Rear Suspension Part Numbers
Revision as of 02:44, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Rear Suspension
1 55020-H1000 ASSY-LEAF SPRING REAR (2) 2 SEDAN COUPE
2 55203-H1001 MOUNTING-FRONT LEAF SPRING (2) 2 SEDAN COUPE
2 55203-H2500 MOUNTING-FRONT LEAF SPRING (2) 2 SEDAN COUPE 0273-
3 55219-H2500 PLATE-FRONT OUTER LEAF SPRING (2) 2 SEDAN COUPE 0273- 2 40323-18000
3 55219-H1001 PLATE-FRONT OUTER LEAF SPRING (2) 2 SEDAN COUPE
4 55044-H5001 BUSH-FRONT UPPER LEAF SPRING (8) 8 SEDAN COUPE 2 55044-H1001
4 55044-H1001 BUSH-FRONT UPPER LEAF SPRING (8) 8 SEDAN COUPE
5 08915-23810 WASHER-LOCK UPPER (4) 4 SEDAN COUPE
6 08911-60810 NUT-HEX M8X1.25 UPPER (4) 4 SEDAN COUPE
7 08915-23810 WASHER-LOCK LOWER (2) 2 SEDAN COUPE
8 08911-60810 NUT-HEX M8X1.25 LOWER (2) 2 SEDAN COUPE
9 55220-H1000 ASSY-SHACKLE LEAF SPRING REAR (2) 2
9 55220-G1900 ASSY-SHACKLE LEAF SPRING REAR (2) 2 55220-H1000
10 55221-H1000 PLATE-SHACKLE LEAF SPRING OUTER (2) 2
11 55046-H1000 BUSH-SHACKLE REAR UPPER (4) 4
12 55047-H1000 BUSH-SHACKLE REAR LOWER (4) 4
13 08915-23810 WASHER-LOCK REAR (4) 4
14 08911-60810 NUT-HEX M10X1.25 REAR (4) 4
15 55262-H1001 SEAT-LEAF SPRING LOWER (2) 2 SEDAN
15 55262-H2801 SEAT-LEAF SPRING LOWER (2) 2 SEDAN 0673- 5 55262-H1001
16 55262-H1802 SEAT-LEAF SPRING LOWER RH (2) 2 COUPE 0673- 5 55262-H1801
16 55262-H1801 SEAT-LEAF SPRING LOWER RH COUPE -573 3
17 55266-H1802 SEAT-LEAF SPRING LOWER LH COUPE 0673- 5 55266-H1801
17 55266-H1801 SEAT-LEAF SPRING LOWER LH COUPE -573 3
18 55247-H1001 CLIP-REAR SPRING (4) 4 SEDAN COUPE -573 3
18 55247-H1002 CLIP-REAR SPRING (4) 4 SEDAN COUPE 0673- 5 55247-H1001
19 55248-H1000 PLATE-CLIP REAR SPRING (2) 2 SEDAN -573 3
19 55248-H1001 PLATE-CLIP REAR SPRING (2) 2 SEDAN 0673- 5 55248-H1000
20 55240-H1800 ASSY-BUMPER REAR AXLE (2) 2 COUPE 0673- 5 55240-H1400
20 55240-H1400 ASSY-BUMPER REAR AXLE (2) 2 COUPE -573 3
21 08911-64010 NUT-HEX M10X1.25 (8) 8
22 08915-14010 WASHER-SPRING LOCK (8) 8
23 55350-H1000 APRESTER-TORQUE REAR SPRING SEDAN COUPE
24 08915-23610 WASHER-SPRING LOCK (2) 2 SEDAN COUPE
25 01111-00022 BOLT-HEX M6X1.0 (2) 2 SEDAN COUPE
26 08911-10810 NUT-HEX M8X1.25 (2) 2 COUPE
27 08915-13810 WASHER-LOCK (2) 2 COUPE
28 56200-H1001 COMP-ABSORBER SHOCK REAR (2) 2 SEDAN
29 56113-09400 WASHER (2) 2 SEDAN
30 55240-H1001 BOUND BUMPER A (2) 2 SEDAN
31 56124-H1001 BOUND-BUMPER B (2) 2 SEDAN
32 56112-09400 BUSH (2) 2 SEDAN
33 56123-H1000 SEAT-BOUND BUMPER (2) 2 SEDAN
34 56218-H1000 BOLT-SHOCK ABSORBER LOWER MOUNTING (2) 2 SEDAN
35 08911-14210 NUT-HEX M12X1.25 (2) 2 SEDAN
36 08915-24210 WASHER-SPRING LOCK (2) 2 SEDAN
37 56210-H1825 KIT-ABSORBER SHOCK REAR (2) 2 COUPE
38 56125-18000 BUSH-RUBBER (4) 4 COUPE
39 08911-10810 NUT-HEX M8X1.25 (4) 4 COUPE
40 08911-30810 NUT-HEX (2) 2 COUPE
41 56124-18000 BUSH-RUBBER (4) 4 COUPE
42 56122-18000 WASHER'A' (2) 2 COUPE
43 56123-18000 WASHER'B' (2) 2 COUPE
44 08915-13810 WASHER-SPRING LOCK (2) 2 COUPE
