RH SEDAN 2 DOOR 1271- 20 74951-H1200 PLATE-KICKING FRONT RH SEDAN 2 DOOR 21 74952-H1200 PLATE-KICKING FRONT LH SEDAN 2 DOOR 21 74952-H3600 PLATE-KICKING FRONT LH SEDAN 2 DOOR 1271- 22 08540-41242 SCREW-TAPPING M4 (8) SEDAN 2 DOOR 22 08540-14242 SCREW-TAPPING M4 1 (16) SEDAN 2 DOOR 1271-
23 74980-H1801 ASSY-BOX CONSOL SEDAN MANUAL 23 74980-H7000 ASSY-BOX CONSOL SEDAN (MANUAL) 0772- 23 74980-H1921 ASSY-BOX CONSOL SEDAN AUTOMATIC 24 74980-H7001 ASSY-BOX,CONSOL SEDAN (MANUAL) 0772- 25 74982-H1021 FINISHER-CONSOL BOX SEDAN AUTOMATIC 25 74982-H1801 FINISHER-CONSOL BOX SEDAN MANUAL 26 74986-H1801 ASSY-BOOT SEDAN MANUAL 26 74986-H7000 ASSY-BOOT SEDAN (MANUAL) 0772- 27 74983-H1921 INDICATOR-COVER SEDAN AUTOMATIC 28 25172-H2520 ASSY-SOCKET SEDAN AUTOMATIC 29 74970-H1021 BULB SEDAN AUTOMATIC 30 74984-H1921 PLATE-POSITION SEDAN AUTOMATIC 31 74985-H1021 PLATE-SLIDE SEDAN AUTOMATIC 32 08510-61642 SCREW (8) SEDAN 33 08915-43642 WASHER-PLAIN (8) SEDAN 34 08310-41242 SCREW (2) SEDAN AUTOMATIC 35 08510-51242 SCREW (4) SEDAN AUTOMATIC 36 08915-43542 WASHER PLAIN (6) SEDAN AUTOMATIC 37 01241-00061 NUT-SPRING TYPE A (4) SEDAN 38 74990-H1800 MASK-CLOCK OP SEDAN(MANUAL) 39 08915-41212 SCREW (3) OP SEDAN(MANUAL) 40 08915-43410 WASHER-PLAINE (3) OP SEDAN(MANUAL)
Coupe
1 74902-H1605 MAT-FLOOR FRONT RH COUPE 2 74902-H2031 CARPET-FLOOR FRONT RH OP COUPE 3 74903-H1605 MAT-FLOOR FRONT LH COUPE 4 74903-H2031 CARPET-FLOOR FRONT LH OP COUPE 5 74904-H2025 CARPET-FLOOR TUNNEL COUPE AUTOMATIC 5 74904-H2031 CARPET-FLOOR TUNNEL COUPE 4 SPEED 6 74907-H1102 CARPET-FLOOR REAR COUPE 2 74907-H1101 6 74907-H1105 MAT-FLOOR REAR COUPE 6 74907-H1101 CARPET-FLOOR REAR COUPE 7 74907-H2011 CARPET-FLOOR REAR OP COUPE 8 08530-52512 SCREW-TAPPING 1 (12) COUPE 9 74943-H1111 JUTE-TUNNEL FRONT COUPE 4 SPEED 9 74943-H1121 JUTE-TUNNEL FRONT COUPE AUTOMATIC 10 74941-H2011 JUTE-FRONT FLOOR (2) COUPE 11 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20 COUPE 0173- 11 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 COUPE 0173- 11 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211 COUPE 0772- 11 74921-H1100 COVER-FLOOR SIDE FRONT RH COUPE 12 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211 COUPE 0772- 12 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20 COUPE 0173- 12 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 COUPE 0173- 12 74922-H1100 COVER-FLOOR SIDE FRONT LH COUPE 13 74925-H7102 COVER-FLOOR SIDE REAR RH (BLACK,LG-13 COUPE 0173- 13 74925-H1800 COVER-FLOOR SIDE REAR RH COUPE 13 74925-H7100 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 COUPE 0772- 13 74925-H7101 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 COUPE 0173- 14 74926-H7102 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 COUPE 0173- 14 74926-H7101 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 COUPE 0173- 14 74926-H7100 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 COUPE 0772- 14 74926-H1800 COVER-FLOOR SIDE REAR LH COUPE 15 74914-H1100 COVER-REAR SEAT LOWER RH COUPE 15 74914-H7000 COVER-REAR SEAT LOWER RH (BLUE,LB-211 COUPE 0772- 15 74914-H7002 COVER-REAR SEAT LOWER RH (BEIGE,LH-20 COUPE 0173- 15 74914-H7004 COVER-REAR SEAT LOWER RH (BLACK,LG-13 COUPE 0173- 16 74914-H7001 COVER-REAR SEAT LOWER LH (BLUE,LB-211 COUPE 0772- 16 74914-H7003 COVER-REAR SEAT LOWER LH (BEIGE,LH-20 COUPE 0173- 16 74914-H1101 COVER-REAR SEAT LOWER LH COUPE 16 74914-H7005 COVER-REAR SEAT LOWER LH (BLACK,LG-13 COUPE 0173- 17 74915-H1800 COVER-REAR WHEEL HOUSE RH COUPE 17 74915-H1801 COVER-REAR WHEEL HOUSE RH YELLOW COUPE 1270- 17 74915-H7100 COVER-REAR WHEEL HOUSE RH (BLUE,LB-211 COUPE 0772- 17 74915-H7101 COVER REAR WHEEL HOUSE RH (BEIGE,LH-20 COUPE 0772- 17 74915-H7102 COVER REAR WHEEL HOUSE RH (BLACK,LG-13 COUPE 0173- 18 74916-H1801 COVER-REAR WHEEL HOUSE LH YELLOW COUPE 1270- 18 74916-H7102 COVER REAR WHEEL HOUSE LH (BLACK,LG-13 COUPE 0173- 18 74916-H7101 COVER REAR WHEEL HOUSE LH (BEIGE,LH-20 COUPE 0772- 18 74916-H1800 COVER-REAR WHEEL HOUSE LH COUPE 18 74916-H7100 COVER-REAR WHEEL HOUSE LH (BLUE) COUPE 0772- 19 74917-H1800 PAD-REAR WHEEL HOUSE (2) COUPE 19 74917-H7000 PAD-REAR WHEEL HOUSE (2) COUPE 0173- 20 74951-H1200 PLATE-KICKING FRONT RH COUPE 20 74951-H3600 PLATE-KICKING FRONT RH COUPE 1271- 0 74951-H1200 21 74952-H3600 PLATE-KICKING FRONT LH COUPE 1271- 0 74952-H1200 21 74952-H1200 PLATE-KICKING FRONT LH COUPE 22 08540-41242 SCREW-TAPPING M4 (8) COUPE 22 08540-41242 SCREW-TAPPING M4 1 (16) COUPE 1271- 23 74961-H1100 TRIM-SEAT RISER RH COUPE 24 74962-H1100 TRIM-SEAT RISER LH COUPE 24 74962-G1000 TRIM-SEAT RISER,LH COUPE 2 74962-H1100
25 74980-H1801 ASSY-BOX CONSOL COUPE MANUAL 25 74980-H7000 ASSY-BOX CONSOL COUPE MANUAL 0772- 0 74980-H1801 25 74980-H1921 ASSY-BOX CONSOL COUPE AUTOMATIC 26 74980-H7001 ASSY-BOX CONSOLE COUPE MANUAL 0772- 0 74980-H2010 26 74980-H2010 ASSY-BOX CONSOL COUPE MANUAL 0772- 27 74982-H1801 FINISHER-CONSOL BOX COUPE MANUAL 28 74986-H1801 ASSY-BOOT COUPE MANUAL 28 74986-H7000 ASSY-BOOT COUPE MANUAL 0772- 0 74986-H1801 29 08510-51242 SCREW (8) COUPE MANUAL 30 08915-43542 WASHER-PLAIN (8) COUPE MANUAL 31 01241-00061 NUT-SPRING (4) COUPE 32 74990-H1800 MASK-CLOCK COUPE MANUAL 33 08513-41212 SCREW (3) COUPE MANUAL 34 08915-43410 WASHER-PLAIN (3) COUPE MANUAL
